MCUXpresso IDE don't run with Error message after install PN7462AU Software plugin
1,625 次查看
won2rang
MCUXpresso IDE don't run with Error message after install PN7462AU Software plugin.
Tools return "Invalid Configuration" with "Unique configuration settings not found (). Exiting"
How can i fix this error?
MCUXpress : MCUXpresso IDE v11.0.1_2563
plugin is com.nxp.pn7xxxxx.update-8.0.0-SNAPSHOT-163
1,523 次查看
lpcxpresso_supp
You cannot import old LPCXpresso patches into MCUXpresso IDE - which its sounds like you are trying to do. However I believe that the functionality this patch includes is probably already included inside MCUXpresso IDE.
However I would strongly recommend that you look at the documentation provided for PN74xx to check what version of the IDE they actually recommend for use with their software.
MCUXpresso IDE Support
1,523 次查看
Sabina_Bruce
My name is Sabina and I'll be happy to help you. Could you please provide screenshot of the error you are seeing. Also could you confirm if you have imported the project dependecies as well?
Sabina
