last day I tried to download the MCUXpresso_Config_Tools_v13_x64.exe of windows and I found that the download link is not available. could you please have a check. Because I need to install it to generate the .dtsi file from .mex file, due to the python scripts only recongise the V13.0 now.
Thanks for your quickly apply, I have pasted the wrong information here. Ofcourse the V14.0 and others version could be downloaded but due to the V13.0 is required to generate the .dtsi file from .mex when using the " So it will be very appreciated if you colud help me to solve this issue.
