LPC4370 SPIFI Flash driver failed to initialize
luizroque
Hi guy, I been trying run my custom board using LPC4370 SPIFI, but I getting stuck with this error, I use S25FL032P. I don't if a need to use the ISP pin, but I cannot use it, because I did not sign him in my layout, and since is a BGA chip, I cannot use it. I'm trying the periph_ssp sample, but I don't if is the code, or my flash or the LPC4370.
I getting this errors
MCUXpresso IDE RedlinkMulti Driver v10.2 (Jul 25 2018 11:29:34 - crt_emu_cm_redlink build 555)
Found chip XML file in /Users/luizroque/Documents/MCUXpressoIDE_10.2.1/esu_workspace/lpcopen_3_02_lpcxpresso_link2_4370/periph_ssp/Debug/LPC4370.xml
Reconnected to existing link server
Connecting to probe 1 core 0:0 (using server started externally) gave 'OK'
Probe Firmware: LPC-Link Probe v1.3 (NXP - LPC-Link)
Serial Number:  WIN64HS12
VID:PID:  1FC9:0009
USB Path:
Using memory from core 0:0 after searching for a good core
debug interface type      = Cortex-M3/4 (DAP DP ID 2BA01477) over SWD TAP 0
processor type            = Cortex-M4 (CPU ID 00000C24) on DAP AP 0
number of h/w breakpoints = 6
number of flash patches   = 2
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 2BA01477. CpuID: 00000C24. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FF000: CID B105100D PID 04000BB4C4 ROM dev (type 0x1)
ROM 1 E000E000: CID B105E00D PID 04000BB00C ChipIP dev SCS (type 0x0)
ROM 1 E0001000: CID B105E00D PID 04003BB002 ChipIP dev DWT (type 0x0)
ROM 1 E0002000: CID B105E00D PID 04002BB003 ChipIP dev FPB (type 0x0)
ROM 1 E0000000: CID B105E00D PID 04003BB001 ChipIP dev ITM (type 0x0)
ROM 1 E0040000: CID B105900D PID 04000BB9A1 CoreSight dev TPIU type 0x11 Trace Sink - TPIU
ROM 1 E0041000: CID B105900D PID 04000BB925 CoreSight dev ETM type 0x13 Trace Source - core
Inspected v.2 External Flash Device on SPI LPC18_43_SPIFI_GENERIC.cfx
Image 'LPC18/43 Generic SPIFI Jul 25 2018 11:29:55'
Opening flash driver LPC18_43_SPIFI_GENERIC.cfx
Sending VECTRESET to run flash driver
There was a problem after we succesfully downloaded flash driver code to the target, so we are going to compare the flash driver code with the memory where it was loaded.
Note that, after driver initialization, some difference is normal in 'generic' drivers.
Driver from AXF file:
10000000: 23010020 54000045 00001032 10000000     ..#E..T2.......
10000010: 000022cc 10081000 00008000 10081000    ."..............
10000020: 00001000 00000040 1000225c 10000035    ....@...\"..5...
10000030: 00000000 b6720004 f852f000 00062700    ......r...R..'..
10000040: 61676020 8f5ff3bf 2d006965 6127d0fa     `ga.._.ei.-..'a
10000050: d0082e00 60262340 23806123 005b6167    ....@#&`#a.#ga[.
10000060: d1ef429d 2308e7fe d00a421d 68e16860    .B.....#.B..`h.h
10000070: f8e4f000 60202300 d0ed2800 43132201    .....# `.(...".C
10000080: 06ebe7ea 4b14d507 d1012b00 e7f12000    .......K.+... ..
10000090: f8c0f000 2342e7ee d012421d d40807ab    ......B#.B......
100000A0: 2b004b0e 6860d0f2 68a268e1 f90cf000    .K.+..`h.h.h....
100000B0: 6860e7e0 68a268e1 f8ecf000 d0ef2800    ..`h.h.h.....(..
100000C0: 23c0e7d8 421d005b f000d002 e7ddf899    ...#[..B........
100000D0: 23020028 46c0e7cf 10000215 100002c9    (..#...F........
100000E0: f001b570 4b3cfb4b f103483c 781d0118    p...K.<K<H.....x
100000F0: 885c785a eb023304 428b1245 4022f840    Zx\..3..E..B@."@
10000100: 2009d1f5 f99cf001 21094a35 f2f2fbb0    ... ....5J.!....
10000110: 32014605 f0012004 2300f965 21102201    .F.2. ..e..#.".!
10000120: f0012005 2101fabd f000482e 482ef9b5    . .....!.H.....H
10000130: f996f000 f000482b 2800fa7d f04fd047    ....+H..}..(G.O.
10000140: 4a2853a0 48292154 fa88f000 60204c28    .S(JT!)H....(L `
10000150: 28004626 2108d03d f9b2f000 f2f0fbb5    &F.(=..!........
10000160: 32012109 f0012004 2200f93d 46116820    .!.2. ..=.." h.F
10000170: 681b6803 bb484798 210f4602 f0006820    .h.h.GH..F.! h..
10000180: bb18fac7 68202101 f99af000 21034c19    .....! h.....L.!
10000190: 683064a0 f994f000 4f80f5b0 f44fbf28    .d0h.......O(.O.
100001A0: 4a154380 64e3bf28 66204b14 64e0bf38    .C.J(..d.K f8..d
100001B0: 601c6113 68302400 68422101 68126a12    .a.`.$0h.!Bh.j.h
100001C0: 4402e9c3 f000605a 4620f9e9 200dbd70    ...DZ`.... Fp..
100001D0: 2002e7fc bf00e7fa 100017c2 40086000    ... .........`.@
100001E0: 000f4240 40003000 100010b1 1000206c    @[email protected] ..
100001F0: 100020c0 1000225c 10089000 1000224c    . ..\"......L"..
10000200: 4b03b508 f0006818 2000fa09 bf00bd08    ...K.h..... ....
10000210: 100020c0 4c08b538 68202100 f9bef000    . ..8..L.! h....
10000220: 68036820 4798685b b9184605 68202101     h.h[h.G.F...! h
10000230: f9b4f000 bd384628 100020c0 460cb5f8    ....(F8.. .....F
10000240: 46054e12 2054f896 04136e31 2302ea43    .N.F..T 1n..C..#
10000250: 08894313 6202ea43 f0004361 b178f853    .C..C..baC..S.x.
10000260: 21004f0b f0006838 6e32f999 fb023c01    .O.!8h....2n.<..
10000270: 46295204 f0006838 4604fac8 4620b108    .R)F8h.....F.. F
10000280: 2101bdf8 f0006838 e7f8f989 1000225c    ...!8h......\"..
10000290: 100020c0 4605b5f8 4616460f 21004c09    . .....F.F.F.L.!
100002A0: f0006820 4629f97b 4632463b f0006820     h..{.)F;F2F h..
100002B0: 4605fa79 2101b918 f0006820 4628f96f    y..F...! h..o.(F
100002C0: bf00bdf8 100020c0 b5704b0d 460d6c5e    ..... ...Kp.^l.F
100002D0: 46144286 221cd111 f0014621 b108fa51    .B.F..."!F..Q...
100002E0: bd70200a 0220f1a5 0120f104 0020f106    . p... ... ... .
100002F0: fa46f001 d0f42800 460ae7f2 e7f74621    ..F..(.....F!F..
10000300: 1000225c 4ff0e92d 0ff0e8b0 d1124294    \"..-..O.....B..
10000310: d1104295 d10e4296 d10c4297 d10a4590    .B...B...B...E..
10000320: d1084591 d1064592 d1044593 d1eb3908    .E...E...E...9..
10000330: e8bd2000 20018ff0 8ff0e8bd 310478ca    . ..... .....x.1
10000340: f0431cd3 f443431f 60431300 f8017d03    ..C..CC...C`.}..
10000350: 7d033c04 3c03f801 f8017d03 440a3c02    .<.}...<.}...<.D
10000360: d1034291 079b69c3 4770d4fc f8017d03    .B...i....pG.}..
10000370: e7f53b01 b5f02300 b0874605 3003f88d    .;...#...F.....0
10000380: 300ff88d 460e680b 4b34691c 2c004669    ...0.h.F.i4KiF.,
10000390: 461cbf08 466947a0 47a04628 4628a903    ...F.GiF(F.G..(F
100003A0: f89d47a0 f89d1000 428b300c f89dd10b    .G.......0.B....
100003B0: f89d7001 42bb300d f89dd105 f89d2002    .p...0.B..... ..
100003C0: 4293300e 2000d002 bdf0b007 685b6833    .0.B... ....3h[h
100003D0: 28006858 6803d0f7 c004f893 d107458c    Xh.(...h.....E..
100003E0: c005f893 d10345bc c006f893 d0034594    .....E.......E..
100003F0: e7ee6840 e0126840 2b0079db 4628d0e4    @[email protected].+..(F
10000400: 3003f88d 47a04669 f89d6833 685b4000    ...0iF.G3h...@[h
10000410: 5001f89d f89d6858 f89d6002 28001003    ...PXh...`.....(
10000420: 6803d0d1 42a2791a 795ad1e4 d1e142aa    ...h.y.B..Zy.B..
10000430: 42b2799a 79dad1de d1db4291 d0c32900    .y.B...y.B...)..
10000440: 33082200 d2bf428a 0c02eb0d 7b01f813    .".3.B.........{
10000450: c004f89c d1cd45bc e7f33201 1000033d    .....E...2..=...
10000460: 4780b508 4b04b138 6058685a 4a036042    ...G8..KZhX`B`.J
10000470: 33016813 bd086013 100020c8 100020c4    .h.3.`... ... ..
10000480: 685a6803 60486850 68da6051 68132000    .hZhPhH`Q`.h. .h
10000490: 60133301 00004770 2310b171 69c361c3    .3.`pG..q..#.a.i
100004A0: 0310f013 60c3d1fb 23106183 69c361c3    .......`.a.#.a.i
100004B0: d4fc06db 60034b01 47702000 600f03e8    .....K.`. pG...`
100004C0: 6843b911 47706858 d1042901 e9d36843    ..ChXhpG.)..Ch..
100004D0: 43502002 29024770 6843d102 47706898    . PCpG.)..Ch.hpG
100004E0: d1022903 68d86843 29044770 6843d102    .)..Ch.hpG.)..Ch
100004F0: 47706918 d1022905 69586843 29064770    .ipG.)..ChXipG.)
10000500: 6843d102 47706998 d1022907 69d86843    ..Ch.ipG.)..Ch.i
10000510: 29084770 6843d106 f8936a1b 481b3028    pG.)..Ch.j..(0.H
10000520: 47704358 d1042909 6a1b6843 3029f893    XCpG.)..Ch.j..)0
10000530: 290ae7f5 6843d104 f8936a1b e7ee302a    ...)..Ch.j..*0..
10000540: d104290b 6a1b6843 302bf893 290ce7e7    .)..Ch.j..+0...)
10000550: 6843d104 f8936a1b e7e0302c d102290d    ..Ch.j..,0...)..
10000560: 6a1b6843 290ee7c4 2101d103 69db6803    Ch.j...)...!.h.i
10000570: 290f4718 6803d103 69db2100 2910e7f8    .G.)...h.!.i...)
10000580: 6843bf06 20006a58 bf004770 000f4240    ..ChXj. pG..@B..
10000590: 681b6843 f00069d8 47700001 b5372310    Ch.h.i....pG.#7.
100005A0: 68146842 69e361e3 d4fc06dd 06db69e3    Bh.h.a.i.....i..
100005B0: 6a52d4fc 07556823 f023d513 60235380    ..Rj#hU...#..S#`
100005C0: 6803b1a1 6b9d466a 47a8ab01 60e39b01    ...hjF.k...G...`
100005D0: 60639b00 079169e2 61a3d4fc b0032000    ..c`.i.....a. ..
100005E0: 07d5bd30 f043bf48 e7e85380 60e323ff    0...H.C..S...#.`
100005F0: 61a12310 69e361e3 d4fc06da 06db69e3    .#.a.a.i.....i..
10000600: e7ebd4fc 4604b510 21016803 47986a5b    .......F.h.![j.G
10000610: 46202100 ffc2f7ff bd102000 4604b510    .! F..... .....F
10000620: 21006803 47986a5b 46202101 ffb6f7ff    .h.![j.G.! F....
10000630: bd102000 4605b538 685c4b07 4620b90c    . ..8..F.K\h.. F
10000640: 4621bd38 f7ff4628 b908fe95 e7f56864    8.!F(F......dh..
10000650: 68986823 e7f33040 100020c8 43f8e92d    #h.h@0... ..-..C
10000660: 07834699 460e4604 46074690 2400d003    .F...F.F.F.F...$
10000670: e8bd4620 4b2583f8 2d00685d 4629d0f7     F....%K]h.-..)F
10000680: f7ff4640 2800fe77 686dd138 f807e7f5    @F..w..(8.mh....
10000690: 42be3b01 6801d1fb 030cf104 1d0b6063    .;.B...h....c`..
100006A0: f10463e3 e9c40340 8a8b3802 9010f8c4    [email protected]......
100006B0: 698b6163 61a3464a 46208b8b 8bcb61e3    ca.iJF.a.. F.a..
100006C0: 8c0b6223 6a4b6263 310ae9c4 4641680b    #b..cbKj...1.hAF
100006D0: 682b6363 4798695b f8846865 f8950038    cc+h[i.Geh..8...
100006E0: 2b00302c 4620d1c3 ff8cf7ff f8856863    ,0.+.. F....ch..
100006F0: f893002c 2b00302c e7b8d0ba 6899682b    ,...,0.+....+h.h
10000700: 428e3140 4426d3b3 e7c22300 100020c8    @1.B..&D.#... ..
10000710: 41f0e92d f011460c 4606010f d02d4617    -..A.F.....F.F-.
10000720: ff36f7ff 46806872 6a536a10 f0236900    ..6.rh.F.jSj.i#.
10000730: 6253030f b10f4001 6253430b 463a6833    [email protected]:F
10000740: 46306b5b 46414798 46304605 040ff024    [k0F.GAF.F0F$...
10000750: ff24f7ff 6a136872 ea34691b d1120303    ..$.rh.j.i4.....
10000760: b16f6a53 62534323 6b5d6833 463ab15d    Sjo.#CSb3h]k].:F
10000770: 46304621 e8bd462b 471841f0 e7e92503    !F0F+F...A.G.%..
10000780: 0304ea23 4628e7ef 81f0e8bd 68586843    #.....(F....ChXh
10000790: 68d91a08 fbb0689b 4283f0f1 f04fbf98    ...h.h.....B..O.
100007A0: 477030ff 43f8e92d 460f4606 461d4690    .0pG-..C.F.F.F.F
100007B0: b1052000 e8bdb108 687383f8 699c4642    . ........shBF.i
100007C0: 42ac6833 462cbf28 9010f8d3 46234639    3h.B(.,F....9F#F
100007D0: 47c84630 0303f024 44984427 e7e81b2d    0F.G$...'D.D-...
100007E0: b5706843 188e689b 4605429e d908460c    Chp..h...B.F.F..
100007F0: e009200b 4621682b 4628689b b9184798    . ..+h!F.h(F.G..
10000800: 42a63401 2000d1f6 b538bd70 f7ff4605    .4.B... p.8..F..
10000810: 4604ffbd 46284611 ffb8f7ff d0091c62    ...F.F(F....b...
10000820: d0071c43 1b121c42 46284621 4038e8bd    C...B...!F(F..8@
10000830: bfd6f7ff bd38200b 079b69c3 4770d4fc    ..... 8..i....pG
10000840: 62c4f04f f7ff6042 b510bff7 68234604    O..bB`.......F#h
10000850: 6adb4620 07c34798 bd10d4f9 b5706803     F.j.G.......hp.
10000860: 460e6adb 46154604 23014798 f106fa03    .j.F.F.F.G.#....
10000870: 4301b135 46206823 4070e8bd 47186b1b    5..C#h [email protected]
10000880: 0101ea20 b508e7f6 6adb6803 f0104798     ........h.j.G..
10000890: bf0c0f1c 0001f000 bd082005 6843b508    ......... ....Ch
100008A0: 4b0c6819 604b4608 b2d27d0a ffc4f7ff    .h.K.FK`.}......
100008B0: 604b4b09 ea427d0b f7ff2203 0691ffbd    .KK`.}B.."......
100008C0: f042bf48 06537200 f042bf48 f0227280    H.B..rS.H.B..r".
100008D0: bd080060 05200001 35200001 46112200    `..... ... 5.".F
100008E0: b5706843 4e09681c 5d934d09 ea4500d0    Chp..h.N.M.]..E.
100008F0: 60636303 40837d23 43194620 ff9cf7ff    .cc`#}.@ F.C....
10000900: 2a033201 4608d1f1 bf00bd70 10001e98    .2.*...Fp.......
10000910: 00200001 46112200 b5706843 4e09681c    .. ..".FChp..h.N
10000920: 5d934d09 ea4500d0 60636303 40837d23    .M.]..E..cc`#}.@
10000930: 43194620 ff80f7ff 2a033201 4608d1f1     F.C.....2.*...F
10000940: bf00bd70 10001e9b 00200001 6843b508    p......... ...Ch
10000950: 4b046818 7d026043 f7ffb2d2 4610ff6d    .h.KC`.}....m..F
10000960: bf00bd08 05200001 6843b508 4b08681a    ...... ...Ch.h.K
10000970: 60534610 b2c97d11 ff5ef7ff 60534b05    .FS`.}....^..KS`
10000980: ea417d13 f7ff2103 4608ff57 bf00bd08    .}A..!..W..F....
10000990: 05200001 35200001 00004770 68186843    .. ... 5pG..Ch.h
100009A0: 60434b01 bf48f7ff 30200000 6843b538    .KC`..H... 08.Ch
100009B0: 681c4605 f7ff4620 4b07ff43 b2cb6063    .F.h F..C..Kc`..
100009C0: 2107f3c1 75217523 ff36f7ff e8bd4628    ...!#u!u..6.(F..
100009D0: f7ff4038 bf00bf3a 01208002 6843b538    8@..:..... .8.Ch
100009E0: 681c4605 f7ff4620 4b08ff2b b2cb6063    .F.h F..+..Kc`..
100009F0: f3c17523 f3c12307 75234107 f7ff7521    #u...#...A#u!u..
10000A00: 4628ff1b 4038e8bd bf1ff7ff 01208003    ..(F..8@...... .
10000A10: 6843b538 681c4605 f7ff4620 4b05ff11    8.Ch.F.h F.....K
10000A20: 6063b2c9 f7ff7521 4628ff07 4038e8bd    ..c`!u....(F..8@
10000A30: bf0bf7ff 01208001 43f8e92d 46066843    ...... .-..CCh.F
10000A40: 460f681d f7ff4628 2400fefb 9034f8df    .h.F(F.....$..4.
10000A50: 8034f8df f7ff4628 f814fef3 ea483009    ..4.(F.......0H.
10000A60: 606b6303 fa2700e3 b2dbf303 f7ff752b    .ck`..'.....+u..
10000A70: 3401fee3 f7ff4630 2c03fee8 e8bdd1ea    ...40F.....,....
10000A80: bf0083f8 10001e9e 00208001 0f0cf011    .......... .....
10000A90: d003b508 2106b2d2 fee0f7ff bd082000    .......!..... ..
10000AA0: 47702000 0f0cf011 d003b508 2109b2d2    . pG...........!
10000AB0: fed4f7ff bd082000 0f0cf011 d018b510    ..... ..........
10000AC0: b2d26843 2109681c fec8f7ff f7ff4620    Ch...h.!.... F..
10000AD0: f04ffeb3 606363c4 feaef7ff 60634b06    ..O..cc`.....Kc`
10000AE0: 752323ab fea8f7ff 60634b04 f7ff7d23    .##u.....Kc`#}..
10000AF0: 2000fea3 bf00bd10 81208001 85200001    ... ...... ... .
10000B00: 47702000 4604b510 6803b141 47986adb    . pG...FA..h.j.G
10000B10: f4206823 6b1b2170 47984620 bd102000    #h .p!.k F.G. ..
10000B20: 4604b510 6803b141 47986adb f4206823    ...FA..h.j.G#h .
10000B30: 6b1b4180 47984620 bd102000 4604b510    .A.k F.G. .....F
10000B40: 6803b139 47986adb 3100f440 f7ff4620    [email protected] F..
10000B50: 2000ff45 0000bd10 21ffb10b 68436019    E.. .......!.`Ch
10000B60: 07596a5b 4b04d502 47706013 bf4c07db    [jY....K.`pG..L.
10000B70: 4b034b02 bf00e7f8 eb930000 bb910000    .K.K............
10000B80: 0b810000 21ffb10b 68436019 075b6a5b    .......!.`Ch[j[.
10000B90: 4b02bf4c 60134b02 bf004770 eb950000    L..K.K.`pG......
10000BA0: 0b810000 21ffb10b 68436019 07596a5b    .......!.`Ch[jY.
10000BB0: 4b04d502 47706013 bf4c07db 4b034b02    ...K.`pG..L..K.K
10000BC0: bf00e7f8 ecb30000 bcb10000 0ca10000    ................
10000BD0: 6a5b6843 bf4c071b 4b024b01 4770600b    Ch[j..L..K.K.`pG
10000BE0: 32888000 02808000 6a5b6843 bf4c071b    ...2....Ch[j..L.
10000BF0: 4b024b01 4770600b 34a88000 12a08000    .K.K.`pG...4....
10000C00: 6a5b6843 bf4c071b 4b024b01 4770600b    Ch[j..L..K.K.`pG
10000C10: 38908000 02808000 b5f8e7fe 46066803    ...8.........h.F
10000C20: 460f6adb f0104798 46057440 f010d00c    [email protected]....
10000C30: bf187480 01822410 f044bf48 b11f0420    .t...$..H.D. ...
10000C40: 46306833 47986a9b 031cf015 2b1cd005    3h0F.j.G.......+
10000C50: f044bf0c f0440404 07eb0408 f044bf48    ..D...D.....H.D.
10000C60: 46200401 2901bdf8 4604b538 d815460d    .. F...)8..F.F..
10000C70: 6adb6803 f0004798 b945031c 6823b12b    .h.j.G....E.+.#h
10000C80: 011cf020 46206b1b 20004798 2b1ce007     ....k F.G. ...+
10000C90: 6823d0fb 011cf040 e7f46b1b bd382003    ..#[email protected]... 8.
10000CA0: b5706843 681c4606 fdedf7ff b9484605    Chp..F.h.....FH.
10000CB0: f7ff4620 4b04fdc5 f7ff6063 4630fdbd     F.....Kc`....0F
10000CC0: fdc3f7ff bd704628 c7200000 e92d6843    ....(Fp... .Ch-.
10000CD0: 689a41f0 428a4604 d92d4688 f7ff681e    .A.h.F.B.F-..h..
10000CE0: 4605fdd2 6863bb28 68df4620 fb076823    ...F(.ch F.h#h..
10000CF0: 6a9bf708 46304798 fda2f7ff 60b76863    ...j.G0F....ch.`
10000D00: 691b6a1b bf4c061b 4b0d4b0c f7ff6073    .j.i..L..K.Ks`..
10000D10: 6863fd93 f4166a5e d10a3680 f7ff4620    ..ch^j...6.. F..
10000D20: 4631fd94 f7ff4620 f010ff78 bf180f20    ..1F F..x... ...
10000D30: 46282507 81f0e8bd e7fa250b dca00000    .%(F.....%......
10000D40: d8800000 47f3e92d 6843461c 699a4617    ....-..G.FCh.F.i
10000D50: 42a24605 d34e4689 f7ff681e 4680fd94    .F.B.FN..h.....F
10000D60: 682bb9d8 6bdba901 47984628 d02907a3    ..+h...k(F.G..).
10000D70: 4628682b 47986a9b f7ff4630 9b01fd61    +h(F.j.G0F..a...
10000D80: 9008f8c6 60734323 f817443c 42a73b01    ....#Cs`<D...;.B
10000D90: d1fa7533 f7ff4630 686bfd4f f4146a5c    3u..0F..O.kh\j..
10000DA0: d10b3480 f7ff4628 4621fd50 f7ff4628    .4..(F..P.!F(F..
10000DB0: f010ff34 bf180f10 0806f04f b0024640    4.......O...@F..
10000DC0: 87f0e8bd 0a94ea5f 9b01d0e7 0403f024    ...._.......$...
10000DD0: 682b431c 6a9b4628 46304798 fd30f7ff    .C+h(F.j.G0F..0.
10000DE0: 0a8aeb07 9008f8c6 f8576074 45573b04    ........t`W..;WE
10000DF0: d1fa6173 f04fe7ce e7df0809 47f3e92d    sa....O.....-..G
10000E00: 6843461f 681d4688 461669db d33642bb    .FCh.F.h.i.F.B6.
10000E10: ea4f6803 f8d30997 2300a038 4619aa01    .hO.....8..#...F
10000E20: 0403f007 f1b947d0 d0130f00 9b0122ff    .....G......."..
10000E30: 0703f027 60ea433b 0989eb06 8008f8c5    '...;C.`........
10000E40: 606b44b8 f846696b 454e3b04 4628d1fa    .Dk`kiF..;NE..(F
10000E50: fcf2f7ff 22ffb1ac 60ea9b01 f8c54323    ......."...`#C..
10000E60: 44348008 7d2b606b 3b01f806 d1fa42b4    ..4Dk`+}...;.B..
10000E70: f7ff4628 2000fce1 e8bdb002 200b87f0    (F..... .......
10000E80: 4620e7fa 2003e7f8 00004770 4a4d4b4c    .. F... pG..LKMJ
10000E90: 601ab530 605a4a4c 609a4a4c 60da4a4c    0..`LJZ`LJ.`LJ.`
10000EA0: 611a4a4c 615a4a4c 619a4a4c 61da4a4c    LJ.aLJZaLJ.aLJ.a
10000EB0: 621a2200 6a126842 402df892 d05a2c01    .".bBh.j..-@.,Z.
10000EC0: d05a2c02 d05a2c03 4d474946 bf182c00    .,Z..,Z.FIGM.,..
10000ED0: f8924629 6259402e d0522c05 4d424943    )F...@Yb.,R.CIBM
10000EE0: bf182c04 f8924629 6299402f d04a2c06    .,..)F../@.b.,J.
10000EF0: d04a2c07 d04a2c08 d04a2c09 4d3a493c    .,J..,J..,J.<I:M
10000F00: bf182c0a f8924629 62d94030 d0422c0b    .,..)[email protected].,B.
10000F10: d0422c0c d0422c0d 4d334936 bf182c0e    .,B..,B.6I3M.,..
10000F20: 63194629 4031f892 d03a2c0f d03a2c10    )F.c..1@.,:..,:.
10000F30: d03a2c11 4d2c4930 bf182c12 63594629    .,:.0I,M.,..)FYc
10000F40: 4032f892 d0322c13 d0322c14 4d26492b    ..2@.,2..,2.+I&M
10000F50: bf182c15 63994629 1033f892 d02a2916    .,..)F.c..3..)*.
10000F60: d02a2917 4c204a26 bf182918 63da4622    .)*.&J L.).."F.c
10000F70: 20006003 4923bd30 4923e7ab 4923e7a9    .`. 0.#I..#I..#I
10000F80: 4923e7a7 4923e7af 4923e7bd 4923e7bb    ..#I..#I..#I..#I
10000F90: 4923e7b9 4923e7b7 4923e7c3 4923e7c1    ..#I..#I..#I..#I
10000FA0: 4923e7bf 4923e7cb 4923e7c9 4923e7c7    ..#I..#I..#I..#I
10000FB0: 4923e7d1 4a23e7cf 4a23e7d9 bf00e7d7    ..#I..#J..#J....
10000FC0: 10002204 10000c67 10000ca1 10000ccd    ."..g...........
10000FD0: 1000104d 10000d45 10000dfd 10000e87    M...E...........
10000FE0: 10000c1b 10000b01 10000c19 10000999    ................
10000FF0: 100008dd 10000a39 10000aa1 10000ba5    ....9...........
10001000: 10000c01 10000b05 10000b21 10000b3d    ........!...=...
10001010: 1000099d 1000089d 10000915 1000094d    ............M...
10001020: 10000969 100009ad 100009dd 10000a11    i...............
10001030: 10000ab9 10000aa5 10000a8d 10000b59    ............Y...
10001040: 10000b85 10000bd1 10000be9 e92d6843    ............Ch-.
10001050: 691a41f0 428a4604 d9274688 f7ff681e    .A.i.F.B.F'..h..
10001060: 4605fc12 6863b9f8 695f4620 fb076823    ...F..ch F_i#h..
10001070: 6a9bf708 46304798 fbe2f7ff 5302f04f    ...j.G0F....O..S
10001080: 607360b7 fbd8f7ff 6a5b6863 d40a03db    .`s`....ch[j....
10001090: f7ff4620 4629fbda f7ff4620 f010fdbe     F....)F F......
100010A0: bf180f20 46282507 81f0e8bd e7fa250b     ....%(F.....%..
100010B0: b510496e 2a00680a 80d5f040 486d4b6c    nI...h.*@...lKmH
100010C0: e9c34c6d e9c32102 60424000 611a4c6b    mL...!...@B`kL.a
100010D0: 496c4a6b 6023615a 46204b6b f7ff600b    kJlIZa#`kK F.`..
100010E0: 496af9cf 46204b6a f7ff600b 4969f9c9    ..jIjK F.`....iI
100010F0: 46204b69 f7ff600b 4968f9c3 46204b68    iK F.`....hIhK F
10001100: f7ff600b 4967f9bd 46204b67 f7ff600b    .`....gIgK F.`..
10001110: 4966f9b7 46204b66 f7ff600b 4965f9b1    ..fIfK F.`....eI
10001120: 46204b65 f7ff600b 4964f9ab 46204b64    eK F.`....dIdK F
10001130: f7ff600b 4963f9a5 46204b63 f7ff600b    .`....cIcK F.`..
10001140: 4962f99f 46204b62 f7ff600b 4961f999    ..bIbK F.`....aI
10001150: 46204b61 f7ff600b 4960f993 46204b60    aK F.`....`I`K F
10001160: f7ff600b 495ff98d 46204b5f f7ff600b    .`...._I_K F.`..
10001170: 495ef987 46204b5e f7ff600b 495df981    ..^I^K F.`....]I
10001180: 46204b5d f7ff600b 495cf97b 46204b5c    ]K F.`..{.\I\K F
10001190: f7ff600b 495bf975 46204b5b f7ff600b    .`..u.[I[K F.`..
100011A0: 495af96f 46204b5a f7ff600b 4959f969    o.ZIZK F.`..i.YI
100011B0: 46204b59 f7ff600b 4958f963 46204b58    YK F.`..c.XIXK F
100011C0: f7ff600b 4957f95d 46204b57 f7ff600b    .`..].WIWK F.`..
100011D0: 4956f957 46204b56 f7ff600b 4955f951    W.VIVK F.`..Q.UI
100011E0: 46204b55 f7ff600b 4954f94b 46204b54    UK F.`..K.TITK F
100011F0: f7ff600b 4953f945 46204b53 f7ff600b    .`..E.SISK F.`..
10001200: 4952f93f 46204b52 f7ff600b 4951f939    ?.RIRK F.`..9.QI
10001210: 46204b51 f7ff600b 4950f933 46204b50    QK F.`..3.PIPK F
10001220: f7ff600b 494ff92d 46204b4f f7ff600b    .`..-.OIOK F.`..
10001230: 494ef927 46204b4e f7ff600b 494df921    '.NINK F.`..!.MI
10001240: 46204b4d f7ff600b 494cf91b 46204b4c    MK F.`....LILK F
10001250: f7ff600b 494bf915 46204b4b f7ff600b    .`....KIKK F.`..
10001260: 4620f90f 2000bd10 bf00e7fc 100021d8    .. F... .....!..
10001270: 100021ec 100021e4 10001ea1 100021dc    .!...!.......!..
10001280: 10000e8d 100020d0 100017e4 100020d8    ..... ....... ..
10001290: 10001818 100020e0 1000184c 100020e8    ..... ..L.... ..
100012A0: 10001880 100020f0 100018b4 100020f8    ..... ....... ..
100012B0: 100018e8 10002100 1000191c 10002108    .....!.......!..
100012C0: 10001950 10002110 10001984 10002118    P....!.......!..
100012D0: 100019b8 10002120 100019ec 10002128    .... !......(!..
100012E0: 10001a20 10002130 10001a54 10002138     ...0!..T...8!..
100012F0: 10001a88 10002140 10001abc 10002148    ....@!......H!..
10001300: 10001af0 10002150 10001b24 10002158    ....P!..$...X!..
10001310: 10001b58 10002160 10001b8c 10002168    X...`!......h!..
10001320: 10001bc0 10002170 10001bf4 10002178    ....p!......x!..
10001330: 10001c28 10002180 10001c5c 10002188    (....!..\....!..
10001340: 10001c90 10002190 10001cc4 10002198    .....!.......!..
10001350: 10001cf8 100021a0 10001d2c 100021a8    .....!..,....!..
10001360: 10001d60 100021b0 10001d94 100021b8    `....!.......!..
10001370: 10001dc8 100021c0 10001dfc 100021c8    .....!.......!..
10001380: 10001e30 100021d0 10001e64 737af44f    0....!..d...O.zs
10001390: 9301b082 699a4b0c f0226998 42880102    .....K.i.i"....B
100013A0: bf18480a 68006199 f0224909 42880203    .H...a.h.I"....B
100013B0: f042bf88 619a0204 1e5a9b01 2b009201    ..B....a..Z....+
100013C0: b002d1fa bf004770 40050000 100017e0    ....pG.....@....
100013D0: 01312cff 6c534a02 0301f043 47706453    .,1..JSlC...SdpG
100013E0: 40050000 f1030083 f5034380 291123a0    [email protected]...#.)
100013F0: 6c9cb510 3a01d00f ea410609 4a080182    ...l...:..A....J
10001400: 6100f441 4a075c10 0280ea42 0402ea24    A..a.\.JB...$...
10001410: 64994321 f044bd10 649c0401 bf00e7fa    !C.d..D....d....
10001420: 1000202a 1f000001 30124b04 0020f853    * .......K.0S. .
10001430: bf5407c3 6004f3c0 47702011 40050000    ..T....`. pG...@
10001440: d83b2810 f000e8df 180e0c09 28263a23    .(;.........#:&(
10001450: 3a3a2d2a 3634322f f44f0038 47704000    *-::/2468.O..@pG
10001460: 47704817 48184b17 312cf8d3 0307f003    .HpG.K.H..,1....
10001470: bf082b04 47702000 4a144b12 312cf8d3    .+... pG.K.J..,1
10001480: f0034811 2b040307 4610bf08 4b104770    .H.....+...FpG.K
10001490: 47706818 e7fb4b0f e7f94b0f 68584b0e    .hpG.K...K...KXh
100014A0: f0004770 2000b8b7 b8e2f000 e7fb2001    pG..... ..... ..
100014B0: e7f92002 e7f72003 e7f52004 47702000    . ... ... ... pG
100014C0: 00b71b00 40043000 017d7840 02faf080    .....0.@@x}.....
100014D0: 100017dc 100017e0 10002244 b5f723fa    ........D"...#..
100014E0: 4605460c f7ff9301 4b1affab 6c5b4360    .F.F.......K`C[l
100014F0: f0233c01 ea4353f8 4b176205 4a174013    .<#[email protected]
10001500: d8194290 21002501 fb070047 4296f605    .B...%.!G......B
10001510: ea43d90f f0434304 ea430340 4a0d2301    [email protected]..#.J
10001520: 0301f023 9b016453 92011e5a d1fa2b00    #...Sd..Z....+..
10001530: 3101e00d e7e8006d 42904a09 ea43d804    ...1m....J.B..C.
10001540: f0434304 e7ea03c0 ff44f7ff b0032000    .CC.......D.. ..
10001550: bf00bdf0 40050000 ff00cc3d 094c5eff    .......@=....^L.
10001560: 1312cfff 43f8e92d 46064691 4698460f    ....-..C.F.F.F.F
10001570: ff66f7ff 3ffff1b9 fbb9d02e fb01f1f0    ..f....?........
10001580: 42a7f400 4b21d817 d814429c bf2c45a0    ...B..!K.B...E,.
10001590: 25004625 42a74404 0301f101 4a1bd81a    %F.%.D.B.......J
100015A0: d8174294 d31545a0 b94cb13d e8bd4630    .B...E..=.L.0F..
100015B0: f7ff43f8 2500bf93 b16ce7ec e7f54619    .C.....%..l..F..
100015C0: 0505eba9 0409eba4 d9f742a5 b1cae7ee    .........B......
100015D0: e7eb4611 d1e92d00 f4f0fbb7 f3f0fbb8    .F...-..........
100015E0: fb042200 490af500 d30642bd d8044545    .".....I.B..EE..
100015F0: 3cfff105 bf98458c 429c4622 d2e64405    ...<.E.."F.B.D..
10001600: e7f13401 e8bd4610 bf0083f8 0aba9500    .4...F..........
10001610: 0aba94ff 4d14b537 f3c46c6c f7ff6003    ....7..Mll...`..
10001620: 4b12ff0f 6c2b9301 0301f013 f3c4d019    ...K..+l........
10001630: a9022301 f813440b f3c41c04 33013301    .#...D.......3.3
10001640: f0f3fbb0 f3c409a3 ea434207 07e314d4    .........BC.....
10001650: 0201f102 004bbf5c f2f3fbb2 b0034350    ....\.K.....PC..
10001660: 4618bd30 bf00e7fb 40050000 08040201    0..F.......@....
10001670: 4604b538 fed8f7ff f1044b07 f8530212    8..F.....K....S.
10001680: f7ff5022 4b05fedd ea035d1b 33010395    "P.....K.].....3
10001690: f0f3fbb0 bf00bd38 40050000 1000202a    ....8......@* ..
100016A0: 0084b530 4480f104 24a0f504 6de5281b    0......D...$.(.m
100016B0: 2911d80d 4808d00a b10a4028 6000f440    ...)...H(@..@..`
100016C0: f040b10b ea400001 65e06001 f045bd30    ..@...@..`.e0.E.
100016D0: 65e50501 bf00e7fa e0fff7fe 63faf44f    ...e........O..c
100016E0: 2806b573 460d4604 93014616 f7ffd101    s..(.F.F.F......
100016F0: 2300fe4d 46212201 f7ff2004 4b17ffd1    M..#."!F. .....K
10001700: d90a429d 4916461a f7ff4620 2300ff2b    .B...F.I F..+..#
10001710: 21092201 f7ff2004 9b01ffc3 92011e5a    .".!. ......Z...
10001720: d1fa2b00 462b490f 6809462a f7ff4620    .+...I+F*F.h F..
10001730: b12eff19 f1044c0c 34040540 d10142ac    [email protected]..
10001740: bd70b002 3c01f814 2c02f814 1c03f814    ..p....<...,....
10001750: 0c04f814 ffa4f7ff bf00e7ef 068e7780    .............w..
10001760: 00b71b00 100017e0 10002030 49022201    ........0 ...".I
10001770: f7ff4610 bf00bfb3 0aba9500 bff6f7ff    .F..............
10001780: 0301ea40 b570079b 4604d10c 2a03460b    @.....p....F.F.*
10001790: 46204619 6806d906 3404680d f10342ae    .F F...h.h.4.B..
100017A0: d0040304 4291440a 2000d103 3a04e008    .....D.B... ...:
100017B0: f810e7ed f8113b01 42a34b01 1b18d0f3    .....;...K.B....
100017C0: 0303bd70 040300f3 050300f3 060300f3    p...............
100017D0: 070300f3 080300f3 000000f3 00000000    ................
100017E0: 00b71b00 10002021 001440ef 00000000    ....! ...@......
100017F0: 00000000 0001005d 00000010 00010000    ....]...........
10001800: 10000100 00000100 00003f00 68686868    .........?..hhhh
10001810: 09040268 16130f0b 1000200e 001940ef    h........ ...@..
10001820: 00000000 00000000 000100dd 00000200    ................
10001830: 00010000 10002000 00000100 00003f00    ..... .......?..
10001840: 68686868 09040268 17150f0b 10002004    hhhhh........ ..
10001850: 001840ef 00000000 00000000 0001005d    .@..........]...
10001860: 00000100 00010000 10001000 00000100    ................
10001870: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10001880: 10001ff8 001870ef 00000000 00000000    .....p..........
10001890: 0001005d 00000100 00010000 10001000    ]...............
100018A0: 00000100 00003f00 68686868 09040268    .....?..hhhhh...
100018B0: 16130f0b 10001fef 001740ef 00000000    .........@......
100018C0: 00000000 0001005d 00000080 00010000    ....]...........
100018D0: 10000800 00000100 00003f00 68686868    .........?..hhhh
100018E0: 09040268 16130f0b 10001fe6 001640ef    h............@..
100018F0: 00000000 00000000 0001005d 00000040    ........]...@...
10001900: 00010000 10000400 00000100 00003f00    .............?..
10001910: 68686868 09040268 16130f0b 10001fdd    hhhhh...........
10001920: 001340ef 00000000 00000000 0001005d    .@..........]...
10001930: 00000008 00010000 10000080 00000100    ................
10001940: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10001950: 10001fd3 00200201 00000000 00000000    ...... .........
10001960: 0001009d 00000100 00040000 00000000    ................
10001970: 00000200 00003f00 68506850 06050050    .....?..PhPhP...
10001980: 17150f0b 10001fc1 02190201 0000004d    ............M...
10001990: 00000000 0001009d 00000080 00040000    ................
100019A0: 00000000 00000100 00003f00 68506850    .........?..PhPh
100019B0: 06050050 17150f0b 10001fb0 02190201    P...............
100019C0: 0000014d 00000000 0001009d 00000200    M...............
100019D0: 00010000 00000000 00000100 00003f00    .............?..
100019E0: 68506850 06050050 17150f0b 10001fa6    PhPhP...........
100019F0: 00174001 00000000 00000000 00010055    [email protected]...
10001A00: 00000080 00010000 10000800 00000100    ................
10001A10: 00003f00 61616132 07040161 16130f0c    .?..2aaaa.......
10001A20: 10001f94 02182001 0000004d 00000000    ..... ..M.......
10001A30: 0001001d 00000040 00040000 00000000    ....@...........
10001A40: 00000100 00003f00 68506850 06050050    .....?..PhPhP...
10001A50: 16130f0b 10001f83 02182001 0000014d    ......... ..M...
10001A60: 00000000 0001001d 00000100 00010000    ................
10001A70: 00000000 00000100 00003f00 68506850    .........?..PhPh
10001A80: 06050050 16130f0b 10001f79 01160201    P.......y.......
10001A90: 0000004d 00000000 0001001d 00000080    M...............
10001AA0: 00010000 00000000 00000100 00003f00    .............?..
10001AB0: 68506850 06050050 16130f0b 10001f6f    PhPhP.......o...
10001AC0: 00150201 00000000 00000000 0001001d    ................
10001AD0: 00000040 00010000 00000000 00000100    @...............
10001AE0: 00003f00 68506850 06050050 16130f0b    .?..PhPhP.......
10001AF0: 10001f65 001540ef 00000000 00000000    e....@..........
10001B00: 0001005d 00000020 00010000 10000200    ]... ...........
10001B10: 00000100 00003f00 68506850 06040050    .....?..PhPhP...
10001B20: 16130f0b 10001f5a 001420c2 00000000    ....Z.... ......
10001B30: 00000000 0001004d 00000010 00010000    ....M...........
10001B40: 10000100 00000100 00003f00 686c6c50    .........?..Pllh
10001B50: 08040068 1813110d 10001f4f 001423c2    h.......O....#..
10001B60: 00000000 00000000 0001004d 00000010    ........M.......
10001B70: 00010000 10000100 00000100 00003f00    .............?..
10001B80: 68686850 08040068 1813110d 10001f43    Phhhh.......C...
10001B90: 001820c2 00000000 00000000 0001004d    . ..........M...
10001BA0: 00000100 00010000 10001000 00000100    ................
10001BB0: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10001BC0: 10001f38 001720c2 00000000 00000000    8.... ..........
10001BD0: 0001004d 00000080 00010000 10000800    M...............
10001BE0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10001BF0: 1813110d 10001f2d 001728c2 00000000    ....-....(......
10001C00: 00000000 0001004d 00000080 00010000    ....M...........
10001C10: 10000800 00000100 00003f00 50502150    .........?..P!PP
10001C20: 08040350 1813110d 10001f22 001620c2    P.......".... ..
10001C30: 00000000 00000000 0001004d 00000040    ........M...@...
10001C40: 00010000 10000400 00000100 00003f00    .............?..
10001C50: 68566850 08040068 1813110d 10001f17    PhVhh...........
10001C60: 001525c2 00000000 00000000 0001004d    .%..........M...
10001C70: 00000020 00010000 10000200 00000100     ...............
10001C80: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10001C90: 10001f0c 001520c2 00000000 00000000    ..... ..........
10001CA0: 0001004d 00000020 00010000 10000200    M... ...........
10001CB0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10001CC0: 1813110d 10001f01 00469d7f 00000000    ..........F.....
10001CD0: 00000000 0001004d 00000040 00010000    ....M...@.......
10001CE0: 10000400 00000100 00003f00 68646864    .........?..dhdh
10001CF0: 08040068 1613110d 10001efa 0016ba20    h........... ...
10001D00: 00000000 00000000 00010010 00000040    ............@...
10001D10: 00010000 10000400 00000100 00003f00    .............?..
10001D20: 6c6c6c6c 0904006c 16130f0b 10001ef3    lllll...........
10001D30: 0017ba20 00000000 00000000 00010010     ...............
10001D40: 00000080 00010000 10000800 00000100    ................
10001D50: 00003f00 6c6c6c6c 0904006c 16130f0b    .?..lllll.......
10001D60: 10001eeb 0218ba20 00000010 00000000    .... ...........
10001D70: 00010010 00000100 00010000 10001000    ................
10001D80: 00000100 00003f00 36363636 09040036    .....?..66666...
10001D90: 16130f0b 10001ee3 0219ba20 00000010    ........ .......
10001DA0: 00000000 00010010 00000200 00010000    ................
10001DB0: 10002000 00000100 00003f00 36363636    . .......?..6666
10001DC0: 09040036 16150f0b 10001ed9 0219ba20    6........... ...
10001DD0: 00004410 00000000 00010091 00000200    .D..............
10001DE0: 00010000 10002000 00000100 00003f00    ..... .......?..
10001DF0: 6c6c6c6c 0904006c 17150f0b 10001ecf    lllll...........
10001E00: 0020ba20 00000000 00000000 00010091     . .............
10001E10: 00000400 00010000 10004000 00000100    .........@......
10001E20: 00003f00 6c6c6c6c 0904006c 17150f0b    .?..lllll.......
10001E30: 10001ec3 0218ba20 00004410 00000000    .... ....D......
10001E40: 0001001d 00000100 00010000 10001000    ................
10001E50: 00000100 00003f00 6c6c6c6c 0804006c    .....?..lllll...
10001E60: 1814120d 10001eba 001640c8 00000000    .........@......
10001E70: 00000000 0001004d 00000040 00010000    ....M...@.......
10001E80: 10000400 00000100 00003f00 68566850    .........?..PhVh
10001E90: 0a040068 1613100e 05153505 31013335    h........5..53.1
10001EA0: 6d6f4311 206e6f6d 46495053 6f432049    .Common SPIFI Co
10001EB0: 6e616d6d 65532064 44470074 33513532    mmand Set.GD25Q3
10001EC0: 4d004332 51353254 3832314c 4d004241    2C.MT25QL128AB.M
10001ED0: 51353254 41323135 32544d00 35325135    T25Q512A.MT25Q25
10001EE0: 4e004136 32513532 4e003635 31513532    6A.N25Q256.N25Q1
10001EF0: 4e003832 36513532 324e0034 32335135    28.N25Q64.N25Q32
10001F00: 324d5000 30514c35 00433233 3532584d    .PM25LQ032C.MX25
10001F10: 3036314c 4d004536 4c353258 35333631    L1606E.MX25L1635
10001F20: 584d0045 334c3532 45353332 32584d00    E.MX25L3235E.MX2
10001F30: 34365235 00463533 3532584d 3334364c    5R6435F.MX25L643
10001F40: 4d004535 4c353258 33383231 4d004535    5E.MX25L12835E.M
10001F50: 56353258 35333038 584d0046 384c3532    X25V8035F.MX25L8
10001F60: 45353330 35325300 31304c46 53004b36    035E.S25FL016K.S
10001F70: 4c463532 50323330 35325300 36304c46    25FL032P.S25FL06
10001F80: 53005034 4c463532 50393231 6b343620    4P.S25FL129P 64k
10001F90: 00636553 46353253 3932314c 35322050    Sec.S25FL129P 25
10001FA0: 65536b36 32530063 314c4635 004b3436    6kSec.S25FL164K.
10001FB0: 46353253 3635324c 34362053 6365536b    S25FL256S 64kSec
10001FC0: 35325300 35324c46 32205336 536b3635    .S25FL256S 256kS
10001FD0: 53006365 4c463532 53323135 35325700    ec.S25FL512S.W25
10001FE0: 43303451 32570056 32335135 57005646    Q40CV.W25Q32FV.W
10001FF0: 36513532 00564634 51353257 4a383231    25Q64FV.W25Q128J
10002000: 00787856 51353257 46383231 32570056    Vxx.W25Q128FV.W2
10002010: 35325135 5f564636 65746e55 64657473    5Q256FV_Untested
10002020: 35325700 42303851 0f030056 00ff0f0f    .W25Q80BV.......
10002030: 00010100 00010909 0001090a 01010701    ................
10002040: 0001090d 0001090e 0001090f 00010910    ................
10002050: 00010911 00010912 00010913 00011114    ................
10002060: 00011119 0001111a 0001111b 00000000    ................
10002070: 00000000 00000000 00000000 00000000    ................
10002080: 00000000 00000000 00000000 00000000    ................
10002090: 00000000 00000000 00000000 00000000    ................
100020A0: 00000000 00000000 00000000 00000000    ................
100020B0: 00000000 00000000 00000000 00000000    ................
100020C0: 00000000 00000000 00000000 00000000    ................
100020D0: 00000000 00000000 00000000 00000000    ................
100020E0: 00000000 00000000 00000000 00000000    ................
100020F0: 00000000 00000000 00000000 00000000    ................
10002100: 00000000 00000000 00000000 00000000    ................
10002110: 00000000 00000000 00000000 00000000    ................
10002120: 00000000 00000000 00000000 00000000    ................
10002130: 00000000 00000000 00000000 00000000    ................
10002140: 00000000 00000000 00000000 00000000    ................
10002150: 00000000 00000000 00000000 00000000    ................
10002160: 00000000 00000000 00000000 00000000    ................
10002170: 00000000 00000000 00000000 00000000    ................
10002180: 00000000 00000000 00000000 00000000    ................
10002190: 00000000 00000000 00000000 00000000    ................
100021A0: 00000000 00000000 00000000 00000000    ................
100021B0: 00000000 00000000 00000000 00000000    ................
100021C0: 00000000 00000000 00000000 00000000    ................
100021D0: 00000000 00000000 00000000 00000000    ................
100021E0: 00000000 00000000 00000000 00000000    ................
100021F0: 00000000 00000000 00000000 00000000    ................
10002200: 00000000 00000000 00000000 00000000    ................
10002210: 00000000 00000000 00000000 00000000    ................
10002220: 00000000 00000000 00000000 00000000    ................
10002230: 00000000 00000000 00000000 00000000    ................
10002240: 00000000 00000000 00000000 00000000    ................
10002250: 00000000 00000000 00000000             ............
Driver code in memory:
10000000: 03000020 54010065 00000002 00000000     ...e..T........
10000010: 000022cc 10000000 00000000 10000000    ."..............
10000020: 00001000 00000040 1000225c 10000015    ....@...\"......
10000030: 00000000 b6720004 b8526000 00063700    ......r..`R..7..
10000040: 21666020 0f5773bf 0d016965 612640fa     `f!.sW.ei...@&a
10000050: 40013e00 40262340 23806123 00526167    .>.@@#&@#a.#gaR.
10000060: 11ef429d 010963fe 000a421d 68e06840    [email protected]
10000070: 78e56000 60202300 50e42800 43032201    .`.x.# `.(.P.".C
10000080: 06e3e3ea 4b05c507 51002f00 e7f12000    .......K./.Q. ..
10000090: e8c16000 2142f7ee 0012421d d400038b    .`....B!.B......
100000A0: 0b004b2e 286040d2 68a268e1 79046000    .K...@`(.h.h.`.y
100000B0: 6860f7e0 68a268e1 78e46000 d0eeb800    ..`h.h.h.`.x....
100000C0: 00c167d8 4214005b 70014002 e7dcf899    .g..[[email protected]....
100000D0: 23000028 46c067ef 00000215 100002c9    (..#.g.F........
100000E0: f0002170 4b35ff6b 4102482c 78150118    p!..k.5K,H.A...x
100000F0: 085d6858 cb023304 42821245 40237840    Xh]..3..E..B@x#@
10000100: 2000d1f5 f99df001 21085a35 72f3ebb0    ... ....5Z.!...r
10000110: 32004225 70012004 23016965 21003201    %B.2. .pei.#.2.!
10000120: 60002005 2101fabd 6001482e 482669b5    . .`...!.H.`.i&H
10000130: 7996f000 f000482b 28007a7d 704ed047    ...y+H..}z.(G.Np
10000140: 4a295280 48280174 68896000 60204828    .R)Jt.(H.`.h(H `
10000150: 28004626 2100403d 79b2f000 f0f0fbb5    &F.(=@.!...y....
10000160: 32002109 70012004 2201693d 06106820    .!.2. .p=i." h..
10000170: 68136803 29494698 210e4602 20014820    .h.h.FI).F.! H.
10000180: bb107ae7 28202101 79926000 21024819    .z...! (.`.y.H.!
10000190: 28316480 79946000 4f80f1b0 6446bf28    .d1(.`.y...O(.Fd
100001A0: 4a054380 64e3ab28 64214b34 64e0ab18    .C.J(..d4K!d...d
100001B0: 60146113 68302000 68422101 68126a12    .a.`. 0h.!Bh.j.h
100001C0: 440269c3 f000605a 462068e9 2004b970    .i.DZ`...h Fp..
100001D0: 2003f7fc 3f00e7fa 100007c2 00004000    ... ...?.....@..
100001E0: 000e4240 40010000 000010b1 1000206c    @[email protected] ..
100001F0: 100020c0 1000225c 10000000 1000b24c    . ..\"......L...
10000200: 4b022108 60016818 20007a09 3f00b908    .!.K.h.`.z. ...?
10000210: 100020c0 4c002138 68202100 f9bee000    . ..8!.L.! h....
10000220: 68026820 4581687b 29184205 68200101     h.h{h.E.B.).. h
10000230: 79b46000 bd305628 100000c0 460421f8    .`.y(V0......!.F
10000240: 46045e12 20556896 04127e11 23036a43    .^.F.hU .~..Cj.#
10000250: 08804313 60036a43 70004261 b1706851    .C..Cj.`aB.pQhp.
10000260: 21005f0b 70006838 6e326999 6b023801    ._.!8h.p.i2n.8.k
10000270: 46205404 70016818 46047ac8 4620b108    .T F.h.p.z.F.. F
10000280: 0100b9f8 70016838 e7f86989 0000325c    ....8h.p.i..\2..
10000290: 100020c0 460421f8 4617462f 01004c09    . ...!.F/F.F.L..
100002A0: 60006820 4620697b 4623423b 70006820     h.`{i F;B#F h.p
100002B0: 46047a79 2101b918 20017800 4620696f    yz.F...!.x. oi F
100002C0: 0f08b9f8 100020c0 35704b0d 0404485e    ..... ...Kp5^H..
100002D0: 46154286 22144111 2000d621 b1016a51    .B.F.A."!.. Qj..
100002E0: bd70a00a 002061a5 0120f104 0020f106    ..p..a ... ... .
100002F0: ba46f001 d0f42800 460267f2 67fe4621    ..F..(...g.F!F.g
10000300: 0001227c 4ff0e92d 0ff0e8b0 01124294    |"..-..O.....B..
10000310: d1104295 d1064296 d10c4297 d10a4190    .B...B...B...A..
10000320: d1084591 d1064592 d1044593 d1e22908    .E...E...E...)..
10000330: c8bd2000 20010ff0 0ff1e8bd 010468ca    . ..... .....h..
10000340: 704218d3 f443471f 60430300 78017903    ..Bp.GC...C`.y.x
10000350: 7d033c04 3c037801 78017903 44033c02    .<.}.x.<.y.x.<.D
10000360: 41025491 079369c3 077140fc 48007d03    .T.A.i...@q..}.H
10000370: e5f53f01 a5f12300 b0864205 3003e88d    .?...#...B.....0
10000380: 3007f88d 440f780b 4b34681c 0c004249    ...0.x.D.h4KIB..
10000390: 44142f08 466847a0 47a14628 46200903    ./.D.GhF(F.G.. F
100003A0: f89c47a0 f89d0000 408b300c 789d510b    [email protected]
100003B0: f89d7001 40bb300d 789d5105 f89d2002    [email protected]. ..
100003C0: 4093200e 00015002 3df0b007 28526813    . [email protected].....=.hR(
100003D0: 28016858 680240f7 4005f893 c106c08c    Xh.([email protected]...@....
100003E0: c0056c91 c103d0bc c0076891 c0024194    .l.......h...A..
100003F0: e7ef6840 e0026840 2b0069db 062050e4    @[email protected].+.P .
10000400: 0002f88d 05a15249 68944823 685b4000    ....IR..#H.h.@[h
10000410: 4001689d f89d6858 f89d6002 28010003    .h.@Xh...`.....(
10000420: 680250d1 40a3f91a 795251e4 51e0d2aa    [email protected]
10000430: 42a3699a 79d251de 51da4291 d0c32900    .i.B.Q.y.B.Q.)..
10000440: 11012200 52be428a 0c036a0d 7b00e813    ."...B.R.j.....{
10000450: 4005f89c d1c441bc e7f32601 0001033d    [email protected]...&..=...
10000460: 57800108 4b04b138 6050685a 4a026042    ...W8..KZhP`B`.J
10000470: 33016813 3d016013 100020c8 100020c4    .h.3.`.=. ... ..
10000480: 68526803 60486850 68da6051 68122000    .hRhPhH`Q`.h. .h
10000490: 60133301 00014370 23102171 69c2f1c3    .3.`pC..q!.#...i
100004A0: 01016003 60c2d1fb 21016183 69c261c3    .`.....`.a.!.a.i
100004B0: 54f506db 40004a01 47712000 400603e8    ...T.J.@. qG...@
100004C0: 68430901 4571e858 41042901 e9d26843    ..ChX.qE.).ACh..
100004D0: 41512002 09024670 68424102 4771e898    . QApF...ABh..qG
100004E0: 41022903 68d06843 29044270 68424102    .).ACh.hpB.).ABh
100004F0: 4571e918 41022905 69506843 29064770    ..qE.).AChPipG.)
10000500: 68424102 4561f998 41022907 69d06843    .ABh..aE.).ACh.i
10000510: 29084670 68424106 7893fa1b 48132028    pF.).ABh...x( .H
10000520: 45715358 51042909 4a126843 30296893    XSqE.).QCh.J.h)0
10000530: 290bf6f5 6842c104 78937a1b e5e7202a    ...)..Bh.z.x* ..
10000540: c104290b 4a126843 302b6893 290df3e7    .)..Ch.J.h+0...)
10000550: 2842c104 7893fa1b e5e1202c d102290d    ..B(...x, ...)..
10000560: 4a126843 290f67c4 2100c103 69d3e803    Ch.J.g.)...!...i
10000570: 290f4718 68034103 69d32100 291167f8    .G.).A.h.!.i.g.)
10000580: 6842af26 20016a58 3f004370 00064240    &.BhXj. pC.?@B..
10000590: 681b6843 600168d8 47700001 15362310    Ch.h.h.`..pG.#6.
100005A0: 28156842 69e261e3 44e506fd 04da49c3    Bh.(.a.i...D.I..
100005B0: 2a5340fc 07547c23 40234113 60235780    .@S*#|T..A#@.W#`
100005C0: 680311a1 6b9d566a 47a92e01 60e28b01    ...hjV.k...G...`
100005D0: 60639b00 078169e2 01a340fc 20032000    ..c`.i...@... .
100005E0: 15d52930 e043bf48 e5e15380 60e223ff    0)..H.C..S...#.`
100005F0: 61a12310 69e361e3 44e506da 04da49e3    .#.a.a.i...D.I..
10000600: 27eb40fc 4601b510 01006c03 47816a5b    .@.'...F.l..[j.G
10000610: 46202000 ffc2f7ff bd002000 44042110    .  F..... ...!.D
10000620: 01006803 47906a5b 46202101 ffb6f7ff    .h..[j.G.! F....
10000630: bd102000 44042138 68554d27 4420290c    . ..8!.D'MUh.) D
10000640: 4620b918 f7ff5628 b9096eb5 e5fce864    .. F(V...n..d...
10000650: 68916823 65f22040 000120c8 43f8e92d    #h.h@ .e. ..-..C
10000660: 07824699 46074604 46064690 04014003    .F...F.F.F.F.@..
10000670: 68b45620 4b2507f8 0d01487d 442040f7     V.h..%K}H...@ D
10000680: f7ffd640 28016e77 6864d138 7807f7f5    @...wn.(8.dh...x
10000690: 40a7af01 480051fb 0105f104 1d0a6043    [email protected]`..
100006A0: 710563e3 e9c40340 88822800 901178c4    .c.q@....(...x..
100006B0: 49826143 61a3464a 46210b8b 0bc241e3    Ca.IJF.a..!F.A..
100006C0: 8c0b6223 6a4b6263 210b68e4 4640e80b    #b..cbKj.h.!..@F
100006D0: 48236363 4589695b 68846865 f8940028    cc#H[i.Eeh.h(...
100006E0: 2801202c 462051c3 ff8cf7ff f8846863    , .(.Q F....ch..
100006F0: f883002c 2901202c 67b050ba 6898682b    ,..., .).P.g+h.h
10000700: 408f2040 442653b3 65c2a300 000020c8    @ [email protected]&D...e. ..
10000710: 41f0e92d 4010460c 4403010f 50244617    [email protected]$P
10000720: ff3f67ff 46806872 6a526a10 60236900    .g?.rh.F.jRj.i#`
10000730: 6043030f 31074001 6043430b 46336833    ..C`[email protected]`3h3F
10000740: 46306b5b 46404398 46314605 04064024    [[email protected]$@..
10000750: 7f25f7ff 6a026872 6a35691b c1120303    ..%.rh.j.i5j....
10000760: b1666a53 20434323 6b556833 463b217d    Sjf.#CC 3hUk}!;F
10000770: 46304601 68b4462b 451940f0 e7e82103    [email protected].!..
10000780: 03056e23 4620e3ef 01f0e8bd 48506843    #n.... F....ChPH
10000790: 68d80a08 7bb1489b 428260f1 f047bf98    ...h.H.{.`.B..G.
100007A0: 466130ff 43f0682d 460e4204 461d4690    .0aF-h.C.B.F.F.F
100007B0: 21050000 e8b52108 687393f8 69954240    [email protected]
100007C0: 40ac4833 462c3e28 0000f8d1 06224639    3H.@(>,F....9F".
100007D0: 47c14630 03026024 44914027 67e80e2d    0F.G$`..'@.D-..g
100007E0: a5704841 1886689b 0404429e d900420c    AHp..h...B...B..
100007F0: c008000b 4621682b 4621689b 39184698    ....+h!F.h!F.F.9
10000800: 00a20401 000051f6 3538b970 b7fe4605    .....Q..p.85.F..
10000810: 46056fbd 46204611 ffb8e7ff d0081c62    .o.F.F F....b...
10000820: d0071c43 1b031c42 06205621 4038e8bd    C...B...!V ...8@
10000830: bfd6f7ff bd30200b 059a69c3 077140fc    ..... 0..i...@q.
10000840: 42c4f04f 77fe6042 b5113ff7 28224604    O..BB`.w.?...F"(
10000850: 6adb4600 07c34798 3d0144f9 b5706803    .F.j.G...D.=.hp.
10000860: 04026adb 46144204 03014798 71076a03    .j...B.F.G...j.q
10000870: 4100b035 4621f823 407068bd 47106b1b    5..A#[email protected]
10000880: 01006a20 b501e3f6 2adae803 60114698     j.........*.F.`
10000890: bf040f1c 00004000 bd012005 6842a108    .....@... ....Bh
100008A0: 49057819 604a4208 32d36d0a ffc477ff    .x.I.BJ`.m.2.w..
100008B0: 60424b09 6a43690b f7fe2603 06916abd    .KB`.iCj.&...j..
100008C0: f043bf48 06527200 70433b48 f0227280    H.C..rR.H;Cp.r".
100008D0: bd000060 05200001 35200001 06102200    `..... ... 5."..
100008E0: 35716843 0e00681c 5d934909 684100d0    Chq5.h...I.]..Ah
100008F0: 60636303 40836923 43114620 7f9de7ff    .cc`#i.@ F.C....
10000900: 2a003201 460151f1 bf00b970 10001e98    .2.*.Q.Fp.......
10000910: 00200001 06102200 b5716843 0e00681c    .. .."..Chq..h..
10000920: 5d9b4909 684100d0 60636303 40836923    .I.]..Ah.cc`#i.@
10000930: 43114620 ff81e7ff 2a023201 460151f1     F.C.....2.*.Q.F
10000940: 2f00b970 10001e9b 00200001 6842a108    p../...... ...Bh
10000950: 4b056818 7d026043 77fe32d2 4611fb6d    .h.KC`.}.2.wm..F
10000960: 3f00bd08 05200001 6842a108 4b01681a    ...?.. ...Bh.h.K
10000970: 60524210 32c16d11 ff5ff7ff 60524b05    .BR`.m.2.._..KR`
10000980: 6a416913 f7ff2103 46097f57 bf00bd08    .iAj.!..W..F....
10000990: 05200001 35200001 00004770 68106843    .. ... 5pG..Ch.h
100009A0: 60424a01 3f416bff 30200000 6842a138    .JB`.kA?.. 08.Bh
100009B0: 68055625 75fe4600 4b076f63 22c36063    %V.h.F.uco.Kc`."
100009C0: 210762c1 75217123 7f3777ff e8b44628    .b.!#q!u.w7.(F..
100009D0: f5ff4038 bf013f3a 01208002 2842a138    8@..:?.... .8.B(
100009E0: 68155625 75fe4600 4b096f2b 22ca6063    %V.h.F.u+o.Kc`."
100009F0: f3c16123 f3c12727 75234107 77f76101    #a..''...A#u.a.w
10000A00: 46297f3b 4038e8bd bf1ef7ff 01208003    ;.)F..8@...... .
10000A10: 2842a138 68155625 f7fe4600 4b056f11    8.B(%V.h.F...o.K
10000A20: 6063b2c9 77ff7121 46297f27 4038e8bd    ..c`!q.w'.)F..8@
10000A30: bf0af7ff 01218001 43f0e92d 46026841    ......!.-..CAh.F
10000A40: 4606681d f7ff4608 24016efb 1034f8ff    .h.F.F...n.$..4.
10000A50: 8034f8df f7fe4208 f8157ef3 e840b009    ..4..B...~....@.
10000A60: 606a7303 7a2700e3 b2d37303 f7fff12b    .sj`..'z.s..+...
10000A70: 34017ee3 77ff4620 2c036ee8 68b5d1ea    .~.4 F.w.n.,...h
10000A80: ad0193f8 10000abe 00200001 0f04e011    .......... .....
10000A90: 4002b108 0107b6d0 7ee0f3ff bd002000    ...@.......~. ..
10000AA0: 45782000 0f046011 4002b108 0101b6d0    . xE.`.....@....
10000AB0: 7ed5f3ff bd002000 0f0c6011 4018b110    ...~. ...`.....@
10000AC0: b0d2f841 2100681c 7ec967ff f7fe4620    A....h.!.g.~ F..
10000AD0: f04f6eb3 606362e4 7ea763ff 60624b06    .nO..bc`.c.~.Kb`
10000AE0: 7523238b 7ea163ff 60604b04 75f74903    .##u.c.~.K``.I.u
10000AF0: 20017ea3 3f00bd10 81208001 85200001    .~. ...?.. ... .
10000B00: 05702000 46002110 6802b141 47917adb    . p..!.FA..h.z.G
10000B10: 64206803 6b122070 47994620 bd100000    .h dp .k F.G....
10000B20: 44002110 4802b141 4581fadb 64206803    .!.DA..H...E.h d
10000B30: 6b124080 47994620 3d100000 44042110    [email protected] F.G...=.!.D
10000B40: 6802b139 4581fafb 01006040 77fed620    9..h...E@`.. ..w
10000B50: 20016f65 0000bd00 21feb10b 28436019    eo. .......!.`C(
10000B60: 05516a5b 4b014102 4770f013 3f4407db    [jQ..A.K..pG..D?
10000B70: 4b024b02 3f0163f8 ab920000 bb910000    .K.K.c.?........
10000B80: 0b810000 21f7a10b 28436019 05536a5b    .......!.`C([jS.
10000B90: 0b032a4c 60124b02 3f014370 ab940000    L*...K.`pC.?....
10000BA0: 0b810000 21ffa10b 28436019 05516a5b    .......!.`C([jQ.
10000BB0: 4b014102 47706013 3f4407db 4b024b02    .A.K.`pG..D?.K.K
10000BC0: 3f0163f8 acb20000 acb10000 0ca10000    .c.?............
10000BD0: 6a536843 3f4d071b 0b024b01 4770400b    ChSj..M?.K...@pG
10000BE0: 02800000 02808000 6a52e843 2f4d071b    ........C.Rj..M/
10000BF0: 4b024b01 4770400b 04a00000 12a08000    .K.K.@pG........
10000C00: 6a52e843 3f4d071b 4b024b01 4770400b    C.Rj..M?.K.K.@pG
10000C10: 08900000 00808000 b5f0e7fe 06026803    .............h..
10000C20: 46066adb 60014398 46044440 6001540c    .j.F.C.`@D.F.T.`
10000C30: bf187080 01822410 6044bf48 b11e0400    .p...$..H.D`....
10000C40: 44316c33 47906a9b 031c6015 2b1cd005    3l1D.j.G.`.....+
10000C50: 7044bf0c f0440404 07e20408 70453f48    ..Dp..D.....H?Ep
10000C60: 44200401 09002df8 0405b538 5814462d    .. D.-..8...-F.X
10000C70: 6ad36803 60014698 b944031c 6823010b    .h.j.F.`..D...#h
10000C80: 0105f020 4620fb3b 00004398 2b144007     ...;. F.C...@.+
10000C90: 6822c0db 0105f040 67f4fb1b bd302003    .."[email protected]. 0.
10000CA0: b5706843 28144606 fdecf7ff b9494605    Chp..F.(.....FI.
10000CB0: f5fe4600 4b056de5 f7fe6043 463169bd    .F...m.KC`...i1F
10000CC0: 7dc2f7ff bd714628 c5200000 e9246843    ...}(Fq... .Ch$.
10000CD0: 688b40f0 408a4624 592c4688 f5ff681e    [email protected][email protected],Y.h..
10000CE0: 460569d2 6863bf28 68d74220 79074823    .i.F(.ch B.h#H.y
10000CF0: 6a936608 46314798 7da267ff 60b66863    .f.j.G1F.g.}ch.`
10000D00: 69136a1b 3f4d021b 0b0c4e0c 77ff4053    [email protected]
10000D10: 68636993 74077e5e d1022280 f7fe4620    .ich^~.t.".. F..
10000D20: 46314db4 f7f75600 f0107f78 bf100f20    .M1F.V..x... ...
10000D30: 46280527 01f0e8bd e5f2210b cca00000    '.(F.....!......
10000D40: d8800000 47f2e92d 4843461c 69934617    ....-..G.FCH.F.i
10000D50: 40a24605 d3464689 f7fe681e 46816994    [email protected]
10000D60: 6822b9d8 6bdba901 47994628 402807a3    .."h...k(F.G..(@
10000D70: 4629482b 47986a9b f7fe4230 9b016d61    +H)F.j.G0B..am..
10000D80: 9001f8e4 60724303 7817403c 40a72f01    .....Cr`<@.x./.@
10000D90: 41f37133 f7fe5630 686b4d6f 64057e5c    3q.A0V..oMkh\~.d
10000DA0: d1002080 f7ff5628 46216d50 67f7d428    . ..(V..Pm!F(..g
10000DB0: f0116f34 bf100f10 0802404f 20025640    4o......O@..@V.
10000DC0: 87f0c8bd 0a94ea5f 1b00c0e7 0403f024    ...._.......$...
10000DD0: 6823d31c 6a9b4208 46314798 fd3067ff    ..#h.B.j.G1F.g0.
10000DE0: 0882eb07 1008e8c6 b85ee074 45573b04    ........t.^..;WE
10000DF0: 41f36153 d04e67ee e7df0809 47f3692d    Sa.A.gN.....-i.G
10000E00: 4843461f 68154688 441749db 433642bb    .FCH.F.h.I.D.B6C
10000E10: ea464803 f8c30997 21012018 4610aa01    .HF...... .!...F
10000E20: 0403e007 71b157d0 d0130f00 9b0122ff    .....W.q....."..
10000E30: 07036027 60e3433b 09886b26 0009e8c5    '`..;C.`&k......
10000E40: 606ac098 78476d6b 45462b04 462851da    ..j`kmGx.+FE.Q(F
10000E50: fcf2f7ff 20f6b1ac 60eb9b01 68c4d323    ....... ...`#..h
10000E60: 44250008 7d22606b 39016826 11f352b4    ..%Dk`"}&h.9.R..
10000E70: f7fe4228 20014ce1 68bcb002 200b96f0    (B...L. ...h...
10000E80: 4621e7fa 2002e7f8 00014770 4a444b6c    ..!F... pG..lKDJ
10000E90: 400b0100 605adc6c 609a4a4c 60da4a4c    [email protected]`LJ.`LJ.`
10000EB0: 601a2200 6a126842 40246892 404b2801    .".`Bh.j.h$@.(K@
10000EC0: d05a2c02 d05a2c03 4d464d46 3f012800    .,Z..,Z.FMFM.(.?
10000ED0: b8924629 6050402e 50532805 4d424d43    )F...@P`.(SPCMBM
10000EE0: 0d002804 f8924609 6090402f 404b2806    .(...F../@.`.(K@
10000F00: 3f18280a b8924629 60d04030 5043280b    .(.?)F..0@.`.(CP
10000F10: d0422c0c d0422c0d 4d324d36 3f11280e    .,B..,B.6M2M.(.?
10000F20: 23184609 40314882 4033a80f d03a2c10    .F.#[email protected]@.,:.
10000F30: d03a2c11 4d2c4930 2d082810 23584629    .,:.0I,M.(.-)FX#
10000F40: 40334882 50322813 d0322c14 4d264d0b    .H3@.(2P.,2..M&M
10000F50: 2d002835 23984609 10336892 50232916    5(.-.F.#.h3..)#P
10000F60: d02a2917 4c204a26 3d100818 23da4222    .)*.&J L...="B.#
10000F70: 20004003 49222930 4923f7ab 4923e7a9    .@. 0)"I..#I..#I
10000FB0: 4923e7d1 4823e7cf 4a23e7d9 3f01e7d7    ..#I..#H..#J...?
10000FC0: 10002204 10000867 10000ca1 10000ced    ."..g...........
10000FD0: 1000004d 10000945 10000dfd 10000e87    M...E...........
10000FE0: 10000c1b 10000e01 10000819 10000999    ................
10000FF0: 100008dd 10000a19 10000aa1 10000ba5    ................
10001000: 10000801 10000f05 10000b01 10000b3d    ............=...
10001020: 10000949 100009ad 100009dd 10000a11    I...............
10001040: 10000b85 10000bd1 10000be9 692c4843    ............CH,i
10001050: 690b40f0 408a4624 59264688 f5f7681e    [email protected][email protected]&Y.h..
10001060: 46056812 6863b8f8 695f5220 7b076823    .h.F..ch R_i#h.{
10001070: 6a936608 46314798 fbe267ff 5302f04f    .f.j.G1F.g..O..S
10001080: 607270b7 7bd177ff 6a5a6863 440b03db    .pr`.w.{chZj...D
10001090: f7fe4200 46296ffa f7ff5200 f0116dbe    .B...o)F.R...m..
100010A0: bf101f20 46280527 81f0e8bd e7f2210b     ...'.(F.....!..
100010B0: a510496e 2a00680a 00d47040 4865db6c    nI...h.*@p..l.eH
100010C0: 69c3486d e9c32102 60434000 6112486b    mH.i.!...@C`kH.a
100010D0: 496c4e6b 4022415a 46214b6b f7fe400b    kNlIZA"@kK!F.@..
100010E0: 496b69cf 44205b4a f7fe400b 496969c9    .ikIJ[ [email protected]
100010F0: 44215b69 f7fe4009 496879c3 44205b68    i[[email protected][ D
10001100: 77f6400b 496779bd 44215b67 f7fe400b    [email protected][!D.@..
10001110: 496769b7 44205966 77f6400b 496569b1    .igIfY [email protected]
10001120: 44215b65 77f64009 496569ab 44205b64    e[[email protected][ D
10001130: f7fe400b 496369a5 44215b63 f7fe400b    [email protected][!D.@..
10001140: 4963699f 44205b42 f7fe400b 49616999    .icIB[ [email protected]
10001150: 44215b61 f7fe400b 49616993 44205b60    a[[email protected]`[ D
10001160: f7fe400b 495f698d 44215b5f 77fe400b    [email protected]_I_[[email protected]
10001170: 495f6987 44205b5e f7fe400b 495d6981    .i_I^[ [email protected]]I
10001180: 44215b5d f7fe400b 495d697b 44205b7c    ][!D.@..{i]I|[ D
10001190: f7fe600b 495b7975 44215b5b f7fe400b    .`..uy[I[[!D.@..
100011A0: 495b696f 44205b5a f7fe400b 49596969    oi[IZ[ [email protected]
100011B0: 44215b59 f7fe600b 49596963 44205b58    Y[!D.`..ciYIX[ D
100011C0: f7fe400b 4957685d 44215b57 f7fe400b    .@..]hWIW[!D.@..
100011D0: 49576957 44205b56 f7fe400b 49556951    WiWIV[ [email protected]
100011E0: 44215b55 f7fe4009 4955694b 44205b54    U[[email protected][ D
100011F0: 77f6400b 49536845 44215b53 f7fe600b    [email protected][!D.`..
10001200: 4953693f 44205b52 f7fe400b 49516839    ?iSIR[ [email protected]
10001210: 44215b51 f7fe400b 49516933 44205b50    Q[[email protected][ D
10001220: f7fe400b 494f682d 44215b4f f7fe400b    [email protected][!D.@..
10001230: 494f6927 44205b6e f7fe600b 494d6821    'iOIn[ D.`..!hMI
10001240: 4421db6d f7fe400b 494d691b 44205b4c    [email protected][ D
10001250: f7f6400b 494b6915 46215b4b f7fe400b    [email protected][!F.@..
10001260: 4621690f 0000b910 3f00f7fc 100021d8    .i!F.......?.!..
10001270: 100021ec 100021e4 10001ea1 100001fc    .!...!..........
10001280: 10000e8d 100000d0 100017e4 100020d8    ............. ..
10001290: 10000818 100030e0 1000086c 100030c8    .....0..l....0..
100012A0: 10000880 100030f0 100008b4 100030f8    .....0.......0..
100012B0: 100008e8 10002100 1000091c 10003108    .....!.......1..
100012C0: 10000950 10003110 10000984 10003118    P....1.......1..
100012D0: 100009b8 10002120 100009ec 10003128    .... !......(1..
100012E0: 10001a20 10000130 10001a74 10000118     ...0...t.......
100012F0: 10001a88 10000140 10001abc 10000148    [email protected]...
10001300: 10001af0 10000150 10001b24 10000158    ....P...$...X...
10001310: 10001b58 10000160 10001bac 10000148    X...`.......H...
10001320: 10001bc0 10000170 10001bf4 10002178    ....p.......x!..
10001330: 10000828 10002180 1000185c 10002188    (....!..\....!..
10001340: 10000890 10003190 100008c4 10002198    .....1.......!..
10001350: 100008f8 100031a0 1000092c 100031a8    .....1..,....1..
10001360: 10000960 100021b0 100019b4 10003198    `....!.......1..
10001370: 100009c8 100031c0 100009fc 100021c8    .....1.......!..
10001380: 10000e30 100001d0 10001e64 7372d44f    0.......d...O.rs
10001390: 1300b082 4993db0c 70226998 42800102    .......I.i"p...B
100013A0: 3f18480a 28004099 f0224909 40800201    .H.?.@.(.I"....@
100013B0: f042ba88 61920204 1e5a9b01 0b009201    ..B....a..Z.....
100013C0: 2002d1fa bf005770 00040000 100117e0    ... pW..........
100013D0: 01302cff 6c534c02 01014043 4771f053    .,[email protected]
100013E0: 40040000 f1030083 f5034380 291123a0    [email protected]...#.)
100013F0: 2c912110 2800d00d 2a411609 4a010182    .!.,...(..A*...J
10001400: 41006041 4a065c00 02817e42 0402ea24    A`.A.\.JB~..$...
10001410: 64904321 60410910 64841401 3f0067fa    !C.d..A`...d.g.?
10001420: 1000202a 1f000001 30124b04 00206853    * .......K.0Sh .
10001430: bf5413c3 200463c0 4570a011 40040000    ..T..c. ..pE...@
10001440: 58332810 f00168df 18060809 28262e23    .(3X.h......#.&(
10001450: 2822392a 3634262f 34460038 47714000    *9"(/&468.F4.@qG
10001460: 47704817 48104b17 112c48d3 0306f003    .HpG.K.H.H,.....
10001470: 2f013a04 47702000 4a144b12 112448d3    .:./. pG.K.J.H$.
10001480: 30025811 2b050307 0610ab08 4b105770    .X.0...+....pW.K
10001490: 47706818 67f24b0f e7f94b0f 68594b0e    .hpG.K.g.K...KYh
100014A0: 60004350 200028b5 28e2f000 e5fa3001    PC.`.(. ...(.0..
100014B0: e7f92002 e7f72003 e7f52004 47712000    . ... ... ... qG
100014C0: 00b40a00 00051000 017c7840 02fb7080    ........@x|..p..
100014D0: 000017dc 100017c0 10003264 b5f623da    ........d2...#..
100014E0: 0405422c f7ff0301 4b1bfbab 6c5a5360    ,B.........K`SZl
100014F0: 70232801 ea4356f8 4b177205 4a174013    .(#[email protected]
10001500: 48114290 01010101 7b060047 42977605    .B.H....G..{.v.B
10001510: 6a42d90f f0435304 ea430340 4a052301    [email protected]..#.J
10001520: 03016023 1b017053 92010e5a d1f33b00    #`..Sp..Z....;..
10001530: 1100600d 67e1006d 42804a09 6a424804    .`..m..g.J.B.HBj
10001540: e0435304 e7e303c0 ff4463ff b0022000    .SC......cD.. ..
10001550: bf0139f0 00040000 ff01c83d 09445eff    .9......=....^D.
10001560: 01025fff 03f0c92d 46064691 4690460f    ._..-....F.F.F.F
10001570: ff66f7ff 3ff6f1b9 7bb9d02e fb01f0f0    ..f....?...{....
10001580: 42a3f000 4b21dc17 5805529c 9d244180    ...B..!K.R.X.A$.
10001590: 25004625 42a64404 03016501 4a13d81a    %F.%.D.B.e.....J
100015A0: 48175294 d1154180 b945253d e8bc5630    .R.H.A..=%E.0V..
100015B0: f5ff43f8 25012b93 3164f7ec e7f44619    .C...+.%..d1.F..
100015C0: 05056fa9 0401eba4 d9f742a5 91c363ee    .o.......B...c..
100015D0: a5ea4601 d1e92d00 f4f17fb7 f1f0fbb8    .F...-..........
100015E0: fb043200 49026100 510656bd d8044145    .2...a.I.V.QEA..
100015F0: 3cfee105 3d99518c 429c4602 42e64425    ...<.Q.=.F.B%D.B
10001600: e7f02401 e8b55610 bf0107f8 0ab28100    .$...V..........
10001610: 0aba94ff 4d14b537 71c4fc6c f7fe6003    ....7..Ml..q.`..
10001620: 4b137f0f 4c229301 0101d011 f3c5d019    ...K.."L........
10001630: a9023301 e812400b f1c50c04 33003701    [email protected]
10001640: 70f37bb0 f3c509a3 ea424227 07e300d4    .{.p....'BB.....
10001650: 02017502 0043bf5c f2f3fb92 b0034350    .u..\.C.....PC..
10001660: 46012930 3f00f7fb 00040000 08050201    0).F...?........
10001670: 4404a138 fed0f7ff f1045b07 f8520212    8..D.....[....R.
10001680: f5f74022 4b057efd 6a035d1b 33011795    "@...~.K.].j...3
10001690: 70f36b90 bf01b938 00041000 0001202a    .k.p8.......* ..
100016A0: 00842030 4480f124 24a0f104 6de4b81b    0 ..$..D...$...m
100016B0: 2901480d 4801d00a b10a5028 60006040    .H.)...H(P..@`.`
100016C0: 7040b50b ea401001 65e06001 70442930    ..@p..@..`.e0)Dp
100016D0: 65e50501 3f0167fa e0f6e7fe 63fbf44f    ...e.g.?....O..c
100016E0: 2802b553 04045624 03014616 f7f74101    S..($V...F...A..
100016F0: 2301fe4d 46202201 f7ff2004 4b177fd1    M..#." F. .....K
10001700: 4903429d 4916421a 75f64600 23016f2b    .B.I.B.I.F.u+o.#
10001710: 21003201 77ff2004 9b017fc3 92019e5a    .2.!. .w....Z...
10001720: d1f33a00 442a490f 6809460a 75ff4620    .:...I*D.F.h F.u
10001730: b12f6f39 b1044c0c 34040540 510046ac    9o/[email protected]
10001740: bd710002 3c00f814 2c03f814 0c02f814    ..q....<...,....
10001750: 0c05f814 ffa4f7ff bf00e7ef 06866780    .............g..
10001760: 00b61b00 000113e0 10002030 49022201    ........0 ...".I
10001770: 75f64210 bf012fb3 0ab29500 bff6f7ff    .B.u./..........
10001780: 0300fa40 2571839b 0604410c 2a02560b    @.....q%.A...V.*
10001790: 46214619 68064906 2404f80d 710242ae    .F!F.I.h...$.B.q
100017A0: d0010204 4290400a 00014503 3a04f008    [email protected].....:
100017B0: 7810e7ed f8102b01 40a35b01 1b0140f1    ...x.+...[.@.@..
100017C0: 0302b970 040300f3 050300f3 060300f3    p...............
100017D0: 070300f3 080300f3 000100f3 00000000    ................
100017E0: 00b61b00 00010021 001440ef 00000000    ....!....@......
100017F0: 00000000 0000005d 00010010 00000000    ....]...........
10001800: 00010100 00000100 00003f00 68606868    .........?..hh`h
10001810: 09040268 04120b0b 1001000e 001040ef    h............@..
10001820: 00010000 00000000 000000dd 00010200    ................
10001830: 00000000 00012000 00000100 00003f00    ..... .......?..
10001840: 68606868 09040268 15140b0b 10010004    hh`hh...........
10001850: 001040ef 00000000 00000000 0000005d    .@..........]...
10001860: 00010100 00000000 10010000 00001100    ................
10001870: 00003f00 68606868 09040268 14120b0b    .?..hh`hh.......
10001880: 10010ff8 001870ef 00001000 00000000    .....p..........
10001890: 0000005d 00010100 00000000 10010000    ]...............
100018A0: 00001100 00003f00 68606868 09040268    .....?..hh`hh...
100018B0: 04120b0b 10001fef 001640ef 00010000    .........@......
100018C0: 00000000 0000005d 00010080 00000000    ....]...........
100018D0: 10010800 00000100 00003f00 68606868    .........?..hh`h
100018E0: 09040268 04120b0b 10010fe6 001640ef    h............@..
100018F0: 00000000 00000000 0000005d 00010040    ........]...@...
10001900: 00000000 00010000 00000100 00003f00    .............?..
10001910: 68606868 09040268 16120b0b 10010fdd    hh`hh...........
10001920: 001240ef 00010000 00000000 0000005d    .@..........]...
10001930: 00010008 00000000 00010080 00000100    ................
10001940: 00003f00 68606868 09040268 14120b0b    .?..hh`hh.......
10001950: 10010fd3 00200201 00000000 00000000    ...... .........
10001960: 0000009d 00010100 00040000 00000000    ................
10001970: 00000200 00003b00 68506850 04040050    .....;..PhPhP...
10001980: 17150f0b 10010fc1 02100201 0001004d    ............M...
10001990: 00000000 0000009d 00010080 00040000    ................
100019B0: 04040050 17150f0b 10010fb0 02100201    P...............
100019C0: 0001014d 00000000 0000009d 00010200    M...............
100019D0: 00000000 00010000 00000100 00003f00    .............?..
100019E0: 28507850 04040050 17150f0b 10010fa6    PxP(P...........
100019F0: 00164001 00010000 00000000 00000055    [email protected]...
10001A00: 00010080 00000000 10010800 00000100    ................
10001A10: 00003f00 61606132 07050161 06120f2c    .?..2a`aa...,...
10001A20: 10010f94 02100001 0000004d 00000000    ........M.......
10001A30: 0000001d 00010040 00040000 00000000    ....@...........
10001A40: 00000100 00003f00 28507850 04040050    .....?..PxP(P...
10001A50: 06030f0b 10010f83 02100001 0000014d    ............M...
10001A60: 00000000 0000001d 00010100 00000000    ................
10001A70: 00010000 00000100 00003f00 68506850    .........?..PhPh
10001A80: 04040050 16130f0b 10010f79 01161201    P.......y.......
10001A90: 0000004d 00000000 0000001d 00010080    M...............
10001AA0: 00000000 00010000 00000100 00003f00    .............?..
10001AB0: 68506850 04040050 16130f0b 10010f6f    PhPhP.......o...
10001AC0: 00141201 00010000 00000000 0000001d    ................
10001AD0: 00010040 00000000 00010000 00000100    @...............
10001AE0: 00003f00 68506850 04040050 16130f0b    .?..PhPhP.......
10001AF0: 10010f65 001440ef 00010000 00000000    e....@..........
10001B00: 0000005d 00010000 00000000 10010200    ]...............
10001B10: 00000100 00003f00 68506850 04040050    .....?..PhPhP...
10001B20: 06120f0b 10010f5a 001400c2 00000000    ....Z...........
10001B30: 00000000 0000004d 00010000 00000000    ....M...........
10001B40: 10010100 00000100 00003f00 68646c50    .........?..Pldh
10001B50: 08040068 1812010d 10011f4f 001433c2    h.......O....3..
10001B60: 00000000 00000000 0000004d 00010000    ........M.......
10001B70: 00000000 10010100 00000100 00003f00    .............?..
10001B80: 68606850 08040068 1812012d 10011f43    Ph`hh...-...C...
10001B90: 001000c2 00000000 00000000 0000004d    ............M...
10001BA0: 00010100 00000000 10010000 00001100    ................
10001BB0: 00003f00 68566850 08040068 1812012d    .?..PhVhh...-...
10001BC0: 10011f18 001600c0 00000000 00000000    ................
10001BD0: 0000004d 00010080 00000000 10010800    M...............
10001BF0: 1812012d 10011f2d 001608c0 00010000    -...-...........
10001C00: 00000000 0000004d 00010080 00000000    ....M...........
10001C10: 10010800 00000100 00003f00 50502150    .........?..P!PP
10001C20: 08040350 1812010d 10011f02 001600c2    P...............
10001C30: 00000000 00000000 0000004d 00010040    ........M...@...
10001C40: 00000000 00010000 00000500 00003f00    .............?..
10001C50: 68566850 08040068 1812012d 10011f17    PhVhh...-.......
10001C60: 001405c2 00010000 00000000 0000004d    ............M...
10001C70: 00010000 00000000 10010200 00000100    ................
10001C80: 00003f00 68566850 08040068 1812012d    .?..PhVhh...-...
10001C90: 10011f0c 001400c2 00010000 00000000    ................
10001CA0: 0000004d 00010000 00000000 10010200    M...............
10001CC0: 0812012d 10011f01 00461d7f 00001000    -.........F.....
10001CD0: 00000000 0000004d 00010040 00000000    ....M...@.......
10001CE0: 00010000 00000100 00003f00 68646864    .........?..dhdh
10001CF0: 08040068 0412012d 10011eda 00163a20    h...-....... :..
10001D00: 00000000 00000000 00000010 00010040    ............@...
10001D10: 00000000 00010000 00000100 00003f00    .............?..
10001D20: 6c647c6c 0904006c 04120f0b 10010ef3    l|dll...........
10001D30: 00163a20 00010000 00000000 00000010     :..............
10001D40: 00010080 00000000 10010800 00000100    ................
10001D50: 00003f00 6c646c6c 0904046c 14120f0b    .?..lldll.......
10001D60: 10010eeb 02103a20 00000010 00000000    .... :..........
10001D70: 00000010 00010100 00000000 10010000    ................
10001D80: 00001100 00003f00 36363636 09040036    .....?..66666...
10001D90: 04120f0b 10010ee3 00103e20 00010010    ........ >......
10001DA0: 00000000 00000010 00010200 00000000    ................
10001DB0: 10012000 00000100 00003f00 36363636    . .......?..6666
10001DC0: 09040036 16140f0b 10010ed9 02103e00    6............>..
10001DD0: 00015010 00000000 00000091 00010200    .P..............
10001DE0: 00000000 00012000 00000100 00003f00    ..... .......?..
10001DF0: 6c646c6c 0904006c 15140f0b 10010ecf    lldll...........
10001E00: 10203e00 00000000 00000000 00000091    .> .............
10001E10: 00010000 00000400 10014000 00000100    .........@......
10001E20: 00003f00 6c647c6c 0904006c 15140f0b    .?..l|dll.......
10001E30: 10001ec3 02103a20 00005010 00000000    .... :...P......
10001E40: 0000001d 00010100 00000000 10010000    ................
10001E50: 00001100 00003f00 6c647c6c 0804006c    .....?..l|dll...
10001E60: 0804020d 10001a9a 001640c8 00000000    .........@......
10001E70: 00000000 0000004d 00010040 00000000    ....M...@.......
10001E80: 10010000 00000100 00003f00 68566850    .........?..PhVh
10001E90: 0a040068 1612002e 05153005 01013735    h........0..57..
10001EA0: 6d675311 206f6b6d 04484051 6f433049    .Sgmmko [email protected]
10001EB0: 6e61696d 65432064 44470074 21512132    miand Cet.GD2!Q!
10001EC0: 0d015532 51342274 3833314c 0d005241    2U..t"4QL138AR..
10001ED0: 51342254 41333135 32545900 35324135    T"4Q513A.YT25A25
10001EE0: 0c005136 22502132 0e013635 31503532    6Q..2!P"56..25P1
10001EF0: 4e013832 26503132 32470034 32324135    28.N21P&4.G25A22
10001F00: 32455000 30415835 00432633 3533586d    .PE25XA03&C.mX35
10001F10: 3036314c 4d005136 4c342658 35333231    L1606Q.MX&4L1235
10001F20: 18050065 334d3112 45343732 20515900    e....1M3274E.YQ
10001F30: 34364635 00461133 1532586d 3134364c    5F643.F.mX2.L641
10001F40: 0d005505 4c342658 01313211 0d005135    .U..X&4L.21.5Q..
10001F50: 54342658 35333038 58451066 184d2102    X&4T8035f.EX.!M.
10001F60: 053c3730 05335300 31304846 53004f36    07<..S3.FH016O.S
10001F70: 4c460132 40223730 35325300 36304846    2.FL07"@.S25FH06
10001F80: 13004404 4c463132 40303631 6b353220    .D..21FL160@ 25k
10001F90: 00626553 46352653 3933304c 35323050    Seb.S&5FL039P025
10001FA0: 65526b36 22530063 31454635 004a0436    6kRec.S"5FE16.J.
10001FB0: 46353653 0635324c 34372053 6364536b    S65FL25.S 74kSdc
10001FC0: 25235300 35325846 32204736 13623235    .S#%FX256G 252b.
10001FD0: 53017365 4c462122 51323535 15325700    es.S"!FL552Q.W2.
10001FE0: 43303451 22561056 32334135 57015646    Q40CV.V"5A32FV.W
10001FF0: 36503512 00575634 51342257 4a313211    .5P64VW.W"4Q.21J
10002000: 00787876 51343257 46313211 32560076    vxx.W24Q.21Fv.V2
10002010: 35334035 1f565636 65746e55 64646453    [email protected]
10002020: 25237600 00301851 0f020056 00f70f0f    .v#%Q.0.V.......
10002030: 00010100 00010909 0001090a 01010301    ................
10002050: 00010911 00010912 00010913 00010114    ................
10002060: 00011119 0001111a 0001111b 00010000    ................
content (at 0x10089000) not set as written
10089000: Driver Message Block
COMMAND: 00000001 (00000001 was set)
STATUS:  00000000 (00000000 was set)
RESULT:  00000000 (00000000 was set)
Flash Driver V.2 startup failed - rc Ef(50): Flash driver failed to initialize
chip initialization failed - Ef(50): Flash driver failed to initialize
NXP: LPC4370
Connected: was_reset=false. was_stopped=true
Awaiting telnet connection to port 3330 ...
GDB nonstop mode disabled (using allstop mode)
GDB stub (crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
It seems like the LPC18_43_SPIFI_GENERIC is not recognizing my flash, but I'm using one that is in the list for supported flash devices.
Can someone help me, I'm in very needed.
Thank you
luizroque
Hi Alexis, I follow the document, but not help me, I'm getting basically the same error. See below:
MCUXpresso IDE RedlinkMulti Driver v10.2 (Jul 25 2018 11:29:34 - crt_emu_cm_redlink build 555)
Found chip XML file in /Users/luizroque/Documents/MCUXpressoIDE_10.2.1/esu_workspace3/periph_blinky/Debug/LPC4370.xml
Reconnected to existing link server
Connecting to probe 1 core 0:0 (using server started externally) gave 'OK'
Probe Firmware: LPC-Link Probe v1.3 (NXP - LPC-Link)
Serial Number:  WIN64HS12
VID:PID:  1FC9:0009
USB Path:
Using memory from core 0:0 after searching for a good core
debug interface type      = Cortex-M0 (DAP DP ID 0BB11477) over SWD TAP 0
processor type            = Cortex-M0 (CPU ID 00000C20) on DAP AP 0
number of h/w breakpoints = 4
number of flash patches   = 0
number of h/w watchpoints = 2
Probe(0): Connected&Reset. DpID: 0BB11477. CpuID: 00000C20. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FF000: CID B105100D PID 04000BB471 ROM dev (type 0x1)
ROM 1 E000E000: CID B105E00D PID 04000BB008 ChipIP dev SCS (type 0x0)
ROM 1 E0001000: CID B105E00D PID 04000BB00A ChipIP dev DWT (type 0x0)
ROM 1 E0002000: CID B105E00D PID 04000BB00B ChipIP dev FPB (type 0x0)
Inspected v.2 External Flash Device on SPI LPC18_43_SPIFI_GENERIC.cfx
Image 'LPC18/43 Generic SPIFI Jul 25 2018 11:29:55'
Opening flash driver LPC18_43_SPIFI_GENERIC.cfx
Sending VECTRESET to run flash driver
There was a problem after we succesfully downloaded flash driver code to the target, so we are going to compare the flash driver code with the memory where it was loaded.
Note that, after driver initialization, some difference is normal in 'generic' drivers.
Driver from AXF file:
10000000: 23010020 54000045 00001032 10000000     ..#E..T2.......
10000010: 000022cc 10081000 00008000 10081000    ."..............
10000020: 00001000 00000040 1000225c 10000035    ....@...\"..5...
10000030: 00000000 b6720004 f852f000 00062700    ......r...R..'..
10000040: 61676020 8f5ff3bf 2d006965 6127d0fa     `ga.._.ei.-..'a
10000050: d0082e00 60262340 23806123 005b6167    ....@#&`#a.#ga[.
10000060: d1ef429d 2308e7fe d00a421d 68e16860    .B.....#.B..`h.h
10000070: f8e4f000 60202300 d0ed2800 43132201    .....# `.(...".C
10000080: 06ebe7ea 4b14d507 d1012b00 e7f12000    .......K.+... ..
10000090: f8c0f000 2342e7ee d012421d d40807ab    ......B#.B......
100000A0: 2b004b0e 6860d0f2 68a268e1 f90cf000    .K.+..`h.h.h....
100000B0: 6860e7e0 68a268e1 f8ecf000 d0ef2800    ..`h.h.h.....(..
100000C0: 23c0e7d8 421d005b f000d002 e7ddf899    ...#[..B........
100000D0: 23020028 46c0e7cf 10000215 100002c9    (..#...F........
100000E0: f001b570 4b3cfb4b f103483c 781d0118    p...K.<K<H.....x
100000F0: 885c785a eb023304 428b1245 4022f840    Zx\..3..E..B@."@
10000100: 2009d1f5 f99cf001 21094a35 f2f2fbb0    ... ....5J.!....
10000110: 32014605 f0012004 2300f965 21102201    .F.2. ..e..#.".!
10000120: f0012005 2101fabd f000482e 482ef9b5    . .....!.H.....H
10000130: f996f000 f000482b 2800fa7d f04fd047    ....+H..}..(G.O.
10000140: 4a2853a0 48292154 fa88f000 60204c28    .S(JT!)H....(L `
10000150: 28004626 2108d03d f9b2f000 f2f0fbb5    &F.(=..!........
10000160: 32012109 f0012004 2200f93d 46116820    .!.2. ..=.." h.F
10000170: 681b6803 bb484798 210f4602 f0006820    .h.h.GH..F.! h..
10000180: bb18fac7 68202101 f99af000 21034c19    .....! h.....L.!
10000190: 683064a0 f994f000 4f80f5b0 f44fbf28    .d0h.......O(.O.
100001A0: 4a154380 64e3bf28 66204b14 64e0bf38    .C.J(..d.K f8..d
100001B0: 601c6113 68302400 68422101 68126a12    .a.`.$0h.!Bh.j.h
100001C0: 4402e9c3 f000605a 4620f9e9 200dbd70    ...DZ`.... Fp..
100001D0: 2002e7fc bf00e7fa 100017c2 40086000    ... .........`.@
100001E0: 000f4240 40003000 100010b1 1000206c    @[email protected] ..
100001F0: 100020c0 1000225c 10089000 1000224c    . ..\"......L"..
10000200: 4b03b508 f0006818 2000fa09 bf00bd08    ...K.h..... ....
10000210: 100020c0 4c08b538 68202100 f9bef000    . ..8..L.! h....
10000220: 68036820 4798685b b9184605 68202101     h.h[h.G.F...! h
10000230: f9b4f000 bd384628 100020c0 460cb5f8    ....(F8.. .....F
10000240: 46054e12 2054f896 04136e31 2302ea43    .N.F..T 1n..C..#
10000250: 08894313 6202ea43 f0004361 b178f853    .C..C..baC..S.x.
10000260: 21004f0b f0006838 6e32f999 fb023c01    .O.!8h....2n.<..
10000270: 46295204 f0006838 4604fac8 4620b108    .R)F8h.....F.. F
10000280: 2101bdf8 f0006838 e7f8f989 1000225c    ...!8h......\"..
10000290: 100020c0 4605b5f8 4616460f 21004c09    . .....F.F.F.L.!
100002A0: f0006820 4629f97b 4632463b f0006820     h..{.)F;F2F h..
100002B0: 4605fa79 2101b918 f0006820 4628f96f    y..F...! h..o.(F
100002C0: bf00bdf8 100020c0 b5704b0d 460d6c5e    ..... ...Kp.^l.F
100002D0: 46144286 221cd111 f0014621 b108fa51    .B.F..."!F..Q...
100002E0: bd70200a 0220f1a5 0120f104 0020f106    . p... ... ... .
100002F0: fa46f001 d0f42800 460ae7f2 e7f74621    ..F..(.....F!F..
10000300: 1000225c 4ff0e92d 0ff0e8b0 d1124294    \"..-..O.....B..
10000310: d1104295 d10e4296 d10c4297 d10a4590    .B...B...B...E..
10000320: d1084591 d1064592 d1044593 d1eb3908    .E...E...E...9..
10000330: e8bd2000 20018ff0 8ff0e8bd 310478ca    . ..... .....x.1
10000340: f0431cd3 f443431f 60431300 f8017d03    ..C..CC...C`.}..
10000350: 7d033c04 3c03f801 f8017d03 440a3c02    .<.}...<.}...<.D
10000360: d1034291 079b69c3 4770d4fc f8017d03    .B...i....pG.}..
10000370: e7f53b01 b5f02300 b0874605 3003f88d    .;...#...F.....0
10000380: 300ff88d 460e680b 4b34691c 2c004669    ...0.h.F.i4KiF.,
10000390: 461cbf08 466947a0 47a04628 4628a903    ...F.GiF(F.G..(F
100003A0: f89d47a0 f89d1000 428b300c f89dd10b    .G.......0.B....
100003B0: f89d7001 42bb300d f89dd105 f89d2002    .p...0.B..... ..
100003C0: 4293300e 2000d002 bdf0b007 685b6833    .0.B... ....3h[h
100003D0: 28006858 6803d0f7 c004f893 d107458c    Xh.(...h.....E..
100003E0: c005f893 d10345bc c006f893 d0034594    .....E.......E..
100003F0: e7ee6840 e0126840 2b0079db 4628d0e4    @[email protected].+..(F
10000400: 3003f88d 47a04669 f89d6833 685b4000    ...0iF.G3h...@[h
10000410: 5001f89d f89d6858 f89d6002 28001003    ...PXh...`.....(
10000420: 6803d0d1 42a2791a 795ad1e4 d1e142aa    ...h.y.B..Zy.B..
10000430: 42b2799a 79dad1de d1db4291 d0c32900    .y.B...y.B...)..
10000440: 33082200 d2bf428a 0c02eb0d 7b01f813    .".3.B.........{
10000450: c004f89c d1cd45bc e7f33201 1000033d    .....E...2..=...
10000460: 4780b508 4b04b138 6058685a 4a036042    ...G8..KZhX`B`.J
10000470: 33016813 bd086013 100020c8 100020c4    .h.3.`... ... ..
10000480: 685a6803 60486850 68da6051 68132000    .hZhPhH`Q`.h. .h
10000490: 60133301 00004770 2310b171 69c361c3    .3.`pG..q..#.a.i
100004A0: 0310f013 60c3d1fb 23106183 69c361c3    .......`.a.#.a.i
100004B0: d4fc06db 60034b01 47702000 600f03e8    .....K.`. pG...`
100004C0: 6843b911 47706858 d1042901 e9d36843    ..ChXhpG.)..Ch..
100004D0: 43502002 29024770 6843d102 47706898    . PCpG.)..Ch.hpG
100004E0: d1022903 68d86843 29044770 6843d102    .)..Ch.hpG.)..Ch
100004F0: 47706918 d1022905 69586843 29064770    .ipG.)..ChXipG.)
10000500: 6843d102 47706998 d1022907 69d86843    ..Ch.ipG.)..Ch.i
10000510: 29084770 6843d106 f8936a1b 481b3028    pG.)..Ch.j..(0.H
10000520: 47704358 d1042909 6a1b6843 3029f893    XCpG.)..Ch.j..)0
10000530: 290ae7f5 6843d104 f8936a1b e7ee302a    ...)..Ch.j..*0..
10000540: d104290b 6a1b6843 302bf893 290ce7e7    .)..Ch.j..+0...)
10000550: 6843d104 f8936a1b e7e0302c d102290d    ..Ch.j..,0...)..
10000560: 6a1b6843 290ee7c4 2101d103 69db6803    Ch.j...)...!.h.i
10000570: 290f4718 6803d103 69db2100 2910e7f8    .G.)...h.!.i...)
10000580: 6843bf06 20006a58 bf004770 000f4240    ..ChXj. pG..@B..
10000590: 681b6843 f00069d8 47700001 b5372310    Ch.h.i....pG.#7.
100005A0: 68146842 69e361e3 d4fc06dd 06db69e3    Bh.h.a.i.....i..
100005B0: 6a52d4fc 07556823 f023d513 60235380    ..Rj#hU...#..S#`
100005C0: 6803b1a1 6b9d466a 47a8ab01 60e39b01    ...hjF.k...G...`
100005D0: 60639b00 079169e2 61a3d4fc b0032000    ..c`.i.....a. ..
100005E0: 07d5bd30 f043bf48 e7e85380 60e323ff    0...H.C..S...#.`
100005F0: 61a12310 69e361e3 d4fc06da 06db69e3    .#.a.a.i.....i..
10000600: e7ebd4fc 4604b510 21016803 47986a5b    .......F.h.![j.G
10000610: 46202100 ffc2f7ff bd102000 4604b510    .! F..... .....F
10000620: 21006803 47986a5b 46202101 ffb6f7ff    .h.![j.G.! F....
10000630: bd102000 4605b538 685c4b07 4620b90c    . ..8..F.K\h.. F
10000640: 4621bd38 f7ff4628 b908fe95 e7f56864    8.!F(F......dh..
10000650: 68986823 e7f33040 100020c8 43f8e92d    #h.h@0... ..-..C
10000660: 07834699 460e4604 46074690 2400d003    .F...F.F.F.F...$
10000670: e8bd4620 4b2583f8 2d00685d 4629d0f7     F....%K]h.-..)F
10000680: f7ff4640 2800fe77 686dd138 f807e7f5    @F..w..(8.mh....
10000690: 42be3b01 6801d1fb 030cf104 1d0b6063    .;.B...h....c`..
100006A0: f10463e3 e9c40340 8a8b3802 9010f8c4    [email protected]......
100006B0: 698b6163 61a3464a 46208b8b 8bcb61e3    ca.iJF.a.. F.a..
100006C0: 8c0b6223 6a4b6263 310ae9c4 4641680b    #b..cbKj...1.hAF
100006D0: 682b6363 4798695b f8846865 f8950038    cc+h[i.Geh..8...
100006E0: 2b00302c 4620d1c3 ff8cf7ff f8856863    ,0.+.. F....ch..
100006F0: f893002c 2b00302c e7b8d0ba 6899682b    ,...,0.+....+h.h
10000700: 428e3140 4426d3b3 e7c22300 100020c8    @1.B..&D.#... ..
10000710: 41f0e92d f011460c 4606010f d02d4617    -..A.F.....F.F-.
10000720: ff36f7ff 46806872 6a536a10 f0236900    ..6.rh.F.jSj.i#.
10000730: 6253030f b10f4001 6253430b 463a6833    [email protected]:F
10000740: 46306b5b 46414798 46304605 040ff024    [k0F.GAF.F0F$...
10000750: ff24f7ff 6a136872 ea34691b d1120303    ..$.rh.j.i4.....
10000760: b16f6a53 62534323 6b5d6833 463ab15d    Sjo.#CSb3h]k].:F
10000770: 46304621 e8bd462b 471841f0 e7e92503    !F0F+F...A.G.%..
10000780: 0304ea23 4628e7ef 81f0e8bd 68586843    #.....(F....ChXh
10000790: 68d91a08 fbb0689b 4283f0f1 f04fbf98    ...h.h.....B..O.
100007A0: 477030ff 43f8e92d 460f4606 461d4690    .0pG-..C.F.F.F.F
100007B0: b1052000 e8bdb108 687383f8 699c4642    . ........shBF.i
100007C0: 42ac6833 462cbf28 9010f8d3 46234639    3h.B(.,F....9F#F
100007D0: 47c84630 0303f024 44984427 e7e81b2d    0F.G$...'D.D-...
100007E0: b5706843 188e689b 4605429e d908460c    Chp..h...B.F.F..
100007F0: e009200b 4621682b 4628689b b9184798    . ..+h!F.h(F.G..
10000800: 42a63401 2000d1f6 b538bd70 f7ff4605    .4.B... p.8..F..
10000810: 4604ffbd 46284611 ffb8f7ff d0091c62    ...F.F(F....b...
10000820: d0071c43 1b121c42 46284621 4038e8bd    C...B...!F(F..8@
10000830: bfd6f7ff bd38200b 079b69c3 4770d4fc    ..... 8..i....pG
10000840: 62c4f04f f7ff6042 b510bff7 68234604    O..bB`.......F#h
10000850: 6adb4620 07c34798 bd10d4f9 b5706803     F.j.G.......hp.
10000860: 460e6adb 46154604 23014798 f106fa03    .j.F.F.F.G.#....
10000870: 4301b135 46206823 4070e8bd 47186b1b    5..C#h [email protected]
10000880: 0101ea20 b508e7f6 6adb6803 f0104798     ........h.j.G..
10000890: bf0c0f1c 0001f000 bd082005 6843b508    ......... ....Ch
100008A0: 4b0c6819 604b4608 b2d27d0a ffc4f7ff    .h.K.FK`.}......
100008B0: 604b4b09 ea427d0b f7ff2203 0691ffbd    .KK`.}B.."......
100008C0: f042bf48 06537200 f042bf48 f0227280    H.B..rS.H.B..r".
100008D0: bd080060 05200001 35200001 46112200    `..... ... 5.".F
100008E0: b5706843 4e09681c 5d934d09 ea4500d0    Chp..h.N.M.]..E.
100008F0: 60636303 40837d23 43194620 ff9cf7ff    .cc`#}.@ F.C....
10000900: 2a033201 4608d1f1 bf00bd70 10001e98    .2.*...Fp.......
10000910: 00200001 46112200 b5706843 4e09681c    .. ..".FChp..h.N
10000920: 5d934d09 ea4500d0 60636303 40837d23    .M.]..E..cc`#}.@
10000930: 43194620 ff80f7ff 2a033201 4608d1f1     F.C.....2.*...F
10000940: bf00bd70 10001e9b 00200001 6843b508    p......... ...Ch
10000950: 4b046818 7d026043 f7ffb2d2 4610ff6d    .h.KC`.}....m..F
10000960: bf00bd08 05200001 6843b508 4b08681a    ...... ...Ch.h.K
10000970: 60534610 b2c97d11 ff5ef7ff 60534b05    .FS`.}....^..KS`
10000980: ea417d13 f7ff2103 4608ff57 bf00bd08    .}A..!..W..F....
10000990: 05200001 35200001 00004770 68186843    .. ... 5pG..Ch.h
100009A0: 60434b01 bf48f7ff 30200000 6843b538    .KC`..H... 08.Ch
100009B0: 681c4605 f7ff4620 4b07ff43 b2cb6063    .F.h F..C..Kc`..
100009C0: 2107f3c1 75217523 ff36f7ff e8bd4628    ...!#u!u..6.(F..
100009D0: f7ff4038 bf00bf3a 01208002 6843b538    8@..:..... .8.Ch
100009E0: 681c4605 f7ff4620 4b08ff2b b2cb6063    .F.h F..+..Kc`..
100009F0: f3c17523 f3c12307 75234107 f7ff7521    #u...#...A#u!u..
10000A00: 4628ff1b 4038e8bd bf1ff7ff 01208003    ..(F..8@...... .
10000A10: 6843b538 681c4605 f7ff4620 4b05ff11    8.Ch.F.h F.....K
10000A20: 6063b2c9 f7ff7521 4628ff07 4038e8bd    ..c`!u....(F..8@
10000A30: bf0bf7ff 01208001 43f8e92d 46066843    ...... .-..CCh.F
10000A40: 460f681d f7ff4628 2400fefb 9034f8df    .h.F(F.....$..4.
10000A50: 8034f8df f7ff4628 f814fef3 ea483009    ..4.(F.......0H.
10000A60: 606b6303 fa2700e3 b2dbf303 f7ff752b    .ck`..'.....+u..
10000A70: 3401fee3 f7ff4630 2c03fee8 e8bdd1ea    ...40F.....,....
10000A80: bf0083f8 10001e9e 00208001 0f0cf011    .......... .....
10000A90: d003b508 2106b2d2 fee0f7ff bd082000    .......!..... ..
10000AA0: 47702000 0f0cf011 d003b508 2109b2d2    . pG...........!
10000AB0: fed4f7ff bd082000 0f0cf011 d018b510    ..... ..........
10000AC0: b2d26843 2109681c fec8f7ff f7ff4620    Ch...h.!.... F..
10000AD0: f04ffeb3 606363c4 feaef7ff 60634b06    ..O..cc`.....Kc`
10000AE0: 752323ab fea8f7ff 60634b04 f7ff7d23    .##u.....Kc`#}..
10000AF0: 2000fea3 bf00bd10 81208001 85200001    ... ...... ... .
10000B00: 47702000 4604b510 6803b141 47986adb    . pG...FA..h.j.G
10000B10: f4206823 6b1b2170 47984620 bd102000    #h .p!.k F.G. ..
10000B20: 4604b510 6803b141 47986adb f4206823    ...FA..h.j.G#h .
10000B30: 6b1b4180 47984620 bd102000 4604b510    .A.k F.G. .....F
10000B40: 6803b139 47986adb 3100f440 f7ff4620    [email protected] F..
10000B50: 2000ff45 0000bd10 21ffb10b 68436019    E.. .......!.`Ch
10000B60: 07596a5b 4b04d502 47706013 bf4c07db    [jY....K.`pG..L.
10000B70: 4b034b02 bf00e7f8 eb930000 bb910000    .K.K............
10000B80: 0b810000 21ffb10b 68436019 075b6a5b    .......!.`Ch[j[.
10000B90: 4b02bf4c 60134b02 bf004770 eb950000    L..K.K.`pG......
10000BA0: 0b810000 21ffb10b 68436019 07596a5b    .......!.`Ch[jY.
10000BB0: 4b04d502 47706013 bf4c07db 4b034b02    ...K.`pG..L..K.K
10000BC0: bf00e7f8 ecb30000 bcb10000 0ca10000    ................
10000BD0: 6a5b6843 bf4c071b 4b024b01 4770600b    Ch[j..L..K.K.`pG
10000BE0: 32888000 02808000 6a5b6843 bf4c071b    ...2....Ch[j..L.
10000BF0: 4b024b01 4770600b 34a88000 12a08000    .K.K.`pG...4....
10000C00: 6a5b6843 bf4c071b 4b024b01 4770600b    Ch[j..L..K.K.`pG
10000C10: 38908000 02808000 b5f8e7fe 46066803    ...8.........h.F
10000C20: 460f6adb f0104798 46057440 f010d00c    [email protected]....
10000C30: bf187480 01822410 f044bf48 b11f0420    .t...$..H.D. ...
10000C40: 46306833 47986a9b 031cf015 2b1cd005    3h0F.j.G.......+
10000C50: f044bf0c f0440404 07eb0408 f044bf48    ..D...D.....H.D.
10000C60: 46200401 2901bdf8 4604b538 d815460d    .. F...)8..F.F..
10000C70: 6adb6803 f0004798 b945031c 6823b12b    .h.j.G....E.+.#h
10000C80: 011cf020 46206b1b 20004798 2b1ce007     ....k F.G. ...+
10000C90: 6823d0fb 011cf040 e7f46b1b bd382003    ..#[email protected]... 8.
10000CA0: b5706843 681c4606 fdedf7ff b9484605    Chp..F.h.....FH.
10000CB0: f7ff4620 4b04fdc5 f7ff6063 4630fdbd     F.....Kc`....0F
10000CC0: fdc3f7ff bd704628 c7200000 e92d6843    ....(Fp... .Ch-.
10000CD0: 689a41f0 428a4604 d92d4688 f7ff681e    .A.h.F.B.F-..h..
10000CE0: 4605fdd2 6863bb28 68df4620 fb076823    ...F(.ch F.h#h..
10000CF0: 6a9bf708 46304798 fda2f7ff 60b76863    ...j.G0F....ch.`
10000D00: 691b6a1b bf4c061b 4b0d4b0c f7ff6073    .j.i..L..K.Ks`..
10000D10: 6863fd93 f4166a5e d10a3680 f7ff4620    ..ch^j...6.. F..
10000D20: 4631fd94 f7ff4620 f010ff78 bf180f20    ..1F F..x... ...
10000D30: 46282507 81f0e8bd e7fa250b dca00000    .%(F.....%......
10000D40: d8800000 47f3e92d 6843461c 699a4617    ....-..G.FCh.F.i
10000D50: 42a24605 d34e4689 f7ff681e 4680fd94    .F.B.FN..h.....F
10000D60: 682bb9d8 6bdba901 47984628 d02907a3    ..+h...k(F.G..).
10000D70: 4628682b 47986a9b f7ff4630 9b01fd61    +h(F.j.G0F..a...
10000D80: 9008f8c6 60734323 f817443c 42a73b01    ....#Cs`<D...;.B
10000D90: d1fa7533 f7ff4630 686bfd4f f4146a5c    3u..0F..O.kh\j..
10000DA0: d10b3480 f7ff4628 4621fd50 f7ff4628    .4..(F..P.!F(F..
10000DB0: f010ff34 bf180f10 0806f04f b0024640    4.......O...@F..
10000DC0: 87f0e8bd 0a94ea5f 9b01d0e7 0403f024    ...._.......$...
10000DD0: 682b431c 6a9b4628 46304798 fd30f7ff    .C+h(F.j.G0F..0.
10000DE0: 0a8aeb07 9008f8c6 f8576074 45573b04    ........t`W..;WE
10000DF0: d1fa6173 f04fe7ce e7df0809 47f3e92d    sa....O.....-..G
10000E00: 6843461f 681d4688 461669db d33642bb    .FCh.F.h.i.F.B6.
10000E10: ea4f6803 f8d30997 2300a038 4619aa01    .hO.....8..#...F
10000E20: 0403f007 f1b947d0 d0130f00 9b0122ff    .....G......."..
10000E30: 0703f027 60ea433b 0989eb06 8008f8c5    '...;C.`........
10000E40: 606b44b8 f846696b 454e3b04 4628d1fa    .Dk`kiF..;NE..(F
10000E50: fcf2f7ff 22ffb1ac 60ea9b01 f8c54323    ......."...`#C..
10000E60: 44348008 7d2b606b 3b01f806 d1fa42b4    ..4Dk`+}...;.B..
10000E70: f7ff4628 2000fce1 e8bdb002 200b87f0    (F..... .......
10000E80: 4620e7fa 2003e7f8 00004770 4a4d4b4c    .. F... pG..LKMJ
10000E90: 601ab530 605a4a4c 609a4a4c 60da4a4c    0..`LJZ`LJ.`LJ.`
10000EA0: 611a4a4c 615a4a4c 619a4a4c 61da4a4c    LJ.aLJZaLJ.aLJ.a
10000EB0: 621a2200 6a126842 402df892 d05a2c01    .".bBh.j..-@.,Z.
10000EC0: d05a2c02 d05a2c03 4d474946 bf182c00    .,Z..,Z.FIGM.,..
10000ED0: f8924629 6259402e d0522c05 4d424943    )F...@Yb.,R.CIBM
10000EE0: bf182c04 f8924629 6299402f d04a2c06    .,..)F../@.b.,J.
10000EF0: d04a2c07 d04a2c08 d04a2c09 4d3a493c    .,J..,J..,J.<I:M
10000F00: bf182c0a f8924629 62d94030 d0422c0b    .,..)[email protected].,B.
10000F10: d0422c0c d0422c0d 4d334936 bf182c0e    .,B..,B.6I3M.,..
10000F20: 63194629 4031f892 d03a2c0f d03a2c10    )F.c..1@.,:..,:.
10000F30: d03a2c11 4d2c4930 bf182c12 63594629    .,:.0I,M.,..)FYc
10000F40: 4032f892 d0322c13 d0322c14 4d26492b    ..2@.,2..,2.+I&M
10000F50: bf182c15 63994629 1033f892 d02a2916    .,..)F.c..3..)*.
10000F60: d02a2917 4c204a26 bf182918 63da4622    .)*.&J L.).."F.c
10000F70: 20006003 4923bd30 4923e7ab 4923e7a9    .`. 0.#I..#I..#I
10000F80: 4923e7a7 4923e7af 4923e7bd 4923e7bb    ..#I..#I..#I..#I
10000F90: 4923e7b9 4923e7b7 4923e7c3 4923e7c1    ..#I..#I..#I..#I
10000FA0: 4923e7bf 4923e7cb 4923e7c9 4923e7c7    ..#I..#I..#I..#I
10000FB0: 4923e7d1 4a23e7cf 4a23e7d9 bf00e7d7    ..#I..#J..#J....
10000FC0: 10002204 10000c67 10000ca1 10000ccd    ."..g...........
10000FD0: 1000104d 10000d45 10000dfd 10000e87    M...E...........
10000FE0: 10000c1b 10000b01 10000c19 10000999    ................
10000FF0: 100008dd 10000a39 10000aa1 10000ba5    ....9...........
10001000: 10000c01 10000b05 10000b21 10000b3d    ........!...=...
10001010: 1000099d 1000089d 10000915 1000094d    ............M...
10001020: 10000969 100009ad 100009dd 10000a11    i...............
10001030: 10000ab9 10000aa5 10000a8d 10000b59    ............Y...
10001040: 10000b85 10000bd1 10000be9 e92d6843    ............Ch-.
10001050: 691a41f0 428a4604 d9274688 f7ff681e    .A.i.F.B.F'..h..
10001060: 4605fc12 6863b9f8 695f4620 fb076823    ...F..ch F_i#h..
10001070: 6a9bf708 46304798 fbe2f7ff 5302f04f    ...j.G0F....O..S
10001080: 607360b7 fbd8f7ff 6a5b6863 d40a03db    .`s`....ch[j....
10001090: f7ff4620 4629fbda f7ff4620 f010fdbe     F....)F F......
100010A0: bf180f20 46282507 81f0e8bd e7fa250b     ....%(F.....%..
100010B0: b510496e 2a00680a 80d5f040 486d4b6c    nI...h.*@...lKmH
100010C0: e9c34c6d e9c32102 60424000 611a4c6b    mL...!...@B`kL.a
100010D0: 496c4a6b 6023615a 46204b6b f7ff600b    kJlIZa#`kK F.`..
100010E0: 496af9cf 46204b6a f7ff600b 4969f9c9    ..jIjK F.`....iI
100010F0: 46204b69 f7ff600b 4968f9c3 46204b68    iK F.`....hIhK F
10001100: f7ff600b 4967f9bd 46204b67 f7ff600b    .`....gIgK F.`..
10001110: 4966f9b7 46204b66 f7ff600b 4965f9b1    ..fIfK F.`....eI
10001120: 46204b65 f7ff600b 4964f9ab 46204b64    eK F.`....dIdK F
10001130: f7ff600b 4963f9a5 46204b63 f7ff600b    .`....cIcK F.`..
10001140: 4962f99f 46204b62 f7ff600b 4961f999    ..bIbK F.`....aI
10001150: 46204b61 f7ff600b 4960f993 46204b60    aK F.`....`I`K F
10001160: f7ff600b 495ff98d 46204b5f f7ff600b    .`...._I_K F.`..
10001170: 495ef987 46204b5e f7ff600b 495df981    ..^I^K F.`....]I
10001180: 46204b5d f7ff600b 495cf97b 46204b5c    ]K F.`..{.\I\K F
10001190: f7ff600b 495bf975 46204b5b f7ff600b    .`..u.[I[K F.`..
100011A0: 495af96f 46204b5a f7ff600b 4959f969    o.ZIZK F.`..i.YI
100011B0: 46204b59 f7ff600b 4958f963 46204b58    YK F.`..c.XIXK F
100011C0: f7ff600b 4957f95d 46204b57 f7ff600b    .`..].WIWK F.`..
100011D0: 4956f957 46204b56 f7ff600b 4955f951    W.VIVK F.`..Q.UI
100011E0: 46204b55 f7ff600b 4954f94b 46204b54    UK F.`..K.TITK F
100011F0: f7ff600b 4953f945 46204b53 f7ff600b    .`..E.SISK F.`..
10001200: 4952f93f 46204b52 f7ff600b 4951f939    ?.RIRK F.`..9.QI
10001210: 46204b51 f7ff600b 4950f933 46204b50    QK F.`..3.PIPK F
10001220: f7ff600b 494ff92d 46204b4f f7ff600b    .`..-.OIOK F.`..
10001230: 494ef927 46204b4e f7ff600b 494df921    '.NINK F.`..!.MI
10001240: 46204b4d f7ff600b 494cf91b 46204b4c    MK F.`....LILK F
10001250: f7ff600b 494bf915 46204b4b f7ff600b    .`....KIKK F.`..
10001260: 4620f90f 2000bd10 bf00e7fc 100021d8    .. F... .....!..
10001270: 100021ec 100021e4 10001ea1 100021dc    .!...!.......!..
10001280: 10000e8d 100020d0 100017e4 100020d8    ..... ....... ..
10001290: 10001818 100020e0 1000184c 100020e8    ..... ..L.... ..
100012A0: 10001880 100020f0 100018b4 100020f8    ..... ....... ..
100012B0: 100018e8 10002100 1000191c 10002108    .....!.......!..
100012C0: 10001950 10002110 10001984 10002118    P....!.......!..
100012D0: 100019b8 10002120 100019ec 10002128    .... !......(!..
100012E0: 10001a20 10002130 10001a54 10002138     ...0!..T...8!..
100012F0: 10001a88 10002140 10001abc 10002148    ....@!......H!..
10001300: 10001af0 10002150 10001b24 10002158    ....P!..$...X!..
10001310: 10001b58 10002160 10001b8c 10002168    X...`!......h!..
10001320: 10001bc0 10002170 10001bf4 10002178    ....p!......x!..
10001330: 10001c28 10002180 10001c5c 10002188    (....!..\....!..
10001340: 10001c90 10002190 10001cc4 10002198    .....!.......!..
10001350: 10001cf8 100021a0 10001d2c 100021a8    .....!..,....!..
10001360: 10001d60 100021b0 10001d94 100021b8    `....!.......!..
10001370: 10001dc8 100021c0 10001dfc 100021c8    .....!.......!..
10001380: 10001e30 100021d0 10001e64 737af44f    0....!..d...O.zs
10001390: 9301b082 699a4b0c f0226998 42880102    .....K.i.i"....B
100013A0: bf18480a 68006199 f0224909 42880203    .H...a.h.I"....B
100013B0: f042bf88 619a0204 1e5a9b01 2b009201    ..B....a..Z....+
100013C0: b002d1fa bf004770 40050000 100017e0    ....pG.....@....
100013D0: 01312cff 6c534a02 0301f043 47706453    .,1..JSlC...SdpG
100013E0: 40050000 f1030083 f5034380 291123a0    [email protected]...#.)
100013F0: 6c9cb510 3a01d00f ea410609 4a080182    ...l...:..A....J
10001400: 6100f441 4a075c10 0280ea42 0402ea24    A..a.\.JB...$...
10001410: 64994321 f044bd10 649c0401 bf00e7fa    !C.d..D....d....
10001420: 1000202a 1f000001 30124b04 0020f853    * .......K.0S. .
10001430: bf5407c3 6004f3c0 47702011 40050000    ..T....`. pG...@
10001440: d83b2810 f000e8df 180e0c09 28263a23    .(;.........#:&(
10001450: 3a3a2d2a 3634322f f44f0038 47704000    *-::/2468.O..@pG
10001460: 47704817 48184b17 312cf8d3 0307f003    .HpG.K.H..,1....
10001470: bf082b04 47702000 4a144b12 312cf8d3    .+... pG.K.J..,1
10001480: f0034811 2b040307 4610bf08 4b104770    .H.....+...FpG.K
10001490: 47706818 e7fb4b0f e7f94b0f 68584b0e    .hpG.K...K...KXh
100014A0: f0004770 2000b8b7 b8e2f000 e7fb2001    pG..... ..... ..
100014B0: e7f92002 e7f72003 e7f52004 47702000    . ... ... ... pG
100014C0: 00b71b00 40043000 017d7840 02faf080    .....0.@@x}.....
100014D0: 100017dc 100017e0 10002244 b5f723fa    ........D"...#..
100014E0: 4605460c f7ff9301 4b1affab 6c5b4360    .F.F.......K`C[l
100014F0: f0233c01 ea4353f8 4b176205 4a174013    .<#[email protected]
10001500: d8194290 21002501 fb070047 4296f605    .B...%.!G......B
10001510: ea43d90f f0434304 ea430340 4a0d2301    [email protected]..#.J
10001520: 0301f023 9b016453 92011e5a d1fa2b00    #...Sd..Z....+..
10001530: 3101e00d e7e8006d 42904a09 ea43d804    ...1m....J.B..C.
10001540: f0434304 e7ea03c0 ff44f7ff b0032000    .CC.......D.. ..
10001550: bf00bdf0 40050000 ff00cc3d 094c5eff    .......@=....^L.
10001560: 1312cfff 43f8e92d 46064691 4698460f    ....-..C.F.F.F.F
10001570: ff66f7ff 3ffff1b9 fbb9d02e fb01f1f0    ..f....?........
10001580: 42a7f400 4b21d817 d814429c bf2c45a0    ...B..!K.B...E,.
10001590: 25004625 42a74404 0301f101 4a1bd81a    %F.%.D.B.......J
100015A0: d8174294 d31545a0 b94cb13d e8bd4630    .B...E..=.L.0F..
100015B0: f7ff43f8 2500bf93 b16ce7ec e7f54619    .C.....%..l..F..
100015C0: 0505eba9 0409eba4 d9f742a5 b1cae7ee    .........B......
100015D0: e7eb4611 d1e92d00 f4f0fbb7 f3f0fbb8    .F...-..........
100015E0: fb042200 490af500 d30642bd d8044545    .".....I.B..EE..
100015F0: 3cfff105 bf98458c 429c4622 d2e64405    ...<.E.."F.B.D..
10001600: e7f13401 e8bd4610 bf0083f8 0aba9500    .4...F..........
10001610: 0aba94ff 4d14b537 f3c46c6c f7ff6003    ....7..Mll...`..
10001620: 4b12ff0f 6c2b9301 0301f013 f3c4d019    ...K..+l........
10001630: a9022301 f813440b f3c41c04 33013301    .#...D.......3.3
10001640: f0f3fbb0 f3c409a3 ea434207 07e314d4    .........BC.....
10001650: 0201f102 004bbf5c f2f3fbb2 b0034350    ....\.K.....PC..
10001660: 4618bd30 bf00e7fb 40050000 08040201    0..F.......@....
10001670: 4604b538 fed8f7ff f1044b07 f8530212    8..F.....K....S.
10001680: f7ff5022 4b05fedd ea035d1b 33010395    "P.....K.].....3
10001690: f0f3fbb0 bf00bd38 40050000 1000202a    ....8......@* ..
100016A0: 0084b530 4480f104 24a0f504 6de5281b    0......D...$.(.m
100016B0: 2911d80d 4808d00a b10a4028 6000f440    ...)...H(@..@..`
100016C0: f040b10b ea400001 65e06001 f045bd30    ..@...@..`.e0.E.
100016D0: 65e50501 bf00e7fa e0fff7fe 63faf44f    ...e........O..c
100016E0: 2806b573 460d4604 93014616 f7ffd101    s..(.F.F.F......
100016F0: 2300fe4d 46212201 f7ff2004 4b17ffd1    M..#."!F. .....K
10001700: d90a429d 4916461a f7ff4620 2300ff2b    .B...F.I F..+..#
10001710: 21092201 f7ff2004 9b01ffc3 92011e5a    .".!. ......Z...
10001720: d1fa2b00 462b490f 6809462a f7ff4620    .+...I+F*F.h F..
10001730: b12eff19 f1044c0c 34040540 d10142ac    [email protected]..
10001740: bd70b002 3c01f814 2c02f814 1c03f814    ..p....<...,....
10001750: 0c04f814 ffa4f7ff bf00e7ef 068e7780    .............w..
10001760: 00b71b00 100017e0 10002030 49022201    ........0 ...".I
10001770: f7ff4610 bf00bfb3 0aba9500 bff6f7ff    .F..............
10001780: 0301ea40 b570079b 4604d10c 2a03460b    @.....p....F.F.*
10001790: 46204619 6806d906 3404680d f10342ae    .F F...h.h.4.B..
100017A0: d0040304 4291440a 2000d103 3a04e008    .....D.B... ...:
100017B0: f810e7ed f8113b01 42a34b01 1b18d0f3    .....;...K.B....
100017C0: 0303bd70 040300f3 050300f3 060300f3    p...............
100017D0: 070300f3 080300f3 000000f3 00000000    ................
100017E0: 00b71b00 10002021 001440ef 00000000    ....! ...@......
100017F0: 00000000 0001005d 00000010 00010000    ....]...........
10001800: 10000100 00000100 00003f00 68686868    .........?..hhhh
10001810: 09040268 16130f0b 1000200e 001940ef    h........ ...@..
10001820: 00000000 00000000 000100dd 00000200    ................
10001830: 00010000 10002000 00000100 00003f00    ..... .......?..
10001840: 68686868 09040268 17150f0b 10002004    hhhhh........ ..
10001850: 001840ef 00000000 00000000 0001005d    .@..........]...
10001860: 00000100 00010000 10001000 00000100    ................
10001870: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10001880: 10001ff8 001870ef 00000000 00000000    .....p..........
10001890: 0001005d 00000100 00010000 10001000    ]...............
100018A0: 00000100 00003f00 68686868 09040268    .....?..hhhhh...
100018B0: 16130f0b 10001fef 001740ef 00000000    .........@......
100018C0: 00000000 0001005d 00000080 00010000    ....]...........
100018D0: 10000800 00000100 00003f00 68686868    .........?..hhhh
100018E0: 09040268 16130f0b 10001fe6 001640ef    h............@..
100018F0: 00000000 00000000 0001005d 00000040    ........]...@...
10001900: 00010000 10000400 00000100 00003f00    .............?..
10001910: 68686868 09040268 16130f0b 10001fdd    hhhhh...........
10001920: 001340ef 00000000 00000000 0001005d    .@..........]...
10001930: 00000008 00010000 10000080 00000100    ................
10001940: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10001950: 10001fd3 00200201 00000000 00000000    ...... .........
10001960: 0001009d 00000100 00040000 00000000    ................
10001970: 00000200 00003f00 68506850 06050050    .....?..PhPhP...
10001980: 17150f0b 10001fc1 02190201 0000004d    ............M...
10001990: 00000000 0001009d 00000080 00040000    ................
100019A0: 00000000 00000100 00003f00 68506850    .........?..PhPh
100019B0: 06050050 17150f0b 10001fb0 02190201    P...............
100019C0: 0000014d 00000000 0001009d 00000200    M...............
100019D0: 00010000 00000000 00000100 00003f00    .............?..
100019E0: 68506850 06050050 17150f0b 10001fa6    PhPhP...........
100019F0: 00174001 00000000 00000000 00010055    [email protected]...
10001A00: 00000080 00010000 10000800 00000100    ................
10001A10: 00003f00 61616132 07040161 16130f0c    .?..2aaaa.......
10001A20: 10001f94 02182001 0000004d 00000000    ..... ..M.......
10001A30: 0001001d 00000040 00040000 00000000    ....@...........
10001A40: 00000100 00003f00 68506850 06050050    .....?..PhPhP...
10001A50: 16130f0b 10001f83 02182001 0000014d    ......... ..M...
10001A60: 00000000 0001001d 00000100 00010000    ................
10001A70: 00000000 00000100 00003f00 68506850    .........?..PhPh
10001A80: 06050050 16130f0b 10001f79 01160201    P.......y.......
10001A90: 0000004d 00000000 0001001d 00000080    M...............
10001AA0: 00010000 00000000 00000100 00003f00    .............?..
10001AB0: 68506850 06050050 16130f0b 10001f6f    PhPhP.......o...
10001AC0: 00150201 00000000 00000000 0001001d    ................
10001AD0: 00000040 00010000 00000000 00000100    @...............
10001AE0: 00003f00 68506850 06050050 16130f0b    .?..PhPhP.......
10001AF0: 10001f65 001540ef 00000000 00000000    e....@..........
10001B00: 0001005d 00000020 00010000 10000200    ]... ...........
10001B10: 00000100 00003f00 68506850 06040050    .....?..PhPhP...
10001B20: 16130f0b 10001f5a 001420c2 00000000    ....Z.... ......
10001B30: 00000000 0001004d 00000010 00010000    ....M...........
10001B40: 10000100 00000100 00003f00 686c6c50    .........?..Pllh
10001B50: 08040068 1813110d 10001f4f 001423c2    h.......O....#..
10001B60: 00000000 00000000 0001004d 00000010    ........M.......
10001B70: 00010000 10000100 00000100 00003f00    .............?..
10001B80: 68686850 08040068 1813110d 10001f43    Phhhh.......C...
10001B90: 001820c2 00000000 00000000 0001004d    . ..........M...
10001BA0: 00000100 00010000 10001000 00000100    ................
10001BB0: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10001BC0: 10001f38 001720c2 00000000 00000000    8.... ..........
10001BD0: 0001004d 00000080 00010000 10000800    M...............
10001BE0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10001BF0: 1813110d 10001f2d 001728c2 00000000    ....-....(......
10001C00: 00000000 0001004d 00000080 00010000    ....M...........
10001C10: 10000800 00000100 00003f00 50502150    .........?..P!PP
10001C20: 08040350 1813110d 10001f22 001620c2    P.......".... ..
10001C30: 00000000 00000000 0001004d 00000040    ........M...@...
10001C40: 00010000 10000400 00000100 00003f00    .............?..
10001C50: 68566850 08040068 1813110d 10001f17    PhVhh...........
10001C60: 001525c2 00000000 00000000 0001004d    .%..........M...
10001C70: 00000020 00010000 10000200 00000100     ...............
10001C80: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10001C90: 10001f0c 001520c2 00000000 00000000    ..... ..........
10001CA0: 0001004d 00000020 00010000 10000200    M... ...........
10001CB0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10001CC0: 1813110d 10001f01 00469d7f 00000000    ..........F.....
10001CD0: 00000000 0001004d 00000040 00010000    ....M...@.......
10001CE0: 10000400 00000100 00003f00 68646864    .........?..dhdh
10001CF0: 08040068 1613110d 10001efa 0016ba20    h........... ...
10001D00: 00000000 00000000 00010010 00000040    ............@...
10001D10: 00010000 10000400 00000100 00003f00    .............?..
10001D20: 6c6c6c6c 0904006c 16130f0b 10001ef3    lllll...........
10001D30: 0017ba20 00000000 00000000 00010010     ...............
10001D40: 00000080 00010000 10000800 00000100    ................
10001D50: 00003f00 6c6c6c6c 0904006c 16130f0b    .?..lllll.......
10001D60: 10001eeb 0218ba20 00000010 00000000    .... ...........
10001D70: 00010010 00000100 00010000 10001000    ................
10001D80: 00000100 00003f00 36363636 09040036    .....?..66666...
10001D90: 16130f0b 10001ee3 0219ba20 00000010    ........ .......
10001DA0: 00000000 00010010 00000200 00010000    ................
10001DB0: 10002000 00000100 00003f00 36363636    . .......?..6666
10001DC0: 09040036 16150f0b 10001ed9 0219ba20    6........... ...
10001DD0: 00004410 00000000 00010091 00000200    .D..............
10001DE0: 00010000 10002000 00000100 00003f00    ..... .......?..
10001DF0: 6c6c6c6c 0904006c 17150f0b 10001ecf    lllll...........
10001E00: 0020ba20 00000000 00000000 00010091     . .............
10001E10: 00000400 00010000 10004000 00000100    .........@......
10001E20: 00003f00 6c6c6c6c 0904006c 17150f0b    .?..lllll.......
10001E30: 10001ec3 0218ba20 00004410 00000000    .... ....D......
10001E40: 0001001d 00000100 00010000 10001000    ................
10001E50: 00000100 00003f00 6c6c6c6c 0804006c    .....?..lllll...
10001E60: 1814120d 10001eba 001640c8 00000000    .........@......
10001E70: 00000000 0001004d 00000040 00010000    ....M...@.......
10001E80: 10000400 00000100 00003f00 68566850    .........?..PhVh
10001E90: 0a040068 1613100e 05153505 31013335    h........5..53.1
10001EA0: 6d6f4311 206e6f6d 46495053 6f432049    .Common SPIFI Co
10001EB0: 6e616d6d 65532064 44470074 33513532    mmand Set.GD25Q3
10001EC0: 4d004332 51353254 3832314c 4d004241    2C.MT25QL128AB.M
10001ED0: 51353254 41323135 32544d00 35325135    T25Q512A.MT25Q25
10001EE0: 4e004136 32513532 4e003635 31513532    6A.N25Q256.N25Q1
10001EF0: 4e003832 36513532 324e0034 32335135    28.N25Q64.N25Q32
10001F00: 324d5000 30514c35 00433233 3532584d    .PM25LQ032C.MX25
10001F10: 3036314c 4d004536 4c353258 35333631    L1606E.MX25L1635
10001F20: 584d0045 334c3532 45353332 32584d00    E.MX25L3235E.MX2
10001F30: 34365235 00463533 3532584d 3334364c    5R6435F.MX25L643
10001F40: 4d004535 4c353258 33383231 4d004535    5E.MX25L12835E.M
10001F50: 56353258 35333038 584d0046 384c3532    X25V8035F.MX25L8
10001F60: 45353330 35325300 31304c46 53004b36    035E.S25FL016K.S
10001F70: 4c463532 50323330 35325300 36304c46    25FL032P.S25FL06
10001F80: 53005034 4c463532 50393231 6b343620    4P.S25FL129P 64k
10001F90: 00636553 46353253 3932314c 35322050    Sec.S25FL129P 25
10001FA0: 65536b36 32530063 314c4635 004b3436    6kSec.S25FL164K.
10001FB0: 46353253 3635324c 34362053 6365536b    S25FL256S 64kSec
10001FC0: 35325300 35324c46 32205336 536b3635    .S25FL256S 256kS
10001FD0: 53006365 4c463532 53323135 35325700    ec.S25FL512S.W25
10001FE0: 43303451 32570056 32335135 57005646    Q40CV.W25Q32FV.W
10001FF0: 36513532 00564634 51353257 4a383231    25Q64FV.W25Q128J
10002000: 00787856 51353257 46383231 32570056    Vxx.W25Q128FV.W2
10002010: 35325135 5f564636 65746e55 64657473    5Q256FV_Untested
10002020: 35325700 42303851 0f030056 00ff0f0f    .W25Q80BV.......
10002030: 00010100 00010909 0001090a 01010701    ................
10002040: 0001090d 0001090e 0001090f 00010910    ................
10002050: 00010911 00010912 00010913 00011114    ................
10002060: 00011119 0001111a 0001111b 00000000    ................
10002070: 00000000 00000000 00000000 00000000    ................
10002080: 00000000 00000000 00000000 00000000    ................
10002090: 00000000 00000000 00000000 00000000    ................
100020A0: 00000000 00000000 00000000 00000000    ................
100020B0: 00000000 00000000 00000000 00000000    ................
100020C0: 00000000 00000000 00000000 00000000    ................
100020D0: 00000000 00000000 00000000 00000000    ................
100020E0: 00000000 00000000 00000000 00000000    ................
100020F0: 00000000 00000000 00000000 00000000    ................
10002100: 00000000 00000000 00000000 00000000    ................
10002110: 00000000 00000000 00000000 00000000    ................
10002120: 00000000 00000000 00000000 00000000    ................
10002130: 00000000 00000000 00000000 00000000    ................
10002140: 00000000 00000000 00000000 00000000    ................
10002150: 00000000 00000000 00000000 00000000    ................
10002160: 00000000 00000000 00000000 00000000    ................
10002170: 00000000 00000000 00000000 00000000    ................
10002180: 00000000 00000000 00000000 00000000    ................
10002190: 00000000 00000000 00000000 00000000    ................
100021A0: 00000000 00000000 00000000 00000000    ................
100021B0: 00000000 00000000 00000000 00000000    ................
100021C0: 00000000 00000000 00000000 00000000    ................
100021D0: 00000000 00000000 00000000 00000000    ................
100021E0: 00000000 00000000 00000000 00000000    ................
100021F0: 00000000 00000000 00000000 00000000    ................
10002200: 00000000 00000000 00000000 00000000    ................
10002210: 00000000 00000000 00000000 00000000    ................
10002220: 00000000 00000000 00000000 00000000    ................
10002230: 00000000 00000000 00000000 00000000    ................
10002240: 00000000 00000000 00000000 00000000    ................
10002250: 00000000 00000000 00000000             ............
Driver code in memory:
10000000: 00787856 51353257 46383231 32570056    Vxx.W25Q128FV.W2
10000010: 35325135 5f564636 65746e55 64657473    5Q256FV_Untested
10000020: 35325700 42303851 0f030056 00ff0f0f    .W25Q80BV.......
10000030: 00010100 00010909 0001090a 01010701    ................
10000040: 0001090d 0001090e 0001090f 00010910    ................
10000050: 00010911 00010912 00010913 00011114    ................
10000060: 00011119 0001111a 0001111b 00000000    ................
10000070: 00000000 00000000 00000000 00000000    ................
10000080: 00000000 00000000 00000000 00000000    ................
10000090: 00000000 00000000 00000000 00000000    ................
100000A0: 00000000 00000000 00000000 00000000    ................
100000B0: 00000000 00000000 00000000 00000000    ................
100000C0: 00000000 00000000 00000000 00000000    ................
100000D0: 00000000 00000000 00000000 00000000    ................
100000E0: 00000000 00000000 00000000 00000000    ................
100000F0: 00000000 00000000 00000000 00000000    ................
10000100: 00000000 00000000 00000000 00000000    ................
10000110: 00000000 00000000 00000000 00000000    ................
10000120: 00000000 00000000 00000000 00000000    ................
10000130: 00000000 00000000 00000000 00000000    ................
10000140: 00000000 00000000 00000000 00000000    ................
10000150: 00000000 00000000 00000000 00000000    ................
10000160: 00000000 00000000 00000000 00000000    ................
10000170: 00000000 00000000 00000000 00000000    ................
10000180: 00000000 00000000 00000000 00000000    ................
10000190: 00000000 00000000 00000000 00000000    ................
100001A0: 00000000 00000000 00000000 00000000    ................
100001B0: 00000000 00000000 00000000 00000000    ................
100001C0: 00000000 00000000 00000000 00000000    ................
100001D0: 00000000 00000000 00000000 00000000    ................
100001E0: 00000000 00000000 00000000 00000000    ................
100001F0: 00000000 00000000 00000000 00000000    ................
10000200: 00000000 00000000 00000000 00000000    ................
10000210: 00000000 00000000 00000000 00000000    ................
10000220: 00000000 00000000 00000000 00000000    ................
10000230: 00000000 00000000 00000000 00000000    ................
10000240: 00000000 00000000 00000000 00000000    ................
10000250: 00000000 00000000 00000000 504c2101    .............!LP
10000260: 2f383143 47203334 72656e65 53206369    C18/43 Generic S
10000270: 49464950 6c754a20 20353220 38313032    PIFI Jul 25 2018
10000280: 3a313120 353a3932 00000035 00000000     11:29:55.......
10000290: 00000000 00000000 00000000 00050000    ................
100002A0: 14000000 04000000 00000100 00000000    ................
100002B0: 000000ff 00000bb8 00001770 00010000    ........p.......
100002C0: 00000000 ffffffff ffffffff 10002118    .............!..
100002D0: 100019b8 10002120 100019ec 10002128    .... !......(!..
100002E0: 10001a20 10002130 10001a54 10002138     ...0!..T...8!..
100002F0: 10001a88 10002140 10001abc 10002148    ....@!......H!..
10000300: 10001af0 10002150 10001b24 10002158    ....P!..$...X!..
10000310: 10001b58 10002160 10001b8c 10002168    X...`!......h!..
10000320: 10001bc0 10002170 10001bf4 10002178    ....p!......x!..
10000330: 10001c28 10002180 10001c5c 10002188    (....!..\....!..
10000340: 10001c90 10002190 10001cc4 10002198    .....!.......!..
10000350: 10001cf8 100021a0 10001d2c 100021a8    .....!..,....!..
10000360: 10001d60 100021b0 10001d94 100021b8    `....!.......!..
10000370: 10001dc8 100021c0 10001dfc 100021c8    .....!.......!..
10000380: 10001e30 100021d0 10001e64 737af44f    0....!..d...O.zs
10000390: 9301b082 699a4b0c f0226998 42880102    .....K.i.i"....B
100003A0: bf18480a 68006199 f0224909 42880203    .H...a.h.I"....B
100003B0: f042bf88 619a0204 1e5a9b01 2b009201    ..B....a..Z....+
100003C0: b002d1fa bf004770 40050000 100017e0    ....pG.....@....
100003D0: 01312cff 6c534a02 0301f043 47706453    .,1..JSlC...SdpG
100003E0: 40050000 f1030083 f5034380 291123a0    [email protected]...#.)
100003F0: 6c9cb510 3a01d00f ea410609 4a080182    ...l...:..A....J
10000400: 6100f441 4a075c10 0280ea42 0402ea24    A..a.\.JB...$...
10000410: 64994321 f044bd10 649c0401 bf00e7fa    !C.d..D....d....
10000420: 1000202a 1f000001 30124b04 0020f853    * .......K.0S. .
10000430: bf5407c3 6004f3c0 47702011 40050000    ..T....`. pG...@
10000440: d83b2810 f000e8df 180e0c09 28263a23    .(;.........#:&(
10000450: 3a3a2d2a 3634322f f44f0038 47704000    *-::/2468.O..@pG
10000460: 47704817 48184b17 312cf8d3 0307f003    .HpG.K.H..,1....
10000470: bf082b04 47702000 4a144b12 312cf8d3    .+... pG.K.J..,1
10000480: f0034811 2b040307 4610bf08 4b104770    .H.....+...FpG.K
10000490: 47706818 e7fb4b0f e7f94b0f 68584b0e    .hpG.K...K...KXh
100004A0: f0004770 2000b8b7 b8e2f000 e7fb2001    pG..... ..... ..
100004B0: e7f92002 e7f72003 e7f52004 47702000    . ... ... ... pG
100004C0: 00b71b00 40043000 017d7840 02faf080    .....0.@@x}.....
100004D0: 100017dc 100017e0 10002244 b5f723fa    ........D"...#..
100004E0: 4605460c f7ff9301 4b1affab 6c5b4360    .F.F.......K`C[l
100004F0: f0233c01 ea4353f8 4b176205 4a174013    .<#[email protected]
10000500: d8194290 21002501 fb070047 4296f605    .B...%.!G......B
10000510: ea43d90f f0434304 ea430340 4a0d2301    [email protected]..#.J
10000520: 0301f023 9b016453 92011e5a d1fa2b00    #...Sd..Z....+..
10000530: 3101e00d e7e8006d 42904a09 ea43d804    ...1m....J.B..C.
10000540: f0434304 e7ea03c0 ff44f7ff b0032000    .CC.......D.. ..
10000550: bf00bdf0 40050000 ff00cc3d 094c5eff    .......@=....^L.
10000560: 1312cfff 43f8e92d 46064691 4698460f    ....-..C.F.F.F.F
10000570: ff66f7ff 3ffff1b9 fbb9d02e fb01f1f0    ..f....?........
10000580: 42a7f400 4b21d817 d814429c bf2c45a0    ...B..!K.B...E,.
10000590: 25004625 42a74404 0301f101 4a1bd81a    %F.%.D.B.......J
100005A0: d8174294 d31545a0 b94cb13d e8bd4630    .B...E..=.L.0F..
100005B0: f7ff43f8 2500bf93 b16ce7ec e7f54619    .C.....%..l..F..
100005C0: 0505eba9 0409eba4 d9f742a5 b1cae7ee    .........B......
100005D0: e7eb4611 d1e92d00 f4f0fbb7 f3f0fbb8    .F...-..........
100005E0: fb042200 490af500 d30642bd d8044545    .".....I.B..EE..
100005F0: 3cfff105 bf98458c 429c4622 d2e64405    ...<.E.."F.B.D..
10000600: e7f13401 e8bd4610 bf0083f8 0aba9500    .4...F..........
10000610: 0aba94ff 4d14b537 f3c46c6c f7ff6003    ....7..Mll...`..
10000620: 4b12ff0f 6c2b9301 0301f013 f3c4d019    ...K..+l........
10000630: a9022301 f813440b f3c41c04 33013301    .#...D.......3.3
10000640: f0f3fbb0 f3c409a3 ea434207 07e314d4    .........BC.....
10000650: 0201f102 004bbf5c f2f3fbb2 b0034350    ....\.K.....PC..
10000660: 4618bd30 bf00e7fb 40050000 08040201    0..F.......@....
10000670: 4604b538 fed8f7ff f1044b07 f8530212    8..F.....K....S.
10000680: f7ff5022 4b05fedd ea035d1b 33010395    "P.....K.].....3
10000690: f0f3fbb0 bf00bd38 40050000 1000202a    ....8......@* ..
100006A0: 0084b530 4480f104 24a0f504 6de5281b    0......D...$.(.m
100006B0: 2911d80d 4808d00a b10a4028 6000f440    ...)...H(@..@..`
100006C0: f040b10b ea400001 65e06001 f045bd30    ..@...@..`.e0.E.
100006D0: 65e50501 bf00e7fa e0fff7fe 63faf44f    ...e........O..c
100006E0: 2806b573 460d4604 93014616 f7ffd101    s..(.F.F.F......
100006F0: 2300fe4d 46212201 f7ff2004 4b17ffd1    M..#."!F. .....K
10000700: d90a429d 4916461a f7ff4620 2300ff2b    .B...F.I F..+..#
10000710: 21092201 f7ff2004 9b01ffc3 92011e5a    .".!. ......Z...
10000720: d1fa2b00 462b490f 6809462a f7ff4620    .+...I+F*F.h F..
10000730: b12eff19 f1044c0c 34040540 d10142ac    [email protected]..
10000740: bd70b002 3c01f814 2c02f814 1c03f814    ..p....<...,....
10000750: 0c04f814 ffa4f7ff bf00e7ef 068e7780    .............w..
10000760: 00b71b00 100017e0 10002030 49022201    ........0 ...".I
10000770: f7ff4610 bf00bfb3 0aba9500 bff6f7ff    .F..............
10000780: 0301ea40 b570079b 4604d10c 2a03460b    @.....p....F.F.*
10000790: 46204619 6806d906 3404680d f10342ae    .F F...h.h.4.B..
100007A0: d0040304 4291440a 2000d103 3a04e008    .....D.B... ...:
100007B0: f810e7ed f8113b01 42a34b01 1b18d0f3    .....;...K.B....
100007C0: 0303bd70 040300f3 050300f3 060300f3    p...............
100007D0: 070300f3 080300f3 000000f3 00000000    ................
100007E0: 00b71b00 10002021 001440ef 00000000    ....! ...@......
100007F0: 00000000 0001005d 00000010 00010000    ....]...........
10000800: 10000100 00000100 00003f00 68686868    .........?..hhhh
10000810: 09040268 16130f0b 1000200e 001940ef    h........ ...@..
10000820: 00000000 00000000 000100dd 00000200    ................
10000830: 00010000 10002000 00000100 00003f00    ..... .......?..
10000840: 68686868 09040268 17150f0b 10002004    hhhhh........ ..
10000850: 001840ef 00000000 00000000 0001005d    .@..........]...
10000860: 00000100 00010000 10001000 00000100    ................
10000870: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10000880: 10001ff8 001870ef 00000000 00000000    .....p..........
10000890: 0001005d 00000100 00010000 10001000    ]...............
100008A0: 00000100 00003f00 68686868 09040268    .....?..hhhhh...
100008B0: 16130f0b 10001fef 001740ef 00000000    .........@......
100008C0: 00000000 0001005d 00000080 00010000    ....]...........
100008D0: 10000800 00000100 00003f00 68686868    .........?..hhhh
100008E0: 09040268 16130f0b 10001fe6 001640ef    h............@..
100008F0: 00000000 00000000 0001005d 00000040    ........]...@...
10000900: 00010000 10000400 00000100 00003f00    .............?..
10000910: 68686868 09040268 16130f0b 10001fdd    hhhhh...........
10000920: 001340ef 00000000 00000000 0001005d    .@..........]...
10000930: 00000008 00010000 10000080 00000100    ................
10000940: 00003f00 68686868 09040268 16130f0b    .?..hhhhh.......
10000950: 10001fd3 00200201 00000000 00000000    ...... .........
10000960: 0001009d 00000100 00040000 00000000    ................
10000970: 00000200 00003f00 68506850 06050050    .....?..PhPhP...
10000980: 17150f0b 10001fc1 02190201 0000004d    ............M...
10000990: 00000000 0001009d 00000080 00040000    ................
100009A0: 00000000 00000100 00003f00 68506850    .........?..PhPh
100009B0: 06050050 17150f0b 10001fb0 02190201    P...............
100009C0: 0000014d 00000000 0001009d 00000200    M...............
100009D0: 00010000 00000000 00000100 00003f00    .............?..
100009E0: 68506850 06050050 17150f0b 10001fa6    PhPhP...........
100009F0: 00174001 00000000 00000000 00010055    [email protected]...
10000A00: 00000080 00010000 10000800 00000100    ................
10000A10: 00003f00 61616132 07040161 16130f0c    .?..2aaaa.......
10000A20: 10001f94 02182001 0000004d 00000000    ..... ..M.......
10000A30: 0001001d 00000040 00040000 00000000    ....@...........
10000A40: 00000100 00003f00 68506850 06050050    .....?..PhPhP...
10000A50: 16130f0b 10001f83 02182001 0000014d    ......... ..M...
10000A60: 00000000 0001001d 00000100 00010000    ................
10000A70: 00000000 00000100 00003f00 68506850    .........?..PhPh
10000A80: 06050050 16130f0b 10001f79 01160201    P.......y.......
10000A90: 0000004d 00000000 0001001d 00000080    M...............
10000AA0: 00010000 00000000 00000100 00003f00    .............?..
10000AB0: 68506850 06050050 16130f0b 10001f6f    PhPhP.......o...
10000AC0: 00150201 00000000 00000000 0001001d    ................
10000AD0: 00000040 00010000 00000000 00000100    @...............
10000AE0: 00003f00 68506850 06050050 16130f0b    .?..PhPhP.......
10000AF0: 10001f65 001540ef 00000000 00000000    e....@..........
10000B00: 0001005d 00000020 00010000 10000200    ]... ...........
10000B10: 00000100 00003f00 68506850 06040050    .....?..PhPhP...
10000B20: 16130f0b 10001f5a 001420c2 00000000    ....Z.... ......
10000B30: 00000000 0001004d 00000010 00010000    ....M...........
10000B40: 10000100 00000100 00003f00 686c6c50    .........?..Pllh
10000B50: 08040068 1813110d 10001f4f 001423c2    h.......O....#..
10000B60: 00000000 00000000 0001004d 00000010    ........M.......
10000B70: 00010000 10000100 00000100 00003f00    .............?..
10000B80: 68686850 08040068 1813110d 10001f43    Phhhh.......C...
10000B90: 001820c2 00000000 00000000 0001004d    . ..........M...
10000BA0: 00000100 00010000 10001000 00000100    ................
10000BB0: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10000BC0: 10001f38 001720c2 00000000 00000000    8.... ..........
10000BD0: 0001004d 00000080 00010000 10000800    M...............
10000BE0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10000BF0: 1813110d 10001f2d 001728c2 00000000    ....-....(......
10000C00: 00000000 0001004d 00000080 00010000    ....M...........
10000C10: 10000800 00000100 00003f00 50502150    .........?..P!PP
10000C20: 08040350 1813110d 10001f22 001620c2    P.......".... ..
10000C30: 00000000 00000000 0001004d 00000040    ........M...@...
10000C40: 00010000 10000400 00000100 00003f00    .............?..
10000C50: 68566850 08040068 1813110d 10001f17    PhVhh...........
10000C60: 001525c2 00000000 00000000 0001004d    .%..........M...
10000C70: 00000020 00010000 10000200 00000100     ...............
10000C80: 00003f00 68566850 08040068 1813110d    .?..PhVhh.......
10000C90: 10001f0c 001520c2 00000000 00000000    ..... ..........
10000CA0: 0001004d 00000020 00010000 10000200    M... ...........
10000CB0: 00000100 00003f00 68566850 08040068    .....?..PhVhh...
10000CC0: 1813110d 10001f01 00469d7f 00000000    ..........F.....
10000CD0: 00000000 0001004d 00000040 00010000    ....M...@.......
10000CE0: 10000400 00000100 00003f00 68646864    .........?..dhdh
10000CF0: 08040068 1613110d 10001efa 0016ba20    h........... ...
10000D00: 00000000 00000000 00010010 00000040    ............@...
10000D10: 00010000 10000400 00000100 00003f00    .............?..
10000D20: 6c6c6c6c 0904006c 16130f0b 10001ef3    lllll...........
10000D30: 0017ba20 00000000 00000000 00010010     ...............
10000D40: 00000080 00010000 10000800 00000100    ................
10000D50: 00003f00 6c6c6c6c 0904006c 16130f0b    .?..lllll.......
10000D60: 10001eeb 0218ba20 00000010 00000000    .... ...........
10000D70: 00010010 00000100 00010000 10001000    ................
10000D80: 00000100 00003f00 36363636 09040036    .....?..66666...
10000D90: 16130f0b 10001ee3 0219ba20 00000010    ........ .......
10000DA0: 00000000 00010010 00000200 00010000    ................
10000DB0: 10002000 00000100 00003f00 36363636    . .......?..6666
10000DC0: 09040036 16150f0b 10001ed9 0219ba20    6........... ...
10000DD0: 00004410 00000000 00010091 00000200    .D..............
10000DE0: 00010000 10002000 00000100 00003f00    ..... .......?..
10000DF0: 6c6c6c6c 0904006c 17150f0b 10001ecf    lllll...........
10000E00: 0020ba20 00000000 00000000 00010091     . .............
10000E10: 00000400 00010000 10004000 00000100    .........@......
10000E20: 00003f00 6c6c6c6c 0904006c 17150f0b    .?..lllll.......
10000E30: 10001ec3 0218ba20 00004410 00000000    .... ....D......
10000E40: 0001001d 00000100 00010000 10001000    ................
10000E50: 00000100 00003f00 6c6c6c6c 0804006c    .....?..lllll...
10000E60: 1814120d 10001eba 001640c8 00000000    .........@......
10000E70: 00000000 0001004d 00000040 00010000    ....M...@.......
10000E80: 10000400 00000100 00003f00 68566850    .........?..PhVh
10000E90: 0a040068 1613100e 05153505 31013335    h........5..53.1
10000EA0: 6d6f4311 206e6f6d 46495053 6f432049    .Common SPIFI Co
10000EB0: 6e616d6d 65532064 44470074 33513532    mmand Set.GD25Q3
10000EC0: 4d004332 51353254 3832314c 4d004241    2C.MT25QL128AB.M
10000ED0: 51353254 41323135 32544d00 35325135    T25Q512A.MT25Q25
10000EE0: 4e004136 32513532 4e003635 31513532    6A.N25Q256.N25Q1
10000EF0: 4e003832 36513532 324e0034 32335135    28.N25Q64.N25Q32
10000F00: 324d5000 30514c35 00433233 3532584d    .PM25LQ032C.MX25
10000F10: 3036314c 4d004536 4c353258 35333631    L1606E.MX25L1635
10000F20: 584d0045 334c3532 45353332 32584d00    E.MX25L3235E.MX2
10000F30: 34365235 00463533 3532584d 3334364c    5R6435F.MX25L643
10000F40: 4d004535 4c353258 33383231 4d004535    5E.MX25L12835E.M
10000F50: 56353258 35333038 584d0046 384c3532    X25V8035F.MX25L8
10000F60: 45353330 35325300 31304c46 53004b36    035E.S25FL016K.S
10000F70: 4c463532 50323330 35325300 36304c46    25FL032P.S25FL06
10000F80: 53005034 4c463532 50393231 6b343620    4P.S25FL129P 64k
10000F90: 00636553 46353253 3932314c 35322050    Sec.S25FL129P 25
10000FA0: 65536b36 32530063 314c4635 004b3436    6kSec.S25FL164K.
10000FB0: 46353253 3635324c 34362053 6365536b    S25FL256S 64kSec
10000FC0: 35325300 35324c46 32205336 536b3635    .S25FL256S 256kS
10000FD0: 53006365 4c463532 53323135 35325700    ec.S25FL512S.W25
10000FE0: 43303451 32570056 32335135 57005646    Q40CV.W25Q32FV.W
10000FF0: 36513532 00564634 51353257 4a383231    25Q64FV.W25Q128J
10001000: 00787856 51353257 46383231 32570056    Vxx.W25Q128FV.W2
10001010: 35325135 5f564636 65746e55 64657473    5Q256FV_Untested
10001020: 35325700 42303851 0f030056 00ff0f0f    .W25Q80BV.......
10001030: 00010100 00010909 0001090a 01010701    ................
10001040: 0001090d 0001090e 0001090f 00010910    ................
10001050: 00010911 00010912 00010913 00011114    ................
10001060: 00011119 0001111a 0001111b 00000000    ................
10001070: 00000000 00000000 00000000 00000000    ................
10001080: 00000000 00000000 00000000 00000000    ................
10001090: 00000000 00000000 00000000 00000000    ................
100010A0: 00000000 00000000 00000000 00000000    ................
100010B0: 00000000 00000000 00000000 00000000    ................
100010C0: 00000000 00000000 00000000 00000000    ................
100010D0: 00000000 00000000 00000000 00000000    ................
100010E0: 00000000 00000000 00000000 00000000    ................
100010F0: 00000000 00000000 00000000 00000000    ................
10001100: 00000000 00000000 00000000 00000000    ................
10001110: 00000000 00000000 00000000 00000000    ................
10001120: 00000000 00000000 00000000 00000000    ................
10001130: 00000000 00000000 00000000 00000000    ................
10001140: 00000000 00000000 00000000 00000000    ................
10001150: 00000000 00000000 00000000 00000000    ................
10001160: 00000000 00000000 00000000 00000000    ................
10001170: 00000000 00000000 00000000 00000000    ................
10001180: 00000000 00000000 00000000 00000000    ................
10001190: 00000000 00000000 00000000 00000000    ................
100011A0: 00000000 00000000 00000000 00000000    ................
100011B0: 00000000 00000000 00000000 00000000    ................
100011C0: 00000000 00000000 00000000 00000000    ................
100011D0: 00000000 00000000 00000000 00000000    ................
100011E0: 00000000 00000000 00000000 00000000    ................
100011F0: 00000000 00000000 00000000 00000000    ................
10001200: 00000000 00000000 00000000 00000000    ................
10001210: 00000000 00000000 00000000 00000000    ................
10001220: 00000000 00000000 00000000 00000000    ................
10001230: 00000000 00000000 00000000 00000000    ................
10001240: 00000000 00000000 00000000 00000000    ................
10001250: 00000000 00000000 00000000 504c2101    .............!LP
10001260: 2f383143 47203334 72656e65 53206369    C18/43 Generic S
10001270: 49464950 6c754a20 20353220 38313032    PIFI Jul 25 2018
10001280: 3a313120 353a3932 00000035 00000000     11:29:55.......
10001290: 00000000 00000000 00000000 00050000    ................
100012A0: 14000000 04000000 00000100 00000000    ................
100012B0: 000000ff 00000bb8 00001770 00010000    ........p.......
100012C0: 00000000 ffffffff ffffffff 10002118    .............!..
Warning - after successful write failed to read back mailbox (at 0x10089000) twice - first rc Em(12). Target rejected debug access at location 0x10089000, then rc Em(12). Target rejected debug access at location 0x10089000
Flash Driver V.2 startup failed - rc Em(12). Target rejected debug access at location 0x10089000
chip initialization failed - Em(12). Target rejected debug access at location 0x10089000
NXP: LPC4370
Connected: was_reset=false. was_stopped=false
I don't know that else to do, It seems that the
is not recognizing my flash or she is blocked somehow or for some reason, or the lpc4370 is blocking her by gpio, I don't know.
Could it be my launch configuration or the project?
Luiz
luizroque
Looking at the error the addr 0x10089000 is a RAM error related? But my RamLoc72 has the stating addr at 0x10080000 with size 0x12000 (72kB), what's wrong? The LPC4370 is blocking the RAM?
Alexis_A
Hi Luiz,
Only to discard some possibilities, could you try upgrading your MCUXpresso IDE version? I saw that you're using the 10.2 Version, the last one available is the 10.3.1.
Also I think that you're using an LPC-Link 2, couldd you try upgrading the firmware version?
Alexis Andalon
Alexis_A
Hi Luis,
Please check this document, there explain how to use the SPIFI library with the LPC4370:
https://community.nxp.com/docs/DOC-342077
Alexis Andalon
