'Go Into' a project nests the project inside?
2,236 次查看
jmreina
Recently when I try to navigate into a project with the Project Explorer from the context menu, it then stuffs the project I am going into as a sub-tree item! See below -
Example:
Why is it doing this? Can this be fixed?
2,137 次查看
RaRo
Hello @jmreina,
First of all, let us apologize for our delay.
Could you please click on Filters and Customization's Project Explorer? There you might find some filtering options that could help you customize the view of the Project Explorer.
[Filters and Customization's Project Explorer]
Could you please go to Content's Filter and Customization and unchecked the Project Info Content Provider? Disabling it seems to fix the issue.
[Unchecking the Project Info Content Provider]
Please let us know if that works on your side.
Best regards, Raul.
2,157 次查看
jmreina
I also see an unexpected order of contents when the project is navigated into -
How do I get the contents to display in the similar order before navigation into the project? I don't like this display above, it looks clumsy
Thoughts?
2,224 次查看
jmreina
I am also seeing Project Settings still listed under my closed project, which is unexpected; why is this still listed?
