ls1088a arm generic timer question
2,176件の閲覧回数
holder
I see in the ls1088a reference manual (Rev. 0, 02/2018) Table 2.1 the memory mapped addresses for the ARM Generic Timer CNTControlBase and CNTReadBase.
Where is the CNTCTLBase located?
How many timers are implemented?
thx,
bob
ラベル(2)
2 返答(返信)
2,006件の閲覧回数
alexander_yakov
LS1088 Reference Manual contains 5 embedded PDF documents, in Adobe Reader you can see these documents if you press Attachments button in the bottom left corner. Please see embedded arm_generic_timer.pdf document for the information about the timer. There is only one ARM generic timer implemented.
2,006件の閲覧回数
holder
Looks like the arm generic timer's are not memory mapped but accessed using instructions documented in the ARM A53 TRM (Chapter 8).
marking this closed.
