Hi Zbynek and Omar.
thank you for reporting this problem. It will be fixed in next MCUXpresso Config Tools update. Meanwhile, you can use attached patch to fix the issue for KV10 and KV11 processors.
How to install the patch:
MCUXpresso Config Tools v7: Go to File > Data Manager > Import, select the attached archive and choose processors you want to update
MCUXpresso IDE 11.1.x: Go to Config Tools > Data Manager > Import, select the attached archive and choose processors you want to update
After installing the patch please restart the tool.
Lukas
