Where is support for MLK03Zx in Processor Expert Driver Suite V10.4?
3,949 次查看
mist
Where is support for MLK03Zx in Processor Expert Driver Suite V10.4? Support for this part seems to have been removed from earlier versions of PE. Now I see only MLK02Z, 04Z and 05Z under Kinetis "L" series..
标记 (1)
5 回复数
3,631 次查看
mist
Hello
I have tried as you suggested with the full MCUXpresso IDE + SDK. It installed OK and I can create a project, but once again when I select the peripherals perspective it says "MCU is not supported" like in the standalone MCUXpresso config tool. Is it that support is now only to set up clocks and to multiplex pins with peripheral config support to be added with later version?
3,631 次查看
Hello Mikael,
Yes, the peripheral config support for kl03 will be release in later version.
About MCUXpresso Supported Devices please check this table :
https://community.nxp.com/docs/DOC-333073
Hope it helps
Alice
3,631 次查看
mist
Thank you for your quick response, but I have a similar problem with MCUXpresso as well.
When I select processor MKL03Z16VFK4 for a new project, it then says "MCU is not supported" when I go to select tools > peripherals.
It appears that I can only configure the clock structure and route hardware pins but there is no code generation for any of the peripheral modules?
3,631 次查看
Hello Mikael,
Please download the latest version MCUXpresso IDE v10.1.0,
MCUXpresso IDE|NXP
then download the latest SDK2.3  for your chip :
https://mcuxpresso.nxp.com/en/builder?uvid=67907
This MCUXpresso IDE has integrate the clock configure tool , so you needn't download  the standalone MCUXpresso Config tool .
Hope it helps
Alice
3,631 次查看
Hello Mikael Stewart,
About the New kinetis  products, PE, CW, KDS will not provide support .
New Kinetis device support can be found with MCUXpresso Software and  tools :
MCUXpresso Software and Tools for Arm® Cortex®-M cores|NXP
Hope it helps
TIC
