nor flash verify
nor flash verify
jagxin
hello
             I have programmed the nor flash with the rcw generated from the pbl tool ,how to read the values that is in the nor flash
when i read 0XE8000000 I am finding 0xffffffff if when  i am executing the commands i was able to read the device id
change p:e8000000 00f0 16bit
change p:e8000aaa 00aa 16bit
change p:e8000554 0055 16bit
change p:e8000aaa 0090 16bit
display p:e8000000..e8000004
display p:e8100000..e8100004
how to find that the code is written to the flash?
lunminliang
Hello agxin j,
You can either use dump of flash programer or ccs command to read back the flash content.
Lunmin
jagxin
Hello sir
I had dumped the flash from evm to my board but still  am getting 0 at the console port how to solve this why am I no getting any u boot comments  the serial console ?
jagxin
dear sir
thanks for your reply
i have programmed the flash now and i have reverted hard coded rcw to settings corresponding  to boot from nor flash now i have connected my serial console i am getting a 0 on the hyper terminal how to find where it is getting stuck
i have probed the cs of nor flash it is toggling  but some soc information that is appearing in evm is not appearing
how to find the boot code is executing
regards
agxin.j
jagxin
sorry sir the last  snap short attached is for nand flash here is the snap for nor flash
jagxin
Source flash poke.tcl file is given for reading from freescale how is this code working ? To read the flash id is there any way to find if the flash is locked or not by reading
sinanakman
Senior Contributor III
Hi Agxin
Did you try the mem command I mentioned above ?
Sinan Akman
jagxin
thank you sir
it is reading now with mem  command
How this commands are providing the flash id ?
regards
agxin
sinanakman
Hi agxin
I don't have a CWTAP but you probably
have a "mem" command to display the
memory:
e.g.:
mem 0xe8000000 16
Let me know if this works.
Sinan Akman
sinanakman
What is the flash you are trying to program.
MT29F4G08ABADAWP you show in the log seems
to be a NAND flash and not  a NOR flash.
What is the exact part number of the flash you
Sinan Akman
