Power estimation tool
3,608 次查看
aune
Been playing around with the power estimation tool, but cannot get my clocks set correctly.
I'm my hardware/software I use external 32khz crystal to feed the FLL. FLL is set to 48Mhz, core to 12 and rest to 6MHz. I cannot set this configuration in the tool. Am I doing something wrong ?
标记 (1)
3,197 次查看
Hui_Ma
Could you let me know which Kinetis product you are using?
I think the MCU Power Estimation Tool doesn't with enough core/bus clock frequency group power consumption data.
That's why you could not select the different core and bus clock frequency.
Please let me know the Kinetis product part number, I could help to check with MCU Power Estimation Tool team about the power consumption data.
Thank you for the attention.
Ma Hui
3,197 次查看
jashanm
hi Hui_Ma,
                 I am working on KEA128, does the power estimation tool support KEA128 as well ?? because i couldnt find EA series in it ! Is there any other tool for this ??
