How to built and debug correctly a .mot generated from Motor Control Toolbox of Matlab to run in MCU KV11?
2,713 次查看
jordiclos
When I try to built it's okey but when trying to debug, an error appear: either "Binaries not found" or "Error with command: arm-none-eabi-gdb --version. Cannot run program "arm-none-eabi-gdb": Launching failed".
Some one knows about the procedure to correctly debug a code generated from matlab?
It will be very helpfull, thanks!
2,630 次查看
xiangjun_rong
I appologize  for the delay.
Can you post your project here so that we can have a review?
xiangjun rong
