MCUEpresso - Pins editor issue - last pin
1,568件の閲覧回数
george_ch
Ref: MCUEpresso Config Tools Version 4.0
Pins editor for MK02FN128VFM
Ref pin 32
Having set pin 32 to PTD7  -  I'm unable to set it back to
(n/a, disabled) when clicking 'Done' in the pins editor.
My mex file attached.
1,418件の閲覧回数
antonintomanec
I just opened your mex in Tools V4.0 and in Pins view on pin 32, in pins editor(dialog) I unchecked PTD7 and checked the last (n/a,disabled), then 'Done'.
Please see the attached mex with the result.
Also in Sources view in BOARD_InitPins(void) comment you shall see:
- {pin_num: '32', peripheral: n/a, signal: disabled, pin_signal: PTD7/UART0_TX/FTM0_CH1/FTM0_FLT1}
Please let me know what step exactly does not work for you.
