Run cpplint on filesave
Natendra
1. How to run cpplint alone without adding clangformate.
2. To identify coding guide line failure warning
converse
Senior Contributor V
MCUXpresso IDE is based on Eclipse CDT. Therefore, you should be able to use the CPPStyle login. See
https://codeyarns.com/tech/2015-01-08-how-to-use-cpplint-in-eclipse-cdt.html
ZhangJennie
HI
Please let us know
- your IDE version
- chip PN, thus we can assign this question to the related engineer.
- Does run cpplint on filesave related with MCUXpresso IDE? If yes how?
Jun Zhang
