Failed to create System Restore Point
3,633件の閲覧回数
xgy_upc
When installing MCUXpresso IDE on a 64-bit Win10 System, the prompt "Failed to create System Restore Point "appears
3,623件の閲覧回数
ErichStyger
Specialist I
Hi @xgy_upc ,
I would say this is more of a problem of Windows than MCUXpresso. I had this a while back when I did not have enough disk space available for Windows (less than 1 GByte free). Not sure if this is the case for you. Other than that, the installation should go fine.
I hope this helps,
Erich
