the selected project does not contain any sdk reference
srihariprasad24
Hi, I have posted the error.
software tool - MCUXpresso IDE
What may be the issue? How to get the sdk reference?
hari
converse
Senior Contributor V
srihariprasad24
Hi, I am using "MKV30F64VLF10" LQFP-48 IC. I couldn't find any SDK for this IC. How to select a SDK to install? or, is there any common SDK builder for MCUXpresso IDE? Thanks, hari
EdwinHz
Yes! You can find the SDK Builder by following this link: https://mcuxpresso.nxp.com/en/select. Here, select your MCU (MKV30F64xxx10), components, platform and IDE, and your SDK will be built and available for download. Once you add it to MCUXpresso, you can create a new project and select the MCU you are using, and the error should be gone.
Edwin.
