LPC54018 uart issue
LPC54018 uart issue
mail8
I use an LPC54018 baseboard with IoT module on it. My project is based on lpc54018iotmodule_i2c_interrupt_b2b_transfer_master example, and I want to use UART4 (present on Shield connector) additional to that.
So I took the lpc54018iotmodule_usart_interrupt example, changed that to use UART4 and it worked fine.
Next I copied the specific parts or UART4 and copied it to the lpc54018iotmodule_i2c_interrupt_b2b_transfer_master base project.
When I compile my project it gives the following error:
In file included from ../utilities/fsl_debug_console.c:54:
/Users/raymond/MCUXpresso/54018/vb-dcu/component/serial_manager/serial_manager.h:124:2: error: #error SERIAL_PORT_TYPE_UART, SERIAL_PORT_TYPE_USBCDC, SERIAL_PORT_TYPE_SWO and SERIAL_PORT_TYPE_USBCDC_VIRTUAL should not be cleared at same time.
I tried lots of things but I can't get rid of the error.
Somebody please help me?
Hello Raymond Verbruggen,
Please send your project to me, I will help check it on my side, thanks!
Alice
mail8
Hi Alice,
Sorry, this attached zip file does gives errors when compiling.
Could you please check?
Thanks a lot on forehand.
Mit freundlichen Grüßen,
Met vriendelijke groet,
Raymond Verbruggen
FOCUSSING B.V.
Mispel 8
7621 WB Borne
Netherlands
+31 6 250 500 69
[email protected]
www.focussing.nl
Op 16 jul. 2020, om 04:35 heeft Alice_Yang <[email protected]> het volgende geschreven:
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: LPC54018 uart issue
reply from Alice_Yang <https://community.nxp.com/people/Alice_Yang?et=watches.email.thread> in MCUXpresso IDE - View the full discussion <https://community.nxp.com/message/1341168?commentID=1341168&et=watches.email.thread#comment-1341168>
Hello Raymond Verbruggen <https://community.nxp.com/people/[email protected]>,
Alice
Reply to this message by replying to this email, or go to the message on NXP Community <https://community.nxp.com/message/1341168?commentID=1341168&et=watches.email.thread#comment-1341168>
Start a new discussion in MCUXpresso IDE by email <mailto:discussions-community-mcuxpresso-mcuxpresso--ide@mail.freescale.jiveon.com> or at NXP Community <https://community.nxp.com/choose-container.jspa?contentType=1&containerType=14&container=11555&et=watches.email.thread>
Following Re: LPC54018 uart issue <https://community.nxp.com/message/1341168?commentID=1341168&et=watches.email.thread#comment-1341168> in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe <https://community.nxp.com/unsubscribe.jspa?id=339846&token=0a2a2c366ac808a62abc846ab062ff562294db14b676b0c4ace99c5e9fcdb6b8> instantly from NXP Community, or adjust email frequency in your email preferences <https://community.nxp.com/user-preferences!input.jspa>
Hello Raymond,
Because in your project, there are two header files use the same  name "uart.h",
I change one of them to uart_v.h, and pay attention to includes the right header files in serial_port_uart.c and
serial_port_uart.h :
Then build, there is no error.
Hope it helps,
Alice
mail8
It helps???
YESSS YOU ARE TOP!!
How easy it can be.
Thank you very much!!
Best regars,
Raymond
Welcome!
Alice
mail8
Hello Alice,
Thank you that is great!
Please find the project in the attached zip file.
Raymond Verbruggen
FOCUSSING B.V.
Mispel 8
7621 WB Borne
Netherlands
+31 6 250 500 69
[email protected]
www.focussing.nl
Alice
Hello Raymond,
There is no error when compile your project on my side:
Alice
mail8
Hey, I did not get a message that you replied!
I will send you a new zip file which does gives errors by replying on your email.
Thanks on forehand!
Raymond
