iMXRT1020 EVK Debug SocketException
AlperSefa
I have a 700-29856 Rev.B1 1020 EVK.  I switched SW8 3th pin also. But i cannot debug.
Hui_Ma
First of all, sorry for the later reply.
I only have Rev A RT1020 evaluation board on hand and could not do a onsite test.
Could you help to check if all jumpers setting, especially for J1 (shunt at 5-6)?
Your SW8 setting is correct.
During the project debug entrance phase, if there will showed below debugger was found:
Thank you for the attention.
Mike
