How to change stack size
feZero
Board FRDM-K64F
mbed OS 5.13.4
A stack overflow has occurred.
I want to increase the stack size, where is it defined?
Error Message: CMSIS-RTOS error: Stack overflow
// Current Thread: main  Id: 0x20002CD0 Entry: 0x31895
StackSize: 0x1000 StackMem: 0x1FFFA850 SP: 0x2002FF58
I've already tried to change the following macro definition, but the error message hasn't changed and the stack size remained 0x1000.
mbed_config.h
#define MBED_CONF_RTOS_MAIN_THREAD_STACK_SIZE 4096
#define MBED_CONF_RTOS_THREAD_STACK_SIZE            4096
Thank you.
danielchen
Hi feZero:
I would suggest you go to Arm Mbed OS support forum for your  the Mbed OS question.
https://forums.mbed.com/c/mbed-os/6
feZero
Hi Daniel
I will post on the link you suggested, Thank you!
danielchen
Hi feZero:
