FRDM-K28F configuration with RTOS , UART & LWIP.
2,756件の閲覧回数
oriinbar
Hi all.
i would like to use the MCU Expresso config tools - to create a new configuration for my new NXP Frdm-K28F board.
how do I create/config a new FRDM-K28F configuration with RTOS , UART & LWIP?
regards
Ori Inbar
タグ(1)
2 返答(返信)
2,387件の閲覧回数
oriinbar
Thank you .
i will add lwm2m myself.
please note that i'm stuck on DAPLINKBOOT - and i don't know where to get the recovery SW that was originally on the board (opened a new issueHow to recover FRDM-K28F )
thx
ori inbar
2,387件の閲覧回数
marek-trmac
Hi Ori Inbar,
I suppose you already have FRDM-K28F SDK package. New configuration in MCUXpresso Config Tools is created using:
  • main menu - File - New Configuration; Next>
  • Select SDK path where FRDM-K28F SDK package is unzipped; Next>
  • Select Boards - FRDM-K28F - New FRDM-K28F configuration; Finish
  • main menu - Tools - Project Generator
  • Select RTOS and drivers you want to use
Note: it seems `lwip` is not supported for K28F
Marek
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
