flex-installer
3,062件の閲覧回数
rans
Senior Contributor I
LLDPUG document specifies how to deploy storage with bootpartition, firmware, and rootfs files using flex-installer:
But in yocto build aside from rootfs.tar.gz file I can't find bootpartition file or storage file
see the full list here:
s tmp/deploy/images/ls1046ardb
atf
boot
fitImage
fitImage--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.bin
fitImage-its--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.its
fitImage-its-ls1046ardb
fitImage-linux.bin--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.bin
fitImage-linux.bin-ls1046ardb
fitImage-ls1046ardb.bin
fsl_fman_ucode_ls1046_r1.0_106_4_18.bin
fsl_fman_ucode_ls1046_r1.0_108_4_9.bin
fsl-ls1046a-qds--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-qds.dtb
fsl-ls1046a-qds-ls1046ardb.dtb
fsl-ls1046a-qds-sdk--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-qds-sdk.dtb
fsl-ls1046a-qds-sdk-ls1046ardb.dtb
fsl-ls1046a-rdb--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-rdb.dtb
fsl-ls1046a-rdb-ls1046ardb.dtb
fsl-ls1046a-rdb-sdk--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-rdb-sdk.dtb
fsl-ls1046a-rdb-sdk-ls1046ardb.dtb
fsl-ls1046a-rdb-usdpaa--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-rdb-usdpaa.dtb
fsl-ls1046a-rdb-usdpaa-ls1046ardb.dtb
fsl-ls1046a-rdb-usdpaa-shared--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.dtb
fsl-ls1046a-rdb-usdpaa-shared.dtb
fsl-ls1046a-rdb-usdpaa-shared-ls1046ardb.dtb
ggg
ls1046ardb_boot.scr
ls2-phy
ls-image-lite.env
ls-image-lite-ls1046ardb-20240320064309.rootfs.ext2.gz
ls-image-lite-ls1046ardb-20240320064309.rootfs.ext2.gz.u-boot
ls-image-lite-ls1046ardb-20240320064309.rootfs.manifest
ls-image-lite-ls1046ardb-20240320064309.rootfs.tar.gz
ls-image-lite-ls1046ardb-20240320064309.rootfs.wic.bz2
ls-image-lite-ls1046ardb-20240320064309.testdata.json
ls-image-lite-ls1046ardb.ext2.gz
ls-image-lite-ls1046ardb.ext2.gz.u-boot
ls-image-lite-ls1046ardb.manifest
ls-image-lite-ls1046ardb.tar.gz
ls-image-lite-ls1046ardb.testdata.json
ls-image-lite-ls1046ardb.wic.bz2
ls-image-lite-qoriq-ls104xa.wks
ls-image-main.env
ls-image-main-ls1046ardb-20240319203839.rootfs.manifest
ls-image-main-ls1046ardb-20240319203839.rootfs.tar.gz
ls-image-main-ls1046ardb-20240319203839.rootfs.wic.bmap
ls-image-main-ls1046ardb-20240319203839.rootfs.wic.bz2
ls-image-main-ls1046ardb-20240319203839.testdata.json
ls-image-main-ls1046ardb.manifest
ls-image-main-ls1046ardb.tar.gz
ls-image-main-ls1046ardb.testdata.json
ls-image-main-ls1046ardb.wic.bmap
ls-image-main-ls1046ardb.wic.bz2
ls-image-main-qoriq-ls104xa.wks
modules--6.1.y+git0+29549c7073-r0-ls1046ardb-20240319203839.tgz
modules-ls1046ardb.tgz
optee
rcw
u-boot.bin
u-boot.bin-tfa
u-boot.bin-tfa-secure-boot
u-boot-ls1046ardb.bin
u-boot-ls1046ardb.bin-tfa
u-boot-ls1046ardb.bin-tfa-secure-boot
u-boot-qoriq-initial-env-ls1046ardb-tfa
u-boot-qoriq-initial-env-ls1046ardb-tfa-2022.04+AUTOINC+7376547b9e+fslgit-r0
u-boot-qoriq-initial-env-ls1046ardb-tfa-secure-boot
u-boot-qoriq-initial-env-ls1046ardb-tfa-secure-boot-2022.04+AUTOINC+7376547b9e+fslgit-r0
u-boot-qoriq-initial-env-tfa
u-boot-qoriq-initial-env-tfa-secure-boot
u-boot-tfa-2022.04+AUTOINC+7376547b9e+fslgit-r0.bin
u-boot-tfa-secure-boot-2022.04+AUTOINC+7376547b9e+fslgit-r0.bin
uefi
Thanks for any idea,
rans
3,018件の閲覧回数
Oswalag
Please start the environment again and run the following command:
bitbake generate-boottgz
3,019件の閲覧回数
Oswalag
