debugging issue
debugging issue
839 次查看
yosri_c
hello NXP ,
we're currently  working on a project using a custom  iMX RT1176 (CM7 master / CM4/ slave)  with the memory map attached below , the issue is when building for release we face no problem , but when we try to run a debugging session , the CM7 loads fine but the slave core wouldn't it through a hardfault
we're not sure wether it's an memory mismatch or a debugger problem or one might suspect a flashing algorithm  issue via PEmicro Multilink for   flash programming
6 回复数
678 次查看
KKR231
Go to project explorer and select project, now go to project setting and select memory and right click on memory and edit it. and in that select flash driver. Screenshot 2024-07-04 144614.png
783 次查看
yosri_c
hi there @HangZhang
Thanks for the update , althought i want to believe it's a problem with debugger or flashing algorithm , i can't because i tried building and debugging with MCUxpresso version  11.6 and both cores loads correctly and i get the debugging interface and the adresses and the entry points , so the boot process is correct like you showed , with IDE v 11.9 i get this
773 次查看
HangZhang
Hi @yosri_c
Do you mean that MCUxpresso version 11.6 can work while MCUxpresso version 11.9 cannot?
Hang
768 次查看
yosri_c
hi @HangZhang
Yes , that's what it looks like happening !
697 次查看
HangZhang
Hi @yosri_c
I'm sorry, I tested MCUxpresso version 11.6 and MCUxpresso version 11.9 on imxrt1170evkb board,
they can work successfully.
I did not reproduce this issue.
Hang
793 次查看
HangZhang
Hi @yosri_c
Compare this image with the picture you sent.
There is no problem with the memory address, so it my be debugger problem or one might suspect a flashing algorithm issue via PEmicro Multilink for flash programming.
Hope this will help you.
Hang
