set GPIO2_DAT15/SDHC2_DAT4 as GPIO
dz_tiger
In the LX2160A Reference Manual, for IIC7_SDA/SDHC2_DAT4/GPIO2_DAT15/XSPI1_B_DATA4, you need to modify the Reset Configuration Word (RCW) to select the GPIO function for this pin. SDHC2_BASE_PMUX=2 is set:
Reset Configuration Word (RCW):
00000000: 4c434330 304c004c 00000000 00000000
00000010: 00000000 0c010000 00000000 00000000
00000020: 390001a0 00002580 00000000 1b009640
00000030: 08008410 00000049 00000000 00000000
00000040: 00000000 00000000 00000000 00000000
00000050: 00000000 00000000 00000000 00000000
00000060: 00000000 00000000 000270a5 00000000
00000070: 88a80011 00150002
GPIO2_DAT15:
gpio set 47 shows (gpio 47) value is 1
But there is no output from the GPIO pin. Do I have to add anything in device tree? What else is missing or wrong?
Thank you,
dz_tiger
dz_tiger
After adding SDHC2_DAT74_PMUX=1, it works.
Case close. Thank you,
Dz_tiger
dz_tiger
Hi Kenli,
Thank you for your reply on the GPIO pin.
I have rebuilt and flashed RCW with SDHC2_DAT74_PMUX=1. But I'm still not getting 1.8v on PIN C26.
I assume C26 is the right pin from LX2160A-1919583.pdf
My current RCW settings are:
       00000030: 08008408 00000049 00000000 00000000
I'm a little confused:
On "User guide Rev. 6.1.55_2.2.0 — 24 January 2024" for LX2160ARDB,
  1. The GPIO2_DAT15, shall be at BANK-2, pin number 47, On Pin C26
  2. I used uboot command: gpio set 47  or gpio mpc@0231000015
  3. In the above User Manual, it needs to set BRDCFG5[2] to 1 . Not sure if I have to do the similar to GPIO2_DAT15,
  4. I2c mw 66 55 64, which chip has address 66, and what register (55) for GPIO2_DAT15 gpio pin?
Thank you,
Dz_tiger
kenli
You must set the RCW field SDHC2_DAT74_PMUX=1 to mux the SDHC2_DAT4 pin as GPIO, as SDHC2_BASE_PMUX does not control this specific pin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2303069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eset%20GPIO2_DAT15%2FSDHC2_DAT4%20as%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%3EIn%20the%20LX2160A%20Reference%20Manual%2C%20for%20IIC7_SDA%2FSDHC2_DAT4%2FGPIO2_DAT15%2FXSPI1_B_DATA4%2C%20you%20need%20to%20modify%20the%20Reset%20Configuration%20Word%20(RCW)%20to%20select%20the%20GPIO%20function%20for%20this%20pin.%26nbsp%3BSDHC2_BASE_PMUX%3D2%20is%20set%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EReset%20Configuration%20Word%20(RCW)%3A%3CBR%20%2F%3E00000000%3A%204c434330%20304c004c%2000000000%2000000000%3CBR%20%2F%3E00000010%3A%2000000000%200c010000%2000000000%2000000000%3CBR%20%2F%3E00000020%3A%20390001a0%2000002580%2000000000%201b009640%3CBR%20%2F%3E00000030%3A%2008008410%2000000049%2000000000%2000000000%3CBR%20%2F%3E00000040%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E00000050%3A%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E00000060%3A%2000000000%2000000000%20000270a5%2000000000%3CBR%20%2F%3E00000070%3A%2088a80011%2000150002%3C%2FP%3E%3CP%3EGPIO2_DAT15%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Egpio%20set%2047%20shows%20(gpio%2047)%20value%20is%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EBut%20there%20is%20no%20output%20from%20the%20GPIO%20pin.%20Do%20I%20have%20to%20add%20anything%20in%20device%20tree%3F%20What%20else%20is%20missin%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eg%20or%20wrong%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3EThank%20you%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3Edz_tiger%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20set%20GPIO2_DAT15%2FSDHC2_DAT4%20as%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EYou%20must%20set%20the%20RCW%20field%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESDHC2_DAT74_PMUX%3D1%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eto%20mux%20the%20SDHC2_DAT4%20pin%20as%20GPIO%2C%20as%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESDHC2_BASE_PMUX%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Edoes%20not%20control%20this%20specific%20pin.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20set%20GPIO2_DAT15%2FSDHC2_DAT4%20as%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3EHi%20Kenli%2C%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EThank%20you%20for%20your%20reply%20on%20the%20GPIO%20pin.%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EI%20have%20rebuilt%20and%20flashed%20RCW%20with%20SDHC2_DAT74_PMUX%3D1.%20But%20I'm%20still%20not%20getting%201.8v%20on%20PIN%20C26.%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EI%20assume%20C26%20is%20the%20right%20pin%20from%20LX2160A-1919583.pdf%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EMy%20current%20RCW%20settings%20are%3A%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EReset%20Configuration%20Word%20(RCW)%3A%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000000%3A%204c434330%20304c004c%2000000000%2000000000%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000010%3A%2000000000%200c010000%2000000000%2000000000%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000020%3A%20390001a0%2000002580%2000000000%201b009640%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000030%3A%2008008408%2000000049%2000000000%2000000000%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000040%3A%2000000000%2000000000%2000000000%2000000000%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000050%3A%2000000000%2000000000%2000000000%2000000000%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000060%3A%2000000000%2000000000%20000270a5%2000000000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B00000070%3A%2088a80011%2000150002%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EI'm%20a%20little%20confused%3A%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EOn%20%22User%20guide%20Rev.%206.1.55_2.2.0%20%E2%80%94%2024%20January%202024%22%20for%20LX2160ARDB%2C%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CDIV%20class%3D%22%22%3EThe%20GPIO2_DAT15%2C%20shall%20be%20at%20BANK-2%2C%20pin%20number%2047%2C%20On%20Pin%20C26%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3EI%20used%20uboot%20command%3A%20gpio%20set%2047%26nbsp%3B%20or%20gpio%20mpc%400231000015%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3EIn%20the%20above%20User%20Manual%2C%20it%20needs%20to%20set%20BRDCFG5%5B2%5D%20to%201%20.%20Not%20sure%20if%20I%20have%20to%20do%20the%20similar%20to%20GPIO2_DAT15%2C%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CDIV%20class%3D%22%22%3EI2c%20mw%2066%2055%2064%2C%20which%20chip%20has%20address%2066%2C%20and%20what%20register%20(55)%20for%20GPIO2_DAT15%20gpio%20pin%3F%3C%2FDIV%3E%3C%2FLI%3E%3C%2FOL%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gpio1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gpio1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gpio1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376178iDA8520D5C8D5FE02%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22gpio1.png%22%20alt%3D%22gpio1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Egpio1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EThank%20you%2C%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3EDz_tiger%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20set%20GPIO2_DAT15%2FSDHC2_DAT4%20as%20GPIO%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20adding%20SDHC2_DAT74_PMUX%3D1%2C%20it%20works.%3C%2FP%3E%3CP%3ECase%20close.%20Thank%20you%2C%3C%2FP%3E%3CP%3EDz_tiger%3C%2FP%3E%3C%2FLINGO-BODY%3E
