Freedom Bootloader K66, CAN feature ?
已解决
跳至解决方案
2,551 次查看
alexco
Hi, I have successfully installed the Freedom Bootloader v2 on my MCU (mk66FX1M0). Currently I use USB and Flash Tool to flash my binary files, I know that I can also use different peripherals  like SPI, I2C or UART, unfortunately It seems that the bootloader for the K66 doesn't handle CAN (I found no code for it in the sources...). But the k66 has 2 CAN modules..I wondered I there was a way to implement it knowing that the CAN is available for other MCUs. Maybe there is a way to adapt the code.
Thank you for your help,
Alex
1 解答
2,374 次查看
Hui_Ma
I checked the NXP Kinetis bootloader V2.0.0 package KV46 bootloader project supports CAN interface.
Customer could check [bootloader] project for MKV46F16 as an example:
..\NXP_Kinetis_Bootloader_2_0_0\targets\MKV46F16
Thank you for the attention.
Mike
在原帖中查看解决方案
2 回复数
2,375 次查看
Hui_Ma
Mike
2,374 次查看
alexco
Hi Mike,
Thank you for your answer,
I will work with this project, and try to adapt the CAN for my MK66 .
Alex
