KEA-128 BOOTLOADER
已解决
KEA-128 BOOTLOADER
跳至解决方案
4,175 次查看
ümitgün
Hello
I am trying to do bootloader for kea-128 series. I found https://community.nxp.com/thread/459210 this post. This code its working fine when you are using first time to bootloader but when i try to update my code in flash I couldn't connect to device. How can i solved my problem?  or I am trying to find KEA-128 series bootloader code example for Kinetis Design Studio project any answer can help me.
Thank you for answer.
标签 (1)
标记 (2)
1 解答
3,710 次查看
miduo
Actually we had provide the UART Bootloader for KEA family with an application note. See here:
https://www.nxp.com/docs/en/application-note/AN5400.pdf
And the code also provide as:https://www.nxp.com/docs/en/application-note-software/AN5400SW.zip
在原帖中查看解决方案
2 回复数
3,711 次查看
miduo
3,710 次查看
ümitgün
I did not see this post i will look this project. Thanks a lot.
