ls1046a usdpaa fmc -c error
1,129 次查看
hongyuanz
root@localhost:/home/user/dpaa# fmc -c usdpaa_config_ls1046_shared_24g.xml -p usdpaa_policy_24g_classif_frag_gtp_1queue.xml -a
ERR : Invocation of FM_PORT_SetPCD for fm0/port/MAC/10 failed with error code 0x00010013
ERR : Invocation of FM_PCD_KgSchemeDelete for fm0/port/MAC/10/dist/default_kernel_queue_mac10 failed with error code 0x00010013
1,108 次查看
yipingwang
Please customize fsl-ls1046a-rdb-usdpaa-shared.dts file according to your target board, then boot the target board with this dtb file.
Please modify the configuration file usdpaa_config_ls1046_shared_24g.xml  according to your target board.
