lx2160 use 1000base
lx2160 use 1000base
1,237件の閲覧回数
wutianyi
Hi  NXP:
   We want to configure the mode on the LX2160 to specify the network port as 1000base. But I only found the DPC configuration example in the DPAA2 manual. How to configure the kernel device tree.
Tianyi
タグ(1)
2 返答(返信)
1,208件の閲覧回数
June_Lu
The DPC file just means that the SerDes lanes, PCS, PHY configuration is all done in Linux as opposed to the MC firmware.
1,184件の閲覧回数
wutianyi
Thank you for your reply. We were able to fix it after modifying the DPC.
