LPC55(S)x Cap Bank using MCUXpresso IDE
5,482 次查看
scornelius
Regarding AN13057 and the LCP55S28:
https://www.nxp.com/docs/en/application-note/AN13057.pdf.
When using the MCUXpresso IDE (11.5.1 or 11.6.0) clock tool, how do you set the cap banks for both the 16Mhz and 32 KHz crystals?
Since clock_config.c is generated from the tool, I assume that manually adding the calls to POWER_Xtal32khzCapabankTrim(..) and POWER_Xtal16mhzCapabankTrim(..) is not recommended.
Steve
4 回复数
5,455 次查看
Hello scornelius,
I have checked the clock config tool, yes, it doesn't include this , we only can add by manual.
Alice
5,449 次查看
scornelius
破坏者
Thank you for confirming this.
Do you know if there any schedule for adding this to the clock tool?
Steve
5,430 次查看
Hello scornelius,
I can help to take request ticket to development team, while sorry I'm not sure whether will add it.
Alice
5,425 次查看
scornelius
I appreciate that Alice.
Thank you for your help,
 Steve
