.axf launching failed
8,687 次查看
Frogram
Hi, all
I am using MCUXpresso IDE with MKV10Z16 (Kinetis V series) via J-LINK(OB V1, https://ko.aliexpress.com/item/1005002956762396.html maybe this product)
when I try to run a project, same error occurs
Whats the problem and how to solve it?
thanks.
8 回复数
5,251 次查看
Dibyendu_nxp
I am facing the same issue @Frogram is already faced . But My launching configuration is right what you recomended
8,178 次查看
ErichStyger
Specialist I
Did you use the 'blue' debug icon?
It seems to me that you tried to launch it as an executable on the host?
I hope this helps,
Erich
8,180 次查看
ptcaos
I have got the same error with a simple project and a FRDM-KL25Z board. I get this message:
"Error starting process.
Cannot run program "C:\Users\3013742\Documents\MCUXpressoIDE_11.5.0_7232\workspace\frdmkl25z_demo_apps_bubble\Debug\frdmkl25z_demo_apps_bubble.axf": Launching failed
Cannot run program "C:\Users\3013742\Documents\MCUXpressoIDE_11.5.0_7232\workspace\frdmkl25z_demo_apps_bubble\Debug\frdmkl25z_demo_apps_bubble.axf": Launching failed"
Help, thanks!!
8,673 次查看
ErichStyger
Specialist I
Your directory separation looks strange: are you using some kind of uni-code path/characters.
Does it work if your project is not on a OneDrive path (local on you disk)?
Can you check/share your launch configuration settings? The path to the binary is specified here:
I hope this helps.
8,631 次查看
Frogram
I tried to move file location to hardware drive, not onedrive
also it's mine
8,621 次查看
ErichStyger
Specialist I
Why is there such strange path separation symbol?
never seen something like that.
It should be a '/' or '\'
8,681 次查看
converse
Senior Contributor V
How did you start the debug session? Did you follow the instructions in the User Manual?
8,678 次查看
Frogram
I just followed which IDE guided
I didn't touched other options
also I don't have any manual fits to my project... It makes more harder
