rte_eth_rx_burst -> returning same mbuff pointer twice consecutively
1,080 次查看
Chidananda22
From my application calling rte_eth_rx_burst
checking sometimes same mbuff coming twice . Checked code buffer not freeing . With out mbuff free what could be the scenario that same mbuff pointer received twice .
标签 (1)
5 回复数
1,073 次查看
yipingwang
Without an explicit mbuf free in your code, the most likely scenarios are that the mbuf is still being effectively returned/reused through another path in the application or shared unsafely across threads/cores, or that a special driver/path-specific buffer handling issue is corrupting lifecycle state.
  • Cross-core/shared mbuf ownership issue. One documented case used one CPU for RX and many worker CPUs consuming mbufs from a ring; the mbuf address was then seen reused/overwritten while still referenced elsewhere. NXP specifically asked whether RTE_MBUF_REFCNT_ATOMIC was enabled for multicore access, and the customer said yes, but the issue was still treated as application-level ownership/lifetime handling.,
  • Duplicate release or hidden return path in the application pipeline. NXP’s guidance in that case was to instrument buffer allocate/release/packet-send actions to see whether the same address was being released back to the buffer pool more than once.
  • PMD/driver returning malformed mbufs to pool in special paths. There is a separate DPAA2 PMD case involving chained mbufs where mbufs returned to the mempool appeared corrupted ( next not cleared), causing sanity-check failures on later allocation. That is not the same symptom as your report, but it does show that special buffer handling paths can lead to later reuse/corruption symptoms.
  • Same source and destination mbuf in crypto path. In a DPAA security/IPsec case, NXP noted that if sym->m_dst is NULL , then m_src and m_dst use the same mbuf. That can make packet contents appear rewritten “in place” under load, even though the pointer identity did not change.
1,064 次查看
Chidananda22
thanks @yipingwang  for your quick reply and suggestions. from code i am not to figure out more . Any DPDK debug flag can help ?
1,038 次查看
yipingwang
  1. Enable DPDK log levels (first thing to try)
Run your app with:
--log-level=8
What you’ll see:
  • RX descriptor handling
  • buffer allocation/recycling
  • PMD behavior
  1. Enable mbuf debug checking (very useful)
Rebuild DPDK with:
CONFIG_RTE_LIBRTE_MBUF_DEBUG=y
This will:
  • Validate mbuf consistency
  • Catch:
    • corrupted metadata
    • reused mbuf incorrectly
    • invalid refcnt
  1. Enable mempool debug
      CONFIG_RTE_LIBRTE_MEMPOOL_DEBUG=y
Helps detect:
  • double allocation
  • cache corruption
  • same buffer returned twice from mempool
  1. Poison/free tracking (EXTREMELY useful)
You can enable memory overwrite checking:
CONFIG_RTE_MALLOC_DEBUG=y
and
--mp-alloc=debug
This helps detect:
  • overwrite before/after mbuf
  • hidden memory corruption
  1. Quick isolation trick (VERY effective)
Run
testpmd -- -i
Then:
set fwd rxonly
start
If duplication disappears:
  • your application bug
If still happens:
  • PMD / HW / queue config issue
1,028 次查看
Chidananda22
Thanks @yipingwang  for Quick reply . I will try and update you .
One observation every time multiple mbuf ( same address coming ) getting below prints in screen
fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffd61c0 (5) affined thread - 1953
fslmc: dpaa2_configure_stashing(): Portal= 5 CPU= 10 SDEST= 5
fslmc: DPAA Portal=0x17ffd61c0 (5) is affined to thread 1953
972 次查看
yipingwang
Those fslmc / dpaa2 portal affined thread logs strongly indicate portal (QBMan SWP) is being re-attached to a different thread/core, which can break ownership model → leading to mbuf reuse / duplication symptoms.
%3CLINGO-SUB%20id%3D%22lingo-sub-2379408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Erte_eth_rx_burst%20-%26gt%3B%20%E8%BF%9E%E7%BB%AD%E4%B8%A4%E6%AC%A1%E8%BF%94%E5%9B%9E%E7%9B%B8%E5%90%8C%E7%9A%84%20mbuff%20%E6%8C%87%E9%92%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8E%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%B0%83%E7%94%A8%20rte_eth_rx_burst%20%3C%2FP%3E%3CP%3E%E6%9C%89%E6%97%B6%E5%90%8C%E4%B8%80%20mbuff%20%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%A4%E6%AC%A1%E3%80%82%E5%B7%B2%E6%A3%80%E6%9F%A5%E4%BB%A3%E7%A0%81%E7%BC%93%E5%86%B2%E5%8C%BA%E6%9C%AA%E9%87%8A%E6%94%BE%20.%E5%9C%A8%E6%B2%A1%E6%9C%89%E7%A9%BA%E9%97%B2%20mbuff%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%90%8C%E4%B8%80%20mbuff%20%E6%8C%87%E9%92%88%E4%BC%9A%E6%94%B6%E5%88%B0%E4%B8%A4%E6%AC%A1%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2379408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E8%AE%BE%E5%A4%87%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rte_eth_rx_burst%20-%26gt%3B%20returning%20same%20mbuff%20pointer%20twice%20consecutively%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3COL%3E%0A%3CLI%3E%3CSTRONG%3E%E5%90%AF%E7%94%A8%20DPDK%20%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%EF%BC%88%E9%A6%96%E5%85%88%E5%B0%9D%E8%AF%95%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E--%E6%97%A5%E5%BF%97%E7%BA%A7%E5%88%AB%3D8%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E4%BC%9A%E7%9C%8B%E5%88%B0%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%A4%84%E7%90%86%20RX%20%E6%8F%8F%E8%BF%B0%E7%AC%A6%3C%2FLI%3E%0A%3CLI%3E%E7%BC%93%E5%86%B2%E5%8C%BA%E5%88%86%E9%85%8D%2F%E5%86%8D%E5%BE%AA%E7%8E%AF%3C%2FLI%3E%0A%3CLI%3EPMD%20%E8%A1%8C%E4%B8%BA%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3COL%20start%3D%222%22%3E%0A%3CLI%3E%3CSTRONG%3E%E5%90%AF%E7%94%A8%20mbuf%20%E8%B0%83%E8%AF%95%E6%A3%80%E6%9F%A5%EF%BC%88%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%B7%A5%E5%85%B7%E9%87%8D%E5%BB%BA%20DPDK%3C%2FP%3E%0A%3CP%3ECONFIG_RTE_LIBRTE_MBUF_DEBUG%3Dy%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%B0%86%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%AA%8C%E8%AF%81%20mbuf%20%E7%9A%84%E4%B8%80%E8%87%B4%E6%80%A7%3C%2FLI%3E%0A%3CLI%3E%E6%8E%A5%E4%BD%8F%EF%BC%9A%0A%3CUL%3E%0A%3CLI%3E%E6%8D%9F%E5%9D%8F%E7%9A%84%E5%85%83%E6%95%B0%E6%8D%AE%3C%2FLI%3E%0A%3CLI%3E%E9%94%99%E8%AF%AF%E5%9C%B0%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%E4%BA%86%20mbuf%3C%2FLI%3E%0A%3CLI%3E%E6%97%A0%E6%95%88%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%223%22%3E%0A%3CLI%3E%3CSTRONG%3E%E5%90%AF%E7%94%A8%20mempool%20%E8%B0%83%E8%AF%95%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%20%20%20%20%20%20CONFIG_RTE_LIBRTE_MEMPOOL_DEBUG%3Dy%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%A3%80%E6%B5%8B%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%8F%8C%E5%88%86%E9%85%8D%3C%2FLI%3E%0A%3CLI%3E%E7%BC%93%E5%AD%98%E6%8D%9F%E5%9D%8F%3C%2FLI%3E%0A%3CLI%3E%E4%BB%8E%20mempool%20%E8%BF%94%E5%9B%9E%E4%B8%A4%E6%AC%A1%E7%9B%B8%E5%90%8C%E7%9A%84%E7%BC%93%E5%86%B2%E5%8C%BA%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%224%22%3E%0A%3CLI%3E%3CSTRONG%3E%E6%AF%92%E7%89%A9%2F%E8%87%AA%E7%94%B1%E8%BF%BD%E8%B8%AA%EF%BC%88%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E5%86%85%E5%AD%98%E8%A6%86%E7%9B%96%E6%A3%80%E6%9F%A5%EF%BC%9A%3C%2FP%3E%0A%3CP%3ECONFIG_RTE_MALLOC_DEBUG%3Dy%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%8F%8A%3C%2FP%3E%0A%3CP%3E-mp-alloc%3Ddebug%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%A3%80%E6%B5%8B%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E8%A6%86%E7%9B%96%E4%B9%8B%E5%89%8D%2F%E4%B9%8B%E5%90%8E%E7%9A%84%20mbuf%3C%2FLI%3E%0A%3CLI%3E%E9%9A%90%E8%97%8F%E7%9A%84%E5%86%85%E5%AD%98%E6%8D%9F%E5%9D%8F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3COL%20start%3D%225%22%3E%0A%3CLI%3E%3CSTRONG%3E%E5%BF%AB%E9%80%9F%E9%9A%94%E7%A6%BB%E6%8A%80%E5%B7%A7%EF%BC%88%E9%9D%9E%E5%B8%B8%E6%9C%89%E6%95%88%EF%BC%89%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E8%BF%90%E8%A1%8C%3C%2FP%3E%0A%3CP%3Etestpmd%20--%20-i%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%3Eset%20fwd%20rxonly%3C%2FP%3E%0A%3CP%3E%E5%BC%80%E5%A7%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%87%8D%E5%A4%8D%E6%B6%88%E5%A4%B1%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%94%99%E8%AF%AF%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%8D%E7%84%B6%E5%8F%91%E7%94%9F%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EPMD%20%2F%20HW%20%2F%20%E9%98%9F%E5%88%97%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rte_eth_rx_burst%20-%26gt%3B%20returning%20same%20mbuff%20pointer%20twice%20consecutively%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E5%92%8C%E5%BB%BA%E8%AE%AE%E3%80%82%E6%88%91%E6%97%A0%E6%B3%95%E4%BB%8E%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%89%BE%E5%87%BA%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%E6%9C%89%E4%BB%BB%E4%BD%95%20DPDK%20%E8%B0%83%E8%AF%95%E6%A0%87%E5%BF%97%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rte_eth_rx_burst%20-%26gt%3B%20returning%20same%20mbuff%20pointer%20twice%20consecutively%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%98%8E%E7%A1%AE%E7%9A%84%20mbuf%20%E7%A9%BA%E7%99%BD%EF%BC%8C%E6%9C%80%E6%9C%89%E5%8F%AF%E8%83%BD%E7%9A%84%E6%83%85%E5%86%B5%E6%98%AF%20mbuf%20%E4%BB%8D%E5%9C%A8%E9%80%9A%E8%BF%87%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%E5%85%B6%E4%BB%96%E8%B7%AF%E5%BE%84%E6%9C%89%E6%95%88%E8%BF%94%E5%9B%9E%2F%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%88%96%E8%80%85%E4%B8%8D%E5%AE%89%E5%85%A8%E5%9C%B0%E8%B7%A8%E7%BA%BF%E7%A8%8B%2F%E5%86%85%E6%A0%B8%E5%85%B1%E4%BA%AB%EF%BC%8C%E6%88%96%E8%80%85%E7%89%B9%E5%AE%9A%E4%BA%8E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E8%B7%AF%E5%BE%84%E7%9A%84%E7%89%B9%E6%AE%8A%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%84%E7%90%86%E9%97%AE%E9%A2%98%E6%AD%A3%E5%9C%A8%E7%A0%B4%E5%9D%8F%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%0A%3CUL%20class%3D%22%22%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E8%B7%A8%E6%A0%B8%2F%E5%85%B1%E4%BA%AB%20mbuf%20%E6%89%80%E6%9C%89%E6%9D%83%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E4%B8%80%E4%B8%AA%E8%AE%B0%E5%BD%95%E5%9C%A8%E6%A1%88%E7%9A%84%E6%A1%88%E4%BE%8B%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%E4%B8%80%E4%B8%AA%20CPU%20%E7%94%A8%E4%BA%8E%20RX%EF%BC%8C%E8%AE%B8%E5%A4%9A%E5%B7%A5%E4%BD%9C%E7%A8%8B%E5%BA%8F%20CPU%20%E6%B6%88%E8%80%97%E4%BA%86%E7%8E%AF%E4%B8%AD%E7%9A%84%20mbuf%EF%BC%9B%E7%84%B6%E5%90%8E%E7%9C%8B%E5%88%B0%20mbuf%20%E5%9C%B0%E5%9D%80%E8%A2%AB%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%2F%E8%A6%86%E7%9B%96%EF%BC%8C%E4%BD%86%E4%BB%8D%E5%9C%A8%E5%85%B6%E4%BB%96%E5%9C%B0%E6%96%B9%E8%A2%AB%E5%BC%95%E7%94%A8%E3%80%82%E6%81%A9%E6%99%BA%E6%B5%A6%E7%89%B9%E5%88%AB%E8%AF%A2%E9%97%AE%3CSPAN%3E%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3E%20RTE_MBUF_REFCNT_ATOMIC%3C%2FCODE%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E6%98%AF%E5%90%A6%E4%B8%BA%E5%A4%9A%E6%A0%B8%E8%AE%BF%E9%97%AE%E5%90%AF%E7%94%A8%EF%BC%8C%E5%AE%A2%E6%88%B7%E8%AF%B4%E6%98%AF%EF%BC%8C%E4%BD%86%E9%97%AE%E9%A2%98%E4%BB%8D%E8%A2%AB%E8%A7%86%E4%B8%BA%E5%BA%94%E7%94%A8%E7%BA%A7%E6%89%80%E6%9C%89%E6%9D%83%2F%E5%AF%BF%E5%91%BD%E5%A4%84%E7%90%86%E3%80%81%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%AE%A1%E9%81%93%E4%B8%AD%E6%9C%89%E9%87%8D%E5%A4%8D%E7%9A%84%E7%89%88%E6%9C%AC%E6%88%96%E9%9A%90%E8%97%8F%E7%9A%84%E8%BF%94%E5%9B%9E%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E6%8C%87%E5%AF%BC%E6%96%B9%E9%92%88%E6%98%AF%E5%88%86%E6%9E%90%E7%BC%93%E5%86%B2%E5%8C%BA%E5%88%86%E9%85%8D%2F%E9%87%8A%E6%94%BE%2F%E6%95%B0%E6%8D%AE%E5%8C%85%E5%8F%91%E9%80%81%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BB%A5%E6%9F%A5%E7%9C%8B%E7%9B%B8%E5%90%8C%E7%9A%84%E5%9C%B0%E5%9D%80%E6%98%AF%E5%90%A6%E8%A2%AB%E5%A4%9A%E6%AC%A1%E9%87%8A%E6%94%BE%E5%9B%9E%E7%BC%93%E5%86%B2%E6%B1%A0%E3%80%82%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3EPMD%2Fdriver%20%E5%9C%A8%E7%89%B9%E6%AE%8A%E8%B7%AF%E5%BE%84%E4%B8%AD%E5%90%91%E6%B1%A0%E8%BF%94%E5%9B%9E%E7%95%B8%E5%BD%A2%20mbufs%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%8F%A6%E5%A4%96%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E6%B6%89%E5%8F%8A%E9%93%BE%E5%BC%8F%20mbuf%20%E7%9A%84%20DPAA2%20PMD%20%E6%A1%88%E4%BE%8B%EF%BC%8C%E5%9C%A8%E8%AF%A5%E6%A1%88%E4%BE%8B%E4%B8%AD%EF%BC%8C%E8%BF%94%E5%9B%9E%20mempool%20%E7%9A%84%20mbuf%20%E5%87%BA%E7%8E%B0%E6%8D%9F%E5%9D%8F%EF%BC%88%3CSPAN%3E%20%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3E%E4%B8%8B%E4%B8%80%E4%B8%AA%3C%2FCODE%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%9C%AA%E6%B8%85%E9%99%A4%EF%BC%89%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AF%BC%E8%87%B4%E4%BB%A5%E5%90%8E%E5%88%86%E9%85%8D%E6%97%B6%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%80%A7%E6%A3%80%E6%9F%A5%E5%A4%B1%E8%B4%A5%E3%80%82%E8%BF%99%E4%B8%8E%E6%82%A8%E7%9A%84%E6%8A%A5%E5%91%8A%E7%97%87%E7%8A%B6%E4%B8%8D%E5%90%8C%EF%BC%8C%E4%BD%86%E5%AE%83%E7%A1%AE%E5%AE%9E%E8%A1%A8%E6%98%8E%E7%89%B9%E6%AE%8A%E7%9A%84%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%84%E7%90%86%E8%B7%AF%E5%BE%84%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E4%BB%A5%E5%90%8E%E7%9A%84%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%2F%E6%8D%9F%E5%9D%8F%E7%97%87%E7%8A%B6%E3%80%82%3C%2FLI%3E%0A%3CLI%20class%3D%22%22%3E%3CSTRONG%20class%3D%22%22%3E%E5%8A%A0%E5%AF%86%E8%B7%AF%E5%BE%84%E4%B8%AD%E7%9A%84%E6%BA%90%E5%92%8C%E7%9B%AE%E6%A0%87%20mbuf%20%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%9C%A8%20DPAA%20%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%2FIPsec%20%E6%A1%88%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8C%87%E5%87%BA%EF%BC%8C%E5%A6%82%E6%9E%9C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Esym-%26gt%3Bm_dst%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%B8%BA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ENULL%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%8C%E5%88%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Em_src%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Em_dst%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20mbuf%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E4%BD%BF%E6%95%B0%E6%8D%AE%E5%8C%85%E5%86%85%E5%AE%B9%E5%9C%A8%E8%B4%9F%E8%BD%BD%E6%83%85%E5%86%B5%E4%B8%8B%20%22%E5%B0%B1%E5%9C%B0%20%22%E9%87%8D%E5%86%99%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%8C%87%E9%92%88%E6%A0%87%E8%AF%86%E6%B2%A1%E6%9C%89%E6%94%B9%E5%8F%98%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rte_eth_rx_burst%20-%26gt%3B%20returning%20same%20mbuff%20pointer%20twice%20consecutively%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E4%BC%9A%E5%B0%BD%E9%87%8F%E5%90%91%E6%82%A8%E6%B1%87%E6%8A%A5%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%AF%8F%E5%BD%93%E5%A4%9A%E4%B8%AA%20mbuf%EF%BC%88%E6%9D%A5%E8%87%AA%E5%90%8C%E4%B8%80%E5%9C%B0%E5%9D%80%EF%BC%89%E5%88%B0%E8%BE%BE%E6%97%B6%EF%BC%8C%E5%B1%8F%E5%B9%95%E4%B8%8A%E9%83%BD%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20%E6%96%B0%E5%A2%9E%E9%97%A8%E6%88%B7%200x17ffd61c0%20(5)%20%E5%85%B3%E8%81%94%E7%BA%BF%E7%A8%8B%20-%201953%3CBR%20%2F%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20%E9%97%A8%E6%88%B7%3D%205%20CPU%3D%2010%20SDEST%3D%205%3CBR%20%2F%3Efslmc%3A%20DPAA%20%E9%97%A8%E6%88%B7%3D0x17ffd61c0%20(5)%20%E5%B7%B2%E7%BB%91%E5%AE%9A%E8%87%B3%E7%BA%BF%E7%A8%8B%201953%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2380657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20rte_eth_rx_burst%20-%26gt%3B%20returning%20same%20mbuff%20pointer%20twice%20consecutively%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2380657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E8%BF%99%E4%BA%9B%20%3CCODE%20translate%3D%22no%22%3Efslmc%20%2F%20dpaa2%20portal%20affined%20thread%3C%2FCODE%3E%20%E6%97%A5%E5%BF%97%E5%BC%BA%E7%83%88%E8%A1%A8%E6%98%8E%E9%97%A8%E6%88%B7%EF%BC%88QbMan%20SWP%EF%BC%89%E6%AD%A3%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E7%BA%BF%E7%A8%8B%2F%E5%86%85%E6%A0%B8%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E7%A0%B4%E5%9D%8F%E6%89%80%E6%9C%89%E6%9D%83%E6%A8%A1%E5%9E%8B%20%E2%86%92%20%E5%AF%BC%E8%87%B4%20mbuf%20%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%2F%E9%87%8D%E5%A4%8D%E7%97%87%E7%8A%B6%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
