FRDM K64F - OUTPUT
FRDM K64F - OUTPUT
5,126件の閲覧回数
kofikofi
Am using P& E Micro bootloader for K64F and that gets me to communicate with the board. Great !!!
PLEASE HAVE A LOOK AT THE ATTACHMENT...
Now the output to my serial terminal emulator (Putty ) does not make sense. Am running a basic "Hello, world " demo and can't get any meaningful print out tho the MCUexpresso console shows the correct output.
How do I fix this... by the way I have tried Tera Term emulator and its the same bad outcome.
Kofi
4,899件の閲覧回数
ZhangJennie
I just tested hello_world SDK demo, PRINTF can print to UART console without problem.
Make sure you enable uart console
make sure the serial terminal with the following settings:
    - 115200 baud rate
    - 8 data bits
    - No parity
    - One stop bit
    - No flow control
Jennie Zhang
