MCUXpresso Config Tools v13 Now Available
We are pleased to announce that MCUXpresso Config Tools v13 are now available.
Downloads
Revision History
13.0
  • Supported disable view content for specific NPI
  • Supported clone single secondary boot role example project
  • Product outgoing license changed to LA_OPT_NXP_Software_License
  • Pins
    • Support customized function name for de-initialization function
    • Customization of the de-deinitialization function name
    • Allow usage of the expansion board file referencing single-row Arduino header with Freedom and LPC headers that are compatible.
    • Pins messages driven by functional properties and pin mode
    • Show external signal tab by default
    • Zephyr Pins configuration in Config Tools
  • Peripherals
    • "Default" option in the peripherals component clock selection
  • TEE
    • Now supports i.MX RT1180 and i.MX 93 processor families
    • Can optionally generate hardened code for the device (enabled by SDK, e.g. LPC55S6x MCU at this moment).
    • SAU, MPU, and Access Templates tabs have been moved to the top-level tab strip and are now MCU-wide
    • XRDC memory regions now allow overlaps
    • EAL configuration implemented for XRDC MRC
    • "This domain only" filter option added for the Memory Attribution Map view; it is always on for the Access Overview view
  • Memory Validation tool
    • Re-enable support
    • Drop GDB support and re-use download mode option
    • Change target connection method for Memory validation tool for MCUs
    • Sync Memory validation tool with register init component
  • Overview of Data for Config Tools v13:
    • General
      • Support of SDK 2.13
    • Pins tool
      • Improved labels of expansion headers in Pins tool
    • Peripherals tool
      • Registers init. component
        • New FlexIO component
        • Improved SEMC component
      • SDK init. components
        • Support of FCB component for RT117x
        • Register init. components
    • TEE tool
      • Support of option to enable generation of code hardened against instruction glitches
    • Memory validation tool
      • Support of RT1xxx processors
    • Bugfixes and minor improvements
Community
%3CLINGO-SUB%20id%3D%22lingo-sub-1585537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20Config%20Tools%20v13%20Now%20Available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1585537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EWe%20are%20pleased%20to%20announce%20that%20MCUXpresso%20Config%20Tools%20v13%20are%20now%20available.%3C%2FP%3E%0A%3CDIV%20id%3D%22bodyDisplay%22%20class%3D%22lia-message-body%20lia-component-message-view-widget-body%20lia-component-body-signature-highlight-escalation%20lia-component-message-view-widget-body-signature-highlight-escalation%22%3E%0A%3CDIV%20class%3D%22lia-message-body-content%22%3E%0A%3CDIV%20id%3D%22bodyDisplay%22%20class%3D%22lia-message-body%20lia-component-message-view-widget-body%20lia-component-body-signature-highlight-escalation%20lia-component-message-view-widget-body-signature-highlight-escalation%22%3E%0A%3CDIV%20class%3D%22lia-message-body-content%22%3E%0A%3CDIV%20class%3D%22bodyItem%22%3E%0A%3CDIV%20class%3D%22lia-message-body-wrapper%20lia-component-message-view-widget-body%22%3E%0A%3CDIV%20id%3D%22bodyDisplay%22%20class%3D%22lia-message-body%22%3E%0A%3CDIV%20class%3D%22lia-message-body-content%22%3E%0A%3CDIV%20class%3D%22lia-message-body-wrapper%20lia-component-message-view-widget-body%22%3E%0A%3CDIV%20id%3D%22bodyDisplay%22%20class%3D%22lia-message-body%22%3E%0A%3CDIV%20class%3D%22lia-message-body-content%22%3E%0A%3CH3%20id%3D%22toc-hId--723127402%22%20id%3D%22toc-hId-1203608185%22%20id%3D%22toc-hId-1998731899%22%3EDownloads%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3EIt%E2%80%99s%20a%20part%20of%20MCUXpresso%20IDE%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fmcuxpresso%2Fide%2Fdownload%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fmcuxpresso%2Fide%2Fdownload%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3EIn%20order%20to%20use%20it%20with%20other%20toolchains%2C%20download%20the%20installer%20for%20all%20platforms%2C%20please%20login%20to%20our%20download%20site%20via%3A%26nbsp%3B%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fmcuxpresso%2Fconfig%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fmcuxpresso%2Fconfig%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EPlease%20refer%20to%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-integrated-development-environment-ide%3AMCUXpresso-IDE%3Ftab%3DDocumentation_Tab%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMCUXpresso%20Config%20Tools%20documentation%3C%2FA%3E%20for%20installation%20and%20quick%20start%20guides.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EFor%20online%20version%2C%20login%20into%20MCUXpresso%20site%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fwelcome%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMCUXpresso%20WEB%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH3%20id%3D%22toc-hId-1764385431%22%20id%3D%22toc-hId--603846278%22%20id%3D%22toc-hId-191277436%22%3E%3CSPAN%3ERevision%20History%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH3%3E%0A%3CP%3E13.0%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ESupported%20disable%20view%20content%20for%20specific%20NPI%3C%2FLI%3E%0A%3CLI%3ESupported%20clone%20single%20secondary%20boot%20role%20example%20project%3C%2FLI%3E%0A%3CLI%3EProduct%20outgoing%20license%20changed%20to%20LA_OPT_NXP_Software_License%3C%2FLI%3E%0A%3CLI%3EPins%0A%3CUL%3E%0A%3CLI%3ESupport%20customized%20function%20name%20for%20de-initialization%20function%3C%2FLI%3E%0A%3CLI%3ECustomization%20of%20the%20de-deinitialization%20function%20name%3C%2FLI%3E%0A%3CLI%3EAllow%20usage%20of%20the%20expansion%20board%20file%20referencing%20single-row%20Arduino%20header%20with%20Freedom%20and%20LPC%20headers%20that%20are%20compatible.%3C%2FLI%3E%0A%3CLI%3EPins%20messages%20driven%20by%20functional%20properties%20and%20pin%20mode%3C%2FLI%3E%0A%3CLI%3EShow%20external%20signal%20tab%20by%20default%3C%2FLI%3E%0A%3CLI%3EZephyr%20Pins%20configuration%20in%20Config%20Tools%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3EPeripherals%0A%3CUL%3E%0A%3CLI%3E%22Default%22%20option%20in%20the%20peripherals%20component%20clock%20selection%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3ETEE%0A%3CUL%3E%0A%3CLI%3ENow%20supports%20i.MX%20RT1180%20and%20i.MX%2093%20processor%20families%3C%2FLI%3E%0A%3CLI%3ECan%20optionally%20generate%20hardened%20code%20for%20the%20device%20(enabled%20by%20SDK%2C%20e.g.%20LPC55S6x%20MCU%20at%20this%20moment).%3C%2FLI%3E%0A%3CLI%3ESAU%2C%20MPU%2C%20and%20Access%20Templates%20tabs%20have%20been%20moved%20to%20the%20top-level%20tab%20strip%20and%20are%20now%20MCU-wide%3C%2FLI%3E%0A%3CLI%3EXRDC%20memory%20regions%20now%20allow%20overlaps%3C%2FLI%3E%0A%3CLI%3EEAL%20configuration%20implemented%20for%20XRDC%20MRC%3C%2FLI%3E%0A%3CLI%3E%22This%20domain%20only%22%20filter%20option%20added%20for%20the%20Memory%20Attribution%20Map%20view%3B%20it%20is%20always%20on%20for%20the%20Access%20Overview%20view%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3EMemory%20Validation%20tool%0A%3CUL%3E%0A%3CLI%3ERe-enable%20support%3C%2FLI%3E%0A%3CLI%3EDrop%20GDB%20support%20and%20re-use%20download%20mode%20option%3C%2FLI%3E%0A%3CLI%3EChange%20target%20connection%20method%20for%20Memory%20validation%20tool%20for%20MCUs%3C%2FLI%3E%0A%3CLI%3ESync%20Memory%20validation%20tool%20with%20register%20init%20component%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EOverview%20of%20Data%20for%20Config%20Tools%20v13%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EGeneral%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3ESupport%20of%20SDK%202.13%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CLI%3EPins%20tool%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3EImproved%20labels%20of%20expansion%20headers%20in%20Pins%20tool%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CLI%3EPeripherals%20tool%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3ERegisters%20init.%20component%20%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3ENew%20FlexIO%20component%3C%2FLI%3E%0A%3CLI%3EImproved%20SEMC%20component%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3ESDK%20init.%20components%0A%3CUL%3E%0A%3CLI%3ESupport%20of%20FCB%20component%20for%20RT117x%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%3ERegister%20init.%20components%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CLI%3ETEE%20tool%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3ESupport%20of%20option%20to%20enable%20generation%20of%20code%20hardened%20against%20instruction%20glitches%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CLI%3EMemory%20validation%20tool%3C%2FLI%3E%0A%3CUL%3E%0A%3CLI%3ESupport%20of%20RT1xxx%20processors%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CLI%3EBugfixes%20and%20minor%20improvements%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId--28665444%22%20id%3D%22toc-hId-86715196%22%20id%3D%22toc-hId-881838910%22%3E%3CSPAN%3ECommunity%3C%2FSPAN%3E%3C%2FH4%3E%0A%3CH3%20id%3D%22toc-hId--39168548%22%20class%3D%22lia-indent-padding-left-30px%22%20id%3D%22toc-hId-76212092%22%20style%3D%22padding-left%20%3A%2030px%3B%22%20id%3D%22toc-hId-871335806%22%20style%3D%22padding-left%20%3A%2030px%3B%22%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmcuxpresso%2Fmcuxpresso-config%22%20target%3D%22_blank%22%20data-objecttype%3D%2214%22%3EMCUXpresso%20Config%20Tools%3C%2FA%3E%3C%2FSPAN%3E%3C%2FH3%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1585537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20are%20pleased%20to%20announce%20that%20MCUXpresso%20Config%20Tools%20v13%20are%20now%20available.%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎01-19-2023 07:48 AM
Updated by:
