ls1046a linux
ls1046a linux
1,308 次查看
renaud
I got the ls1046a-rdb eval board running Linux 4.9.62. Is that the latest version to support the eval board?
I am trying to get Linux 5.11 to run. It start booting to the point where the kernel should acquire an IP address thru DHCP. It does not work. (the boot loader does acquire it so the server works).
Is the Ethernet support complete on Linux 5.11 as I can see much more code in 4.9.
Could you advise?
Cheers.
1 回复
1,297 次查看
Pavel
NXP offers LSDK 2012 for the LS1046ARDB board:
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/layerscap...
This LSDK supports LTS 4.19.139 and LTS 5.4.47 Linux kernel. See LSDK 2012 User Guide:
https://www.nxp.com/docs/en/user-guide/LSDKUG_Rev20.12.pdf
Use this LSDK.
