lpc18xx: issue with library function
manojkumar_1
We are using LCP1857 device with MCU xpresso IDE v10.0.2 and LCPopen 3.1.
We have a debug framework using vprintf which is not working as expected. Details as below,
void DBG_Print(const char *format, ...)
 va_list args;
 va_start(args, format);
 vprintf(format, args);
 va_end(args);
DBG_Print("Uart debug\r\n);
When  above piece of code build with LPCxpresso 7.7.2 IDE it works it gives output as "Uart debug"
If we are using with MCUxpresso 10.0.2 it just gives the output "U".
