plot data with MCUxpresso IDE
ソリューションへジャンプ
3,274件の閲覧回数
gschelotto
Contributor V
How can I plot data when debugging (i.e. data array stored in RAM) with MCUxpresso IDE? If it not possible, how can I dump the data into a CSV file?
regards,
gaston
2,985件の閲覧回数
lpcxpresso_supp
There is no direct functionality to do this. What you could do is, if you work out the memory range that your array occupies (for instance from the map file), you could then save it out from the Memory View...
https://community.nxp.com/message/630631
then process the exported file with external tools.
MCUXpresso IDE Support
2,986件の閲覧回数
lpcxpresso_supp
