spi flash reading problem
1,487 次查看
bdbz
I'm trying to use MEK18F spi interface to read extern spi flash(W25Q16JVSSIG) Device ID,but it can't work.do you have code examples with it?thanks a lot for your attention!
标记 (1)
1 回复
1,421 次查看
jingpan
It seems there isn't such a example.
https://community.nxp.com/message/1233471
imxRT also has same LPSPI peripheral. You can take a look.
Jing
