problems building
problems building
2,244 次查看
martinleisner
I'm building yocto releases for L1012A freeway.
Is there a document which entails "what's in different images" (or is this an exercise for the interested reader).
Building both scarthgap and styhead, when I attempt to create
fsl-image-network-full-cmdline
pktgen-dpdk (21.11.0) had a number of compile problems.
I fixed some, added some ignore warnings flags (and before tried to fix the missing prototypes problems (mostly stdlib.h), then I got "undefined symbols" I couldn't find.
I tried some "howtos" about removing recipes, but none worked....Is there a good way to remove recipes (or do I need to remove a containing recipe)
Marty
Marty
2,197 次查看
Oswalag
Please try to build your image with the mickledore branch, it should work without any issue.
2,156 次查看
martinleisner
mickledore does the same as a few other recent yocto releases.
fail the same way.
When I removed some of the compiling errors, others (undefined symbols) appears....
Following a few posts on how to remove recipes from yocto failed....
2,111 次查看
Oswalag
I didn't have the errors you mentioned on mickledore, please follow the LLDPUG, install all the dependencies and try again.
