GPIO defines
GPIO defines
2,384 次查看
nobodyKnows
I generated a pin_mux.h with MCUXpresso Config Tool V6 for a KL27Z256. The generated code looks good but it is only for GPIO and not for FGPIO. Is there a way to generate defines for both GPIO and FGPIO?
Thanks a lot and best regards,
Maximilian
2 回复数
2,230 次查看
Lukas_Heczko
Hi Maximilian,
Sorry for delayed response. Indeed, FGPIO register aliases were not considered in MCUXpresso Pins tool so far. We will include it in next version of MCUXpresso Configuraiton Tools. Thank you for your feedback!
Thank you,
Lukas
2,231 次查看
nobodyKnows
It seems there is no offical solution but I modified the code generation script to do this.
The script is in this folder:
C:\ProgramData\NXP\mcu_data_v6\processors\MKL27Z256xxx4\ksdk2_0\scripts\pins
