LPC1518JBD64 Programming Spec
已解决
跳至解决方案
3,733 次查看
Leap_Electronic
This is Alex from Leaptronix.
We are the third party of programmer.
Could we apply below IC programming spec
LPC1518JBD64
Thanks and have a good day.
标签 (1)
1 解答
3,618 次查看
kerryzhou
Hi Ryan Tseng,
  You are welcome.
  So, please help to mark the correct answer or assumed answered item, just to close this question, thank you!
Wish it helps you!
Kerry
在原帖中查看解决方案
3 回复数
3,618 次查看
kerryzhou
Hi Ryan Tseng ,
  This community block is mainly used for the kinetis, if you have the LPC question, you can post your question in this area:
 LPC Microcontrollers
  LPC1518JBD64 is the Cortex M3 core, so you can check the ARM core SWD/JTAG programmer, and the LPC1518JBD64 flash operation in the user manual.
If you have more questions, please create your question in the LPC area, the LPC engineer will help you in details.
Wish it helps you!
Kerry
3,618 次查看
Leap_Electronic
Thanks for the respond and help.
I will post in the LPC area.
3,618 次查看
kerryzhou
Hi Ryan Tseng,
  You are welcome.
Wish it helps you!
Kerry
