MIMRT170 lwip TCP/IP server and client example
1,750 次查看
gurukiran
I need to do client and server program for MIMRT1170-EVKB board using LWIP TCP/IP Stack and freeRTOS.
Please provide the example for TCP client and TCP server program. As ping is working fine. For that I need to add TCP client and TCP server program.
Thank you,
GuruKiran M B
1,709 次查看
gurukiran
Hi Nxp,
From the nxp community Forum, we got info on how the socket creation works, things to configure for tcp-client.
From that idea , we have coded for both tcp-client and tcp-server and it will be helpful for others to refer while implementing the same.
Tcp-client and server implementation include transmitting the data in the packets and receiving the acknowledgement.
A special thanks to my teammates: Har**bleep**ha R and Niranjan for their support while implementing the same.
PFA attached code for the same.
Gurukiran M B
