RT1176 SDK projects - octal/hyper flash support
nickwallis
Senior Contributor I
Am I correct in thinking that all of the SDK example projects are by default configured for XiP operation from serial NOR QSPI flash?
In which case, what changes need to be made to enable operation from octal or hyper flash?
Is selecting a different flash driver (.cfx file) sufficient?
I think a different FDCB configuration in evkmimxrt1170_flexspi_nor_config.c will be needed.
thanks!
_Leo_
Thank you so much for your interest in our products and for using our community.
The application notes AN12107, AN12239 and AN13028 will be very useful.
Hope it helps you.
Have a nice day!
