Hi NXP,
I use RT1050 with QSPI flash, and how to change the MCUXpresso setting to use QSPI flash?
I have read the following document in segger web site, but how to do in MCUXpresso IDE?
https://wiki.segger.com/i.MXRT1050#Enable_Flashloader
Solved! Go to Solution.
No one use QSPI on RT1050?
How do you solve this issue in MCUXpresso v11.7.0 with J-Link?
RT-UFL needs to modify JLinkDevices.xml
https://www.cnblogs.com/henjay724/p/14942574.html
"就是把 \RT-UFL-1.0\algo\SEGGER\JLink_Vxxx 路径下的全部文件拷贝覆盖到 \SEGGER\JLink_V686f\ 目录下即可"
I can not find JLinkDevices.xml in J-Link v7.84a, so I doubt it can work with new J-Link version.
Can NXP give another solution for this issue when MCUXpresso IDE update? Since NXP always suggest to use latest IDE and SDK.
This github repository lacks 3 .flm files.
Can you give me the link of the first picture?
Jing
Thanks. I'll forward to Jay.
Jing
Jay told me that there is some special requirement, he can't include those file.(I don't understand why...)
So please download from
https://github.com/nxp-mcuxpresso/i.mxrt-ufl/releases/download/v1.0/i.mxrt-ufl-1.0-with-flm.zip
Jing
