How to put codes in different memory
1,447件の閲覧回数
leexiao
I am now using MIMXRT1050 Evaluation board under MCUXpresso. How can I put some of my codes in the SRAM_OC? When I was using LPCXpresso I can implement it using the following instruction.
__TEXT_EXT(RAM3,initSPI) void initSPI(void)
But it did not work for the MCUXpresso and MIMXRT1050 Evaluation board. Your help will be appreciated.
Regards.
Lee Xiao
1,350件の閲覧回数
Carlos_Mendoza
Hi Lee,
Please try using the __RAMFUNC(RAM3) Macro, you can find more information on this link:
https://community.nxp.com/message/630735
Hope it helps!
Carlos Mendoza
Technical Support Engineer
