Question about Hexiwear
1,824 次查看
fabig
I'm trying to use the example projects provided by Hexiwear on their github.
I'm using MCUxpresso 10.2.0 with the Hexiwear SDK. The example projects from the SDK work, the whole project from the Hexiwear Github doesn't work. It's giving me a "Program "-E" not found in PATH" error, so I cannot build it. What is required to fix this?
标签 (1)
1 回复
1,635 次查看
kerryzhou
Hi Fabi G,
   Do you mean the HEXIWEAR code download from this link?
GitHub - MikroElektronika/HEXIWEAR: HEXIWEAR firmware
  The project on this package is using KDS IDE, not the MCUXpresso IDE, so if you use the MCUXpresso IDE, it will have problems.
  Please refer to the HEXIWEAR - Getting started.pdf in folder : HEXIWEAR-master\HEXIWEAR-master\documentation
  You will find the project is based on KDS.
Wish it helps you!
Kerry
