Files missing from the MIMX9331 SDK
1,889 次查看
TK6223
I started writing our firmware using a development board that had a MIMX9352 SoC. Our own hardware has a MIMX9331 SoC, so I downloaded the SDK (25.09) for that chip and updated the project files to use the correct SDK. This resulted in the build failing because the following files were missing:
components/uart/component_lpuart_adapter.MIMX9331.cmake
devices/MIMX9331/all_lib_device.cmake
devices/MIMX9331/cmsis_drivers/driver_cmsis_lpi2c.MIMX9331.cmake
devices/MIMX9331/device_CMSIS.MIMX9331.cmake
devices/MIMX9331/device_startup.MIMX9331.cmake
devices/MIMX9331/device_system.MIMX9331.cmake
devices/MIMX9331/drivers/driver_cache_xcache.MIMX9331.cmake
devices/MIMX9331/drivers/driver_clock.MIMX9331.cmake
devices/MIMX9331/drivers/driver_common.MIMX9331.cmake
devices/MIMX9331/drivers/driver_iomuxc.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpi2c_edma.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpuart.MIMX9331.cmake
devices/MIMX9331/drivers/driver_memory.MIMX9331.cmake
devices/MIMX9331/drivers/driver_rgpio.MIMX9331.cmake
devices/MIMX9331/drivers/edma4/driver_edma4.MIMX9331.cmake
devices/MIMX9331/utilities/debug_console_lite/utility_assert_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utilities_misc_utilities.MIMX9331.cmake
devices/MIMX9331/utilities/utility_debug_console_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utility_str.MIMX9331.cmake
The SDK for the MIMX9331 contains also the MIMX9352 files under devices, and the corresponding files for the 9352 exist there. As a workaround I've manually copied the missing files from the 9352 directory and renamed them (+ fixed the contents to refer to the 9331 when necessary).
Will the missing MIMX9331 files be added in an upcoming release?
1,885 次查看
Bio_TICFSL
Please take this appnote for differences between MX91 and MX93.
https://www.nxp.com/docs/en/application-note/AN14012.pdf
1,729 次查看
TK6223
Thanks for the reply! These are both i.MX93 chips so I don't see how the MX91 would be relevant here, but please correct me if I'm wrong.
And shouldn't there at least be the all_lib_device.cmake file with the corresponding configuration for the MIMX9331? I didn't check the peripherals related to each of the missing files, but for example the driver_clock, driver_common, driver_iomuxc and driver_rgpio files definitely sound like something that should be there.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMX9331%20SDK%20%E4%B8%A2%E5%A4%B1%E7%9A%84%E6%96%87%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E9%85%8D%E6%9C%89%20MIMX9352%20SoC%20%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E6%9D%A5%E7%BC%96%E5%86%99%E5%9B%BA%E4%BB%B6%E3%80%82%E6%88%91%E4%BB%AC%E8%87%AA%E5%B7%B1%E7%9A%84%E7%A1%AC%E4%BB%B6%E9%87%87%E7%94%A8%E7%9A%84%E6%98%AF%20MIMX9331%20SoC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%E8%AF%A5%E8%8A%AF%E7%89%87%E7%9A%84%20SDK%20(25.09)%EF%BC%8C%E5%B9%B6%E6%9B%B4%E6%96%B0%E4%BA%86%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%20SDK%E3%80%82%E8%BF%99%E5%AF%BC%E8%87%B4%E7%89%88%E6%9C%AC%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%BC%BA%E5%B0%91%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%85%83%E5%99%A8%E4%BB%B6%2FUART%2Fcomponent_lpuart_adapter.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2Fall_lib_device.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2Fcmsis_drivers%2Fdrivers_cmsis_lpi2c.mimx9331.c.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2Fdevice_cmsis.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2Fdevice_startup.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2Fdevice_system.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fdriver_cache_xcache.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E5%99%A8%2Fdriver_clock.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fdriver_common.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E5%99%A8%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_iomuxc.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E5%99%A8%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_lpi2c_edma.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E5%99%A8%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_lpuart.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E5%99%A8%2Fdriver_memory.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fdriver_rgpio.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2Fedma4%2Fdriver_edma4.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2FDEBUG_Console_Lite%2FUtility_assert_Lite.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F_misc_Utilities.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2FUtility_DEBUG_Console_Lite.mimx9331.cmake%20%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%2Fmimx9331%2F%E5%AE%9E%E7%94%A8%E7%A8%8B%E5%BA%8F%2Futility_str.mimx9331.cmake%3C%2FP%3E%3CP%3EMIMX9331%20%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E8%BF%98%E5%8C%85%E5%90%AB%E8%AE%BE%E5%A4%87%E4%B8%8B%E7%9A%84%20MIMX9352%20%E6%96%87%E4%BB%B6%EF%BC%8C9352%20%E7%9A%84%E7%9B%B8%E5%BA%94%E6%96%87%E4%BB%B6%E4%B9%9F%E5%AD%98%E5%9C%A8%E4%BA%8E%E8%AE%BE%E5%A4%87%E4%B8%8B%E3%80%82%E4%BD%9C%E4%B8%BA%E4%B8%80%E7%A7%8D%E5%8F%98%E9%80%9A%E5%8A%9E%E6%B3%95%EF%BC%8C%E6%88%91%E4%BB%8E%209352%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E6%89%8B%E5%8A%A8%E5%A4%8D%E5%88%B6%E4%BA%86%E4%B8%A2%E5%A4%B1%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E9%87%8D%E6%96%B0%E5%91%BD%E5%90%8D%E4%BA%86%E5%AE%83%E4%BB%AC%EF%BC%88%2B%20%E4%BF%AE%E5%A4%8D%E4%BA%86%E5%86%85%E5%AE%B9%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%E5%BF%85%E8%A6%81%E6%97%B6%E5%8F%82%E8%80%83%209331%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E7%BC%BA%E5%A4%B1%E7%9A%84%20MIMX9331%20%E6%96%87%E4%BB%B6%E4%BC%9A%E5%9C%A8%E5%8D%B3%E5%B0%86%E5%8F%91%E5%B8%83%E7%9A%84%E7%89%88%E6%9C%AC%E4%B8%AD%E6%B7%BB%E5%8A%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%E8%BF%99%E4%B8%A4%E6%AC%BE%E8%8A%AF%E7%89%87%E9%83%BD%E6%98%AF%20i.MX93%20%E8%8A%AF%E7%89%87%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%20MX91%20%E4%B8%8E%E6%AD%A4%E6%9C%89%E5%85%B3%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E8%AF%B4%E9%94%99%E4%BA%86%EF%BC%8C%E8%AF%B7%E6%8C%87%E6%AD%A3%E3%80%82%3C%2FP%3E%3CP%3E%E9%9A%BE%E9%81%93%E4%B8%8D%E5%BA%94%E8%AF%A5%E8%87%B3%E5%B0%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%20MIMX9331%20%E7%9B%B8%E5%BA%94%E9%85%8D%E7%BD%AE%E7%9A%84%20all_lib_device.cmake%20%E6%96%87%E4%BB%B6%E5%90%97%EF%BC%9F%E6%88%91%E6%B2%A1%E6%9C%89%E6%A3%80%E6%9F%A5%E4%B8%8E%E6%AF%8F%E4%B8%AA%E4%B8%A2%E5%A4%B1%E6%96%87%E4%BB%B6%E7%9B%B8%E5%85%B3%E7%9A%84%E5%A4%96%E8%AE%BE%EF%BC%8C%E4%BD%86%E4%BE%8B%E5%A6%82%20driver_clock%E3%80%81driver_common%E3%80%81driver_iomuxc%20%E5%92%8C%20driver_rgpio%20%E6%96%87%E4%BB%B6%E5%90%AC%E8%B5%B7%E6%9D%A5%E8%82%AF%E5%AE%9A%E5%BA%94%E8%AF%A5%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20MX91%20%E5%92%8C%20MX93%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B7%AE%E5%BC%82%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%9C%AC%E5%BA%94%E7%94%A8%E6%B3%A8%E9%87%8A%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
