How can I install the Eclipse Marketplace Client in MCUXpresso? It is not available by default under Help > Install new software...
After adding the repository http://download.eclipse.org/mpc/neon, I can select the plugin, but installation cannot be completed due to a missing requirement:
Cannot complete the install because one or more required items could not be found.
Software being installed: Marketplace Client 1.5.1.v20160929-1432 (org.eclipse.epp.mpc.feature.group 1.5.1.v20160929-1432)
Missing requirement: Marketplace Client 1.5.1.v20160929-1432 (org.eclipse.epp.mpc.feature.group 1.5.1.v20160929-1432) requires 'org.eclipse.equinox.p2.discovery.feature.feature.group [1.0.0.v201004,2.0.0)' but it could not be found
What other repositories need to be added, and which plugins need to be minimally installed?
Dries.
Solved! Go to Solution.
Try installing from the releases repository.
http://download.eclipse.org/releases/neon
The Eclipse Marketplace Client is under General Purpose Tools → Marketplace Client
Thanks, that worked.
Any reason why the Neon release repo is not included by default? And why the Marketplace is not installed by default?
