K32L2B31 - how to write and read 32 byte System Register File which is powered on all power mode
plefebvre1
Hi thanks for help
who knows how to write and read 32 byte System Register File which is powered on all power mode
for the K32L2B31
Pierre
RaRo
Hello @plefebvre1,
Could you please check the following community post: Power Management on Kinetis MCUs: LLS and VLLS mod... - NXP Community? There is explain how to use the System Register File and could be useful to take a look at.
For the K32L2B, this System Register File's base address is 0x4004_1000 and it can be seen in K32 L2B Sub-Family Reference Manual. Table 4-4. Peripheral bridge 0 slot assignments.
[Excerpt of Table 4-4. Peripheral bridge 0 slot assignments]
Warm regards, Raul.
