what should I do to use MCUXpresso LinkServer
crj1998
My board is in BOOTLOADER state,what should I do if I want to use MCUXPresso LinkServer?For Example, what file should i put in the BOOTLOADER?
and the IDE always in the state as follow。
Tags (2)
ErichStyger
Specialist I
Can you tell what board you are using?
If it is a FRDM board with OpenSDA, maybe you need to revover your board, see Recovering OpenSDA Boards with Windows 10 | MCU on Eclipse
I hope this helps,
Erich
