ode WArrior DDR validation: injecting SPD
1,122件の閲覧回数
renaud
I have used the DDR validation by reading the SPD from the UDIMM (on ls1046a-rdb).
Next I tried to define the DRAM as a discrete DRAM or import registers from the target but the validation failed for some reason,
Our prototype will be injecting the SPD values in software from the boot loader. How can I load the SPD from a file to the DDR validation tool. It seems only DDR register values can be imported.
Renaud
1,049件の閲覧回数
Hector_Villarruel
I apologize for the short delay.
I can see that you have created a new case, in order to avoid any kind of confusion, we will continue the communication on the new case.
Hector Villarruel
