dpaa2_net: FS table with 1 entries full
Chidananda22
hi creating 1 dpni and dpdmux.
on Port 0 creating 2 RXQ .
Adding rte_flow as below
memset(&udp_spec, 0, sizeof(udp_spec));
memset(&udp_mask, 0, sizeof(udp_mask));
udp_spec.hdr.dst_port = rte_cpu_to_be_16(udp_port);
udp_mask.hdr.dst_port = 0xffff;
pattern[0].type = RTE_FLOW_ITEM_TYPE_UDP;
pattern[0].spec = &udp_spec;
pattern[0].mask = &udp_mask;
pattern[1].type = RTE_FLOW_ITEM_TYPE_END;
action[0].type = RTE_FLOW_ACTION_TYPE_QUEUE;
action[0].conf = &queue;
action[1].type = RTE_FLOW_ACTION_TYPE_END;
struct rte_flow *flow =
rte_flow_create(port_id,
&attr,
pattern,
action,
&error);
Creating 2 flow on port 0 for RXQ 0 and RXQ 1
create_udp_queue_flow(port_id, 5000, 0);
create_udp_queue_flow(port_id, 5001, 1);
Getting below error.
Bio_TICFSL
The logs and restool output tell a clear story. The DPNI object was provisioned with only 1 fs_entry, which gets consumed by the first flow rule (UDP 5000 → RXQ 0). Any subsequent rte_flow_create() call fails immediately because the hardware FS table has no room left.
Port 0 started with 2 RX queues and 7 TX queues UDP port 5000 -> RXQ 0 created dpaa2_net: FS table with 1 entries full dpaa2_net: Failure to create flow, return code (-1) Flow create failed: unknown fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffebbc0 (2) affined thread - 8602 fslmc: dpaa2_configure_stashing(): Portal= 2 CPU= 1 SDEST= 0 fslmc: DPAA Portal=0x17ffebbc0 (2) is affined for eth rx to thread 8602root@localhost:/home/user# restool dpni info dpni.1 dpni version: 8.2 dpni id: 1 plugged state: plugged endpoint state: 0 endpoint: dpdmux.0.2, link is down link status: 0 - down mac address: ce:8a:4d:82:e7:dc max frame length: 1536 dpni_attr.options value is: 0x80000310 Unrecognized options found... num_queues: 16 num_cgs: 24 num_rx_tcs: 8 num_tx_tcs: 16 mac_entries: 16 vlan_entries: 16 qos_entries: 64 fs_entries: 1 qos_key_size: 56 fs_key_size: 56
10:53 AM
DPAA2 Flow Steering Table Full — Root Cause & Fix
Root Cause
Confirmed by restool:
fs_entries: 1    ← only 1 hardware flow-steering slot
The DPNI was created (either via DPL or restool dpni create) without explicitly setting fs-entries, so it defaulted to 1.
Fix — Recreate the DPNI with More FS Entries
Option 1 — Dynamically via restool (no reflash needed):
# Destroy the existing DPNI
restool dpni destroy dpni.1
# Recreate it with sufficient FS entries (e.g., 16 or 64)
restool dpni create \
  --options=DPNI_OPT_HAS_KEY_MASKING \
  --num-queues=16 \
  --fs-entries=64 \
  --num-rx-traffic-classes=8 \
  --num-tx-traffic-classes=16
# Re-bind to the DPDMUX endpoint
restool dpdmux connect dpdmux.0.2 --endpoint=dpni.X
Replace dpni.X with the newly created ID shown after dpni create.
Option 2 — Edit the DPL (Data Path Layout) file:
Find the dpni@1 object block in your DPL (.dts / .dpl) and increase fs_entries:
dpni@1 {
    compatible = "fsl,dpni";
    fs_entries = <64>;     /* was 1, increase as needed */
Then reload the DPL:
restool dprc load dprc.1 <your_updated.dpl>
 Your DPNI already has qos_entries: 64 and qos_key_size: 56, so the hardware supports it — only the provisioned FS table size was too small.
Quick Validation After Fix
# Confirm new fs_entries value
restool dpni info dpni.<new_id> | grep fs_entries
# Expected: fs_entries: 64  (or whatever you set)
Then retry your DPDK application — the Flow create failed error should be gone.
regards
Chidananda22
Resolved by adding below 2 lines in application  memset(&attr, 0, sizeof(attr));
attr.ingress = 1;
attr.group = 0;
attr.priority = pat;
pat++;
Chidananda22
./dpdk-multirxq-sample-prog  -l 1-3 -n 1 --log-level=fslmc,8 --huge-dir /dev/hugepages --proc-type=auto -b fslmc:dpio.16 -b fslmc:dpio.17 -b fslmc:dpio.18 -b fslmc:dpio.19 -b fslmc:dpio.20 -b fslmc:dpio.21 -b fslmc:dpio.22 -b fslmc:dpio.23 -b fslmc:dpmcp.38 -b fslmc:dpmcp.39
EAL: Detected 16 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Auto-detected process type: PRIMARY
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.16)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.17)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.18)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.19)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.20)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.21)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.22)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.23)
fslmc: rte_fslmc_parse(): Parsing dev=(dpmcp.38)
fslmc: rte_fslmc_parse(): Parsing dev=(dpmcp.39)
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
fslmc: fslmc_get_container_group(): Container: dprc.2 has VFIO iommu group id = 11
fslmc: **Devargs matched dpmcp.39
fslmc: **Devargs matched dpio.18
fslmc: **Devargs matched dpio.16
fslmc: Skipping invalid device (power)
fslmc: **Devargs matched dpio.22
fslmc: **Devargs matched dpio.20
fslmc: **Devargs matched dpio.19
fslmc: **Devargs matched dpmcp.38
fslmc: **Devargs matched dpio.17
fslmc: **Devargs matched dpio.23
fslmc: **Devargs matched dpio.21
fslmc: FSLMC Bus scan completed
fslmc: List of devices scanned on bus:
fslmc: dpni.1
fslmc: dpseci.1
fslmc: dpseci.2
fslmc: dpseci.3
fslmc: dpseci.4
fslmc: dpseci.5
fslmc: dpseci.6
fslmc: dpseci.7
fslmc: dpseci.8
fslmc: dpseci.9
fslmc: dpseci.10
fslmc: dpseci.11
fslmc: dpseci.12
fslmc: dpseci.13
fslmc: dpseci.14
fslmc: dpseci.15
fslmc: dpseci.16
fslmc: dpcon.32
fslmc: dpcon.33
fslmc: dpcon.34
fslmc: dpcon.35
fslmc: dpcon.36
fslmc: dpcon.37
fslmc: dpcon.38
fslmc: dpcon.39
fslmc: dpbp.2
fslmc: dpbp.3
fslmc: dpbp.4
fslmc: dpbp.5
fslmc: dpbp.6
fslmc: dpbp.7
fslmc: dpbp.8
fslmc: dpbp.9
fslmc: dpbp.10
fslmc: dpbp.11
fslmc: dpbp.12
fslmc: dpbp.13
fslmc: dpbp.14
fslmc: dpbp.15
fslmc: dpbp.16
fslmc: dpbp.17
fslmc: dpio.16
fslmc: dpio.17
fslmc: dpio.18
fslmc: dpio.19
fslmc: dpio.20
fslmc: dpio.21
fslmc: dpio.22
fslmc: dpio.23
fslmc: dpio.24
fslmc: dpio.25
fslmc: dpio.26
fslmc: dpio.27
fslmc: dpio.28
fslmc: dpio.29
fslmc: dpio.30
fslmc: dpio.31
fslmc: dpci.0
fslmc: dpci.1
fslmc: dpmcp.37
fslmc: dpmcp.38
fslmc: dpmcp.39
fslmc: dpdmai.0
fslmc: dpdmai.1
fslmc: dpdmai.2
fslmc: dpdmai.3
fslmc: dpdmai.4
fslmc: dpdmai.5
fslmc: dpdmai.6
fslmc: dpdmai.7
fslmc: dpdmux.0
fslmc: dprc.2
EAL: Selected IOVA mode 'VA'
EAL: No available hugepages reported in hugepages-2048kB
EAL: No available hugepages reported in hugepages-32768kB
EAL: No available hugepages reported in hugepages-64kB
EAL: Probing VFIO support...
EAL: VFIO support initialized
fslmc: fslmc_vfio_setup_group(): VFIO Container FD is [0x1B]
fslmc: fslmc_map_dma(): --> Map address: 0x140000000, size: 1073741824
fslmc: rte_fslmc_vfio_dmamap(): Installed memory callback handler
fslmc: rte_fslmc_vfio_dmamap(): Total 1 segments found.
fslmc: Unable to map region (errno = 22)
fslmc: dpmcp.38 Blacklisted, skipping
fslmc: dpmcp.39 Blacklisted, skipping
fslmc: Device (dprc.2) abstracted from VFIO
fslmc: Device (dpni.1) abstracted from VFIO
fslmc: Device (dpseci.1) abstracted from VFIO
fslmc: Device (dpseci.2) abstracted from VFIO
fslmc: Device (dpseci.3) abstracted from VFIO
fslmc: Device (dpseci.4) abstracted from VFIO
fslmc: Device (dpseci.5) abstracted from VFIO
fslmc: Device (dpseci.6) abstracted from VFIO
fslmc: Device (dpseci.7) abstracted from VFIO
fslmc: Device (dpseci.8) abstracted from VFIO
fslmc: Device (dpseci.9) abstracted from VFIO
fslmc: Device (dpseci.10) abstracted from VFIO
fslmc: Device (dpseci.11) abstracted from VFIO
fslmc: Device (dpseci.12) abstracted from VFIO
fslmc: Device (dpseci.13) abstracted from VFIO
fslmc: Device (dpseci.14) abstracted from VFIO
fslmc: Device (dpseci.15) abstracted from VFIO
fslmc: Device (dpseci.16) abstracted from VFIO
fslmc: Device (dpcon.32) abstracted from VFIO
fslmc: Device (dpcon.33) abstracted from VFIO
fslmc: Device (dpcon.34) abstracted from VFIO
fslmc: Device (dpcon.35) abstracted from VFIO
fslmc: Device (dpcon.36) abstracted from VFIO
fslmc: Device (dpcon.37) abstracted from VFIO
fslmc: Device (dpcon.38) abstracted from VFIO
fslmc: Device (dpcon.39) abstracted from VFIO
fslmc: Device (dpbp.2) abstracted from VFIO
fslmc: Device (dpbp.3) abstracted from VFIO
fslmc: Device (dpbp.4) abstracted from VFIO
fslmc: Device (dpbp.5) abstracted from VFIO
fslmc: Device (dpbp.6) abstracted from VFIO
fslmc: Device (dpbp.7) abstracted from VFIO
fslmc: Device (dpbp.8) abstracted from VFIO
fslmc: Device (dpbp.9) abstracted from VFIO
fslmc: Device (dpbp.10) abstracted from VFIO
fslmc: Device (dpbp.11) abstracted from VFIO
fslmc: Device (dpbp.12) abstracted from VFIO
fslmc: Device (dpbp.13) abstracted from VFIO
fslmc: Device (dpbp.14) abstracted from VFIO
fslmc: Device (dpbp.15) abstracted from VFIO
fslmc: Device (dpbp.16) abstracted from VFIO
fslmc: Device (dpbp.17) abstracted from VFIO
fslmc: dpio.16 Blacklisted, skipping
fslmc: dpio.17 Blacklisted, skipping
fslmc: dpio.18 Blacklisted, skipping
fslmc: dpio.19 Blacklisted, skipping
fslmc: dpio.20 Blacklisted, skipping
fslmc: dpio.21 Blacklisted, skipping
fslmc: dpio.22 Blacklisted, skipping
fslmc: dpio.23 Blacklisted, skipping
fslmc: dpaa2_create_dpio_device(): LX2160 Platform Detected
fslmc: Device (dpio.24) abstracted from VFIO
fslmc: Device (dpio.25) abstracted from VFIO
fslmc: Device (dpio.26) abstracted from VFIO
fslmc: Device (dpio.27) abstracted from VFIO
fslmc: Device (dpio.28) abstracted from VFIO
fslmc: Device (dpio.29) abstracted from VFIO
fslmc: Device (dpio.30) abstracted from VFIO
fslmc: Device (dpio.31) abstracted from VFIO
fslmc: Device (dpci.0) abstracted from VFIO
fslmc: Device (dpci.1) abstracted from VFIO
fslmc: Device (dpdmai.0) abstracted from VFIO
fslmc: Device (dpdmai.1) abstracted from VFIO
fslmc: Device (dpdmai.2) abstracted from VFIO
fslmc: Device (dpdmai.3) abstracted from VFIO
fslmc: Device (dpdmai.4) abstracted from VFIO
fslmc: Device (dpdmai.5) abstracted from VFIO
fslmc: Device (dpdmai.6) abstracted from VFIO
fslmc: Device (dpdmai.7) abstracted from VFIO
fslmc: Device (dpdmux.0) abstracted from VFIO
PMD: dpni.1: netdev created, connected to dpdmux.0
fslmc: dpaa2_get_qbman_swp(): New Portal 0x17fff3280 (1) affined thread - 8602
fslmc: dpaa2_configure_stashing(): Portal= 1 CPU= 1 SDEST= 0
fslmc: DPAA Portal=0x17fff3280 (1) is affined to thread 8602
Chidananda22
dpni version: 8.2
dpni id: 1
endpoint state: 0
num_queues: 16
num_cgs: 24
num_rx_tcs: 8
num_tx_tcs: 16
mac_entries: 16
vlan_entries: 16
qos_entries: 64
fs_entries: 1
qos_key_size: 56
fs_key_size: 56
Bio_TICFSL
10:53 AM
Root Cause
  --num-queues=16 \
  --fs-entries=64 \
dpni@1 {
regards
Chidananda22
Thanks resolved
Chidananda22
root@localhost:/home# restool dpni info dpni.2
dpni version: 8.4
dpni id: 2
endpoint state: 0
endpoint: dpmac.8, link is down
mac address: d0:63:b4:06:53:2a
num_queues: 16
num_cgs: 24
num_rx_tcs: 8
num_tx_tcs: 16
mac_entries: 16
vlan_entries: 16
qos_entries: 64
fs_entries: 12
qos_key_size: 56
fs_key_size: 56
num_channels: 1
num_opr: 0
ingress_all_frames: 0
ingress_all_bytes: 0
ingress_multicast_frames: 0
ingress_multicast_bytes: 0
ingress_broadcast_frames: 0
ingress_broadcast_bytes: 0
egress_all_frames: 0
still failing.
%3CLINGO-SUB%20id%3D%22lingo-sub-2403314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20creating%201%20dpni%20and%20dpdmux.%3C%2FP%3E%3CP%3Eon%20Port%200%20creating%202%20RXQ%20.%3C%2FP%3E%3CP%3EAdding%20rte_flow%20as%20below%26nbsp%3B%3C%2FP%3E%3CP%3Ememset(%26amp%3Budp_spec%2C%200%2C%20sizeof(udp_spec))%3B%3CBR%20%2F%3Ememset(%26amp%3Budp_mask%2C%200%2C%20sizeof(udp_mask))%3B%3C%2FP%3E%3CP%3Eudp_spec.hdr.dst_port%20%3D%20rte_cpu_to_be_16(udp_port)%3B%3CBR%20%2F%3Eudp_mask.hdr.dst_port%20%3D%200xffff%3B%3C%2FP%3E%3CP%3Epattern%5B0%5D.type%20%3D%20RTE_FLOW_ITEM_TYPE_UDP%3B%3CBR%20%2F%3Epattern%5B0%5D.spec%20%3D%20%26amp%3Budp_spec%3B%3CBR%20%2F%3Epattern%5B0%5D.mask%20%3D%20%26amp%3Budp_mask%3B%3C%2FP%3E%3CP%3Epattern%5B1%5D.type%20%3D%20RTE_FLOW_ITEM_TYPE_END%3B%3C%2FP%3E%3CP%3Eaction%5B0%5D.type%20%3D%20RTE_FLOW_ACTION_TYPE_QUEUE%3B%3CBR%20%2F%3Eaction%5B0%5D.conf%20%3D%20%26amp%3Bqueue%3B%3C%2FP%3E%3CP%3Eaction%5B1%5D.type%20%3D%20RTE_FLOW_ACTION_TYPE_END%3B%3C%2FP%3E%3CP%3Estruct%20rte_flow%20*flow%20%3D%3CBR%20%2F%3Erte_flow_create(port_id%2C%3CBR%20%2F%3E%26amp%3Battr%2C%3CBR%20%2F%3Epattern%2C%3CBR%20%2F%3Eaction%2C%3CBR%20%2F%3E%26amp%3Berror)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECreating%202%20flow%20on%20port%200%20for%20RXQ%200%20and%20RXQ%201%26nbsp%3B%3C%2FP%3E%3CP%3Ecreate_udp_queue_flow(port_id%2C%205000%2C%200)%3B%3CBR%20%2F%3Ecreate_udp_queue_flow(port_id%2C%205001%2C%201)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EGetting%20below%20error.%3C%2FP%3E%3CP%3Edpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20logs%20and%20%3CCODE%20class%3D%22p8i6j0f%22%3Erestool%3C%2FCODE%3E%20output%20tell%20a%20clear%20story.%20The%20DPNI%20object%20was%20provisioned%20with%20only%20%3CSTRONG%3E1%20%3CCODE%20class%3D%22p8i6j0f%22%3Efs_entry%3C%2FCODE%3E%3C%2FSTRONG%3E%2C%20which%20gets%20consumed%20by%20the%20first%20flow%20rule%20(%3CCODE%20class%3D%22p8i6j0f%22%3EUDP%205000%20%E2%86%92%20RXQ%200%3C%2FCODE%3E).%20Any%20subsequent%20%3CCODE%20class%3D%22p8i6j0f%22%3Erte_flow_create()%3C%2FCODE%3E%20call%20fails%20immediately%20because%20the%20hardware%20FS%20table%20has%20no%20room%20left.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20style%3D%22height%3A%20100%25%3B%20position%3A%20absolute%3B%20top%3A%200px%3B%20width%3A%20100%25%3B%22%20data-viewport-type%3D%22window%22%3E%0A%3CDIV%20style%3D%22box-sizing%3A%20border-box%3B%20margin-top%3A%200px%3B%20padding-bottom%3A%200px%3B%20padding-top%3A%200px%3B%22%20data-testid%3D%22virtuoso-item-list%22%3E%0A%3CDIV%20style%3D%22overflow-anchor%3A%20none%3B%22%20data-known-size%3D%223271%22%20data-item-index%3D%220%22%20data-index%3D%220%22%3E%0A%3CDIV%20class%3D%22pwfflu1%22%20style%3D%22--pwfflu0%3A%200px%3B%22%3E%0A%3CDIV%20class%3D%22wgjulht%20_1ibi0s312%20_1ibi0s31i%20_1ibi0s31y%20wgjulhx%22%20style%3D%22--_1yc2r981%3A%201576.3499755859375px%3B%22%20data-workflow-run-id%3D%22d217374e00424f468f1f4465ba7f3694%22%3E%0A%3CDIV%20class%3D%22_4xkvb01%20_1qnjdah7%20focusable-list-item%20_1qnjdahi%20_1ibi0s31i%22%20style%3D%22--_4xkvb00%3A%208px%3B%22%20tabindex%3D%220%22%20data-ui-element%3D%22chat-user-bubble%22%3E%0A%3CDIV%20class%3D%22_1qnjdah8%20_1qnjdah3%20_1ibi0s312%20_1ibi0s31g%20_1ibi0s31y%20_1ibi0s32s%22%3E%0A%3CDIV%20class%3D%22_1qnjdahb%22%3E%0A%3CDIV%20class%3D%22_1qnjdah9%20_1ibi0s3eg%22%20style%3D%22scroll-margin-top%3A%20-601.35px%3B%22%20tabindex%3D%220%22%20role%3D%22button%22%3E%0A%3CDIV%20class%3D%22_1ibi0s312%20_1ibi0s3ei%20_1ibi0s31i%20_1ibi0s376%22%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EPort%200%20started%20with%202%20RX%20queues%20and%207%20TX%20queues%20UDP%20port%205000%20-%26gt%3B%20RXQ%200%20created%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%20dpaa2_net%3A%20Failure%20to%20create%20flow%2C%20return%20code%20(-1)%20Flow%20create%20failed%3A%20unknown%20fslmc%3A%20dpaa2_get_qbman_swp()%3A%20New%20Portal%200x17ffebbc0%20(2)%20affined%20thread%20-%208602%20fslmc%3A%20dpaa2_configure_stashing()%3A%20Portal%3D%202%20CPU%3D%201%20SDEST%3D%200%20fslmc%3A%20DPAA%20Portal%3D0x17ffebbc0%20(2)%20is%20affined%20for%20eth%20rx%20to%20thread%208602root%40localhost%3A%2Fhome%2Fuser%23%20restool%20dpni%20info%20dpni.1%20dpni%20version%3A%208.2%20dpni%20id%3A%201%20plugged%20state%3A%20plugged%20endpoint%20state%3A%200%20endpoint%3A%20dpdmux.0.2%2C%20link%20is%20down%20link%20status%3A%200%20-%20down%20mac%20address%3A%20ce%3A8a%3A4d%3A82%3Ae7%3Adc%20max%20frame%20length%3A%201536%20dpni_attr.options%20value%20is%3A%200x80000310%20Unrecognized%20options%20found...%20num_queues%3A%2016%20num_cgs%3A%2024%20num_rx_tcs%3A%208%20num_tx_tcs%3A%2016%20mac_entries%3A%2016%20vlan_entries%3A%2016%20qos_entries%3A%2064%20fs_entries%3A%201%20qos_key_size%3A%2056%20fs_key_size%3A%2056%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22_1qnjdaho%20_1qnjdahp%22%3E%3CSPAN%20class%3D%22_1ibi0s3eb%22%3E10%3A53%20AM%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22_4xkvb01%20_1ibi0s31g%20_1ibi0s376%22%20style%3D%22--_4xkvb00%3A%204px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22_1ibi0s312%20_1ibi0s31i%20_1ibi0s31y%22%3E%0A%3CDIV%20class%3D%22_1ibi0s3en%20_1ibi0s3ce%20focusable-list-item%20pb1qj28%20_1ibi0s34s%20_1ibi0s33w%22%20data-ui-element%3D%22chat-intermediate-steps%22%3E%0A%3CDIV%20class%3D%22_4xkvb01%20_1ibi0s31i%22%20style%3D%22--_4xkvb00%3A%2012px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22_1bdmgj40%20_1ibi0s312%20_1ibi0s31i%20_1llyo9u0%20focusable-list-item%22%20tabindex%3D%220%22%20data-ui-element%3D%22chat-assistant-content-bubble%22%3E%0A%3CDIV%20class%3D%22_1ibi0s312%20_1ibi0s31i%20_1ibi0s31y%22%3E%0A%3CDIV%3E%0A%3CDIV%20class%3D%22_1ibi0s3en%22%3E%0A%3CH2%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading2%20_9k2iva1%22%20id%3D%22toc-hId--442982026%22%20id%3D%22toc-hId--442979983%22%20id%3D%22toc-hId--442979983%22%20id%3D%22toc-hId--442979983%22%3EDPAA2%20Flow%20Steering%20Table%20Full%20%E2%80%94%20Root%20Cause%20%26amp%3B%20Fix%3C%2FH2%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThe%20logs%20and%20%3CCODE%20class%3D%22p8i6j0f%22%3Erestool%3C%2FCODE%3E%20output%20tell%20a%20clear%20story.%20The%20DPNI%20object%20was%20provisioned%20with%20only%20%3CSTRONG%3E1%20%3CCODE%20class%3D%22p8i6j0f%22%3Efs_entry%3C%2FCODE%3E%3C%2FSTRONG%3E%2C%20which%20gets%20consumed%20by%20the%20first%20flow%20rule%20(%3CCODE%20class%3D%22p8i6j0f%22%3EUDP%205000%20%E2%86%92%20RXQ%200%3C%2FCODE%3E).%20Any%20subsequent%20%3CCODE%20class%3D%22p8i6j0f%22%3Erte_flow_create()%3C%2FCODE%3E%20call%20fails%20immediately%20because%20the%20hardware%20FS%20table%20has%20no%20room%20left.%3C%2FP%3E%0A%3CH3%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading3%20_9k2iva1%22%20id%3D%22toc-hId-247579448%22%20id%3D%22toc-hId-247581491%22%20id%3D%22toc-hId-247581491%22%20id%3D%22toc-hId-247581491%22%3ERoot%20Cause%3C%2FH3%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22p8i6j0e%20hljs%20language-sql%20_12n1b832%22%3Edpaa2_net%3A%20FS%20%3CSPAN%20class%3D%22hljs-keyword%22%3Etable%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hljs-keyword%22%3Ewith%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hljs-number%22%3E1%3C%2FSPAN%3E%20entries%20%3CSPAN%20class%3D%22hljs-keyword%22%3Efull%3C%2FSPAN%3E%0Adpaa2_net%3A%20Failure%20%3CSPAN%20class%3D%22hljs-keyword%22%3Eto%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22hljs-keyword%22%3Ecreate%3C%2FSPAN%3E%20flow%2C%20%3CSPAN%20class%3D%22hljs-keyword%22%3Ereturn%3C%2FSPAN%3E%20code%20(%3CSPAN%20class%3D%22hljs-number%22%3E-1%3C%2FSPAN%3E)%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22l8rrz25%20_1ibi0s3eb%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EConfirmed%20by%20%3CCODE%20class%3D%22p8i6j0f%22%3Erestool%3C%2FCODE%3E%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22p8i6j0e%20hljs%20language-makefile%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-section%22%3Efs_entries%3A%201%20%20%20%20%E2%86%90%20only%201%20hardware%20flow-steering%20slot%3C%2FSPAN%3E%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22l8rrz25%20_1ibi0s3eb%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThe%20DPNI%20was%20created%20(either%20via%20DPL%20or%20%3CCODE%20class%3D%22p8i6j0f%22%3Erestool%20dpni%20create%3C%2FCODE%3E)%20without%20explicitly%20setting%20%3CCODE%20class%3D%22p8i6j0f%22%3Efs-entries%3C%2FCODE%3E%2C%20so%20it%20defaulted%20to%20%3CSTRONG%3E1%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CH3%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading3%20_9k2iva1%22%20id%3D%22toc-hId--1559875015%22%20id%3D%22toc-hId--1559872972%22%20id%3D%22toc-hId--1559872972%22%20id%3D%22toc-hId--1559872972%22%3EFix%20%E2%80%94%20Recreate%20the%20DPNI%20with%20More%20FS%20Entries%3C%2FH3%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%3CSTRONG%3EOption%201%20%E2%80%94%20Dynamically%20via%20%3CCODE%20class%3D%22p8i6j0f%22%3Erestool%3C%2FCODE%3E%20(no%20reflash%20needed)%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Destroy%20the%20existing%20DPNI%3C%2FSPAN%3E%0Arestool%20dpni%20destroy%20dpni.1%0A%0A%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Recreate%20it%20with%20sufficient%20FS%20entries%20(e.g.%2C%2016%20or%2064)%3C%2FSPAN%3E%0Arestool%20dpni%20create%20%5C%0A%20%20--options%3DDPNI_OPT_HAS_KEY_MASKING%20%5C%0A%20%20--num-queues%3D16%20%5C%0A%20%20--fs-entries%3D64%20%5C%0A%20%20--num-rx-traffic-classes%3D8%20%5C%0A%20%20--num-tx-traffic-classes%3D16%0A%0A%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Re-bind%20to%20the%20DPDMUX%20endpoint%3C%2FSPAN%3E%0Arestool%20dpdmux%20connect%20dpdmux.0.2%20--endpoint%3Ddpni.X%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CBLOCKQUOTE%20class%3D%22p8i6j03%22%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EReplace%20%3CCODE%20class%3D%22p8i6j0f%22%3Edpni.X%3C%2FCODE%3E%20with%20the%20newly%20created%20ID%20shown%20after%20%3CCODE%20class%3D%22p8i6j0f%22%3Edpni%20create%3C%2FCODE%3E.%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%3CSTRONG%3EOption%202%20%E2%80%94%20Edit%20the%20DPL%20(Data%20Path%20Layout)%20file%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EFind%20the%20%3CCODE%20class%3D%22p8i6j0f%22%3Edpni%401%3C%2FCODE%3E%20object%20block%20in%20your%20DPL%20(%3CCODE%20class%3D%22p8i6j0f%22%3E.dts%3C%2FCODE%3E%20%2F%20%3CCODE%20class%3D%22p8i6j0f%22%3E.dpl%3C%2FCODE%3E)%20and%20increase%20%3CCODE%20class%3D%22p8i6j0f%22%3Efs_entries%3C%2FCODE%3E%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-dts%20p8i6j0e%20hljs%20language-dts%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-symbol%22%3Edpni%40%3C%2FSPAN%3E%3CSPAN%20class%3D%22hljs-number%22%3E1%3C%2FSPAN%3E%20%7B%0A%20%20%20%20compatible%20%3D%20%3CSPAN%20class%3D%22hljs-string%22%3E%22fsl%2Cdpni%22%3C%2FSPAN%3E%3B%0A%20%20%20%20...%0A%20%20%20%20fs_entries%20%3D%20%26lt%3B%3CSPAN%20class%3D%22hljs-number%22%3E64%3C%2FSPAN%3E%26gt%3B%3B%20%20%20%20%20%3CSPAN%20class%3D%22hljs-comment%22%3E%2F*%20was%201%2C%20increase%20as%20needed%20*%2F%3C%2FSPAN%3E%0A%20%20%20%20...%0A%7D%3B%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThen%20reload%20the%20DPL%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3Erestool%20dprc%20load%20dprc.1%20%3CYOUR_UPDATED.DPL%3E%3C%2FYOUR_UPDATED.DPL%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3BYour%20DPNI%20already%20has%20%3CCODE%20class%3D%22p8i6j0f%22%3Eqos_entries%3A%2064%3C%2FCODE%3E%20and%20%3CCODE%20class%3D%22p8i6j0f%22%3Eqos_key_size%3A%2056%3C%2FCODE%3E%2C%20so%20the%20hardware%20supports%20it%20%E2%80%94%20only%20the%20provisioned%20FS%20table%20size%20was%20too%20small.%3C%2FP%3E%0A%3CH3%20class%3D%22_9k2iva0%20p8i6j0c%20_1ibi0s314%20heading3%20_9k2iva1%22%20id%3D%22toc-hId-927637818%22%20id%3D%22toc-hId-927639861%22%20id%3D%22toc-hId-927639861%22%20id%3D%22toc-hId-927639861%22%3EQuick%20Validation%20After%20Fix%3C%2FH3%3E%0A%3CDIV%20class%3D%22l8rrz21%20_1ibi0s3en%22%20data-ui-element%3D%22code-block-container%22%3E%0A%3CPRE%3E%3CCODE%20class%3D%22markdown-code-bash%20p8i6j0e%20hljs%20language-bash%20_12n1b832%22%3E%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Confirm%20new%20fs_entries%20value%3C%2FSPAN%3E%0Arestool%20dpni%20info%20dpni.%3CNEW_ID%3E%20%7C%20grep%20fs_entries%0A%0A%3CSPAN%20class%3D%22hljs-comment%22%3E%23%20Expected%3A%20fs_entries%3A%2064%20%20(or%20whatever%20you%20set)%3C%2FSPAN%3E%0A%3C%2FNEW_ID%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CDIV%20class%3D%22l8rrz23%20_1ibi0s3dp%20_1ibi0s332%20_1ibi0s3eo%20_1ibi0s3bm%20_1ibi0s3ce%22%3E%0A%3CDIV%20class%3D%22lqznwq0%22%20style%3D%22mask-image%3A%20url('%2Fimages%2Fcopy.svg')%3B%20vertical-align%3A%20text-bottom%3B%20height%3A%2014px%3B%20min-width%3A%2014px%3B%20width%3A%2014px%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EThen%20retry%20your%20DPDK%20application%20%E2%80%94%20the%20%3CCODE%20class%3D%22p8i6j0f%22%3EFlow%20create%20failed%3C%2FCODE%3E%20error%20should%20be%20gone.%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3Eregards%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eroot%40localhost%3A%2Fhome%2Fuser%23%20restool%20dpni%20info%20dpni.1%3CBR%20%2F%3Edpni%20version%3A%208.2%3CBR%20%2F%3Edpni%20id%3A%201%3CBR%20%2F%3Eplugged%20state%3A%20plugged%3CBR%20%2F%3Eendpoint%20state%3A%200%3CBR%20%2F%3Eendpoint%3A%20dpdmux.0.2%2C%20link%20is%20down%3CBR%20%2F%3Elink%20status%3A%200%20-%20down%3CBR%20%2F%3Emac%20address%3A%20ce%3A8a%3A4d%3A82%3Ae7%3Adc%3CBR%20%2F%3Emax%20frame%20length%3A%201536%3CBR%20%2F%3Edpni_attr.options%20value%20is%3A%200x80000310%3CBR%20%2F%3EUnrecognized%20options%20found...%3CBR%20%2F%3Enum_queues%3A%2016%3CBR%20%2F%3Enum_cgs%3A%2024%3CBR%20%2F%3Enum_rx_tcs%3A%208%3CBR%20%2F%3Enum_tx_tcs%3A%2016%3CBR%20%2F%3Emac_entries%3A%2016%3CBR%20%2F%3Evlan_entries%3A%2016%3CBR%20%2F%3Eqos_entries%3A%2064%3CBR%20%2F%3Efs_entries%3A%201%3CBR%20%2F%3Eqos_key_size%3A%2056%3CBR%20%2F%3Efs_key_size%3A%2056%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2403315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2403315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E.%2Fdpdk-multirxq-sample-prog%26nbsp%3B%20-l%201-3%20-n%201%20--log-level%3Dfslmc%2C8%20--huge-dir%20%2Fdev%2Fhugepages%20--proc-type%3Dauto%20-b%20fslmc%3Adpio.16%20-b%20fslmc%3Adpio.17%20-b%20fslmc%3Adpio.18%20-b%20fslmc%3Adpio.19%20-b%20fslmc%3Adpio.20%20-b%20fslmc%3Adpio.21%20-b%20fslmc%3Adpio.22%20-b%20fslmc%3Adpio.23%20-b%20fslmc%3Adpmcp.38%20-b%20fslmc%3Adpmcp.39%3CBR%20%2F%3EEAL%3A%20Detected%2016%20lcore(s)%3CBR%20%2F%3EEAL%3A%20Detected%201%20NUMA%20nodes%3CBR%20%2F%3EEAL%3A%20Auto-detected%20process%20type%3A%20PRIMARY%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3EEAL%3A%20Multi-process%20socket%20%2Fvar%2Frun%2Fdpdk%2Frte%2Fmp_socket%3CBR%20%2F%3Efslmc%3A%20fslmc_get_container_group()%3A%20Container%3A%20dprc.2%20has%20VFIO%20iommu%20group%20id%20%3D%2011%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpmcp.39%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.18%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.16%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20Skipping%20invalid%20device%20(power)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.22%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.20%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.19%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpmcp.38%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.17%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.23%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20**Devargs%20matched%20dpio.21%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.16)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.17)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.18)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.19)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.20)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.21)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.22)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpio.23)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.38)%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_parse()%3A%20Parsing%20dev%3D(dpmcp.39)%3CBR%20%2F%3Efslmc%3A%20FSLMC%20Bus%20scan%20completed%3CBR%20%2F%3Efslmc%3A%20List%20of%20devices%20scanned%20on%20bus%3A%3CBR%20%2F%3Efslmc%3A%20dpni.1%3CBR%20%2F%3Efslmc%3A%20dpseci.1%3CBR%20%2F%3Efslmc%3A%20dpseci.2%3CBR%20%2F%3Efslmc%3A%20dpseci.3%3CBR%20%2F%3Efslmc%3A%20dpseci.4%3CBR%20%2F%3Efslmc%3A%20dpseci.5%3CBR%20%2F%3Efslmc%3A%20dpseci.6%3CBR%20%2F%3Efslmc%3A%20dpseci.7%3CBR%20%2F%3Efslmc%3A%20dpseci.8%3CBR%20%2F%3Efslmc%3A%20dpseci.9%3CBR%20%2F%3Efslmc%3A%20dpseci.10%3CBR%20%2F%3Efslmc%3A%20dpseci.11%3CBR%20%2F%3Efslmc%3A%20dpseci.12%3CBR%20%2F%3Efslmc%3A%20dpseci.13%3CBR%20%2F%3Efslmc%3A%20dpseci.14%3CBR%20%2F%3Efslmc%3A%20dpseci.15%3CBR%20%2F%3Efslmc%3A%20dpseci.16%3CBR%20%2F%3Efslmc%3A%20dpcon.32%3CBR%20%2F%3Efslmc%3A%20dpcon.33%3CBR%20%2F%3Efslmc%3A%20dpcon.34%3CBR%20%2F%3Efslmc%3A%20dpcon.35%3CBR%20%2F%3Efslmc%3A%20dpcon.36%3CBR%20%2F%3Efslmc%3A%20dpcon.37%3CBR%20%2F%3Efslmc%3A%20dpcon.38%3CBR%20%2F%3Efslmc%3A%20dpcon.39%3CBR%20%2F%3Efslmc%3A%20dpbp.2%3CBR%20%2F%3Efslmc%3A%20dpbp.3%3CBR%20%2F%3Efslmc%3A%20dpbp.4%3CBR%20%2F%3Efslmc%3A%20dpbp.5%3CBR%20%2F%3Efslmc%3A%20dpbp.6%3CBR%20%2F%3Efslmc%3A%20dpbp.7%3CBR%20%2F%3Efslmc%3A%20dpbp.8%3CBR%20%2F%3Efslmc%3A%20dpbp.9%3CBR%20%2F%3Efslmc%3A%20dpbp.10%3CBR%20%2F%3Efslmc%3A%20dpbp.11%3CBR%20%2F%3Efslmc%3A%20dpbp.12%3CBR%20%2F%3Efslmc%3A%20dpbp.13%3CBR%20%2F%3Efslmc%3A%20dpbp.14%3CBR%20%2F%3Efslmc%3A%20dpbp.15%3CBR%20%2F%3Efslmc%3A%20dpbp.16%3CBR%20%2F%3Efslmc%3A%20dpbp.17%3CBR%20%2F%3Efslmc%3A%20dpio.16%3CBR%20%2F%3Efslmc%3A%20dpio.17%3CBR%20%2F%3Efslmc%3A%20dpio.18%3CBR%20%2F%3Efslmc%3A%20dpio.19%3CBR%20%2F%3Efslmc%3A%20dpio.20%3CBR%20%2F%3Efslmc%3A%20dpio.21%3CBR%20%2F%3Efslmc%3A%20dpio.22%3CBR%20%2F%3Efslmc%3A%20dpio.23%3CBR%20%2F%3Efslmc%3A%20dpio.24%3CBR%20%2F%3Efslmc%3A%20dpio.25%3CBR%20%2F%3Efslmc%3A%20dpio.26%3CBR%20%2F%3Efslmc%3A%20dpio.27%3CBR%20%2F%3Efslmc%3A%20dpio.28%3CBR%20%2F%3Efslmc%3A%20dpio.29%3CBR%20%2F%3Efslmc%3A%20dpio.30%3CBR%20%2F%3Efslmc%3A%20dpio.31%3CBR%20%2F%3Efslmc%3A%20dpci.0%3CBR%20%2F%3Efslmc%3A%20dpci.1%3CBR%20%2F%3Efslmc%3A%20dpmcp.37%3CBR%20%2F%3Efslmc%3A%20dpmcp.38%3CBR%20%2F%3Efslmc%3A%20dpmcp.39%3CBR%20%2F%3Efslmc%3A%20dpdmai.0%3CBR%20%2F%3Efslmc%3A%20dpdmai.1%3CBR%20%2F%3Efslmc%3A%20dpdmai.2%3CBR%20%2F%3Efslmc%3A%20dpdmai.3%3CBR%20%2F%3Efslmc%3A%20dpdmai.4%3CBR%20%2F%3Efslmc%3A%20dpdmai.5%3CBR%20%2F%3Efslmc%3A%20dpdmai.6%3CBR%20%2F%3Efslmc%3A%20dpdmai.7%3CBR%20%2F%3Efslmc%3A%20dpdmux.0%3CBR%20%2F%3Efslmc%3A%20dprc.2%3CBR%20%2F%3EEAL%3A%20Selected%20IOVA%20mode%20'VA'%3CBR%20%2F%3EEAL%3A%20No%20available%20hugepages%20reported%20in%20hugepages-2048kB%3CBR%20%2F%3EEAL%3A%20No%20available%20hugepages%20reported%20in%20hugepages-32768kB%3CBR%20%2F%3EEAL%3A%20No%20available%20hugepages%20reported%20in%20hugepages-64kB%3CBR%20%2F%3EEAL%3A%20Probing%20VFIO%20support...%3CBR%20%2F%3EEAL%3A%20VFIO%20support%20initialized%3CBR%20%2F%3Efslmc%3A%20fslmc_get_container_group()%3A%20Container%3A%20dprc.2%20has%20VFIO%20iommu%20group%20id%20%3D%2011%3CBR%20%2F%3Efslmc%3A%20fslmc_vfio_setup_group()%3A%20VFIO%20Container%20FD%20is%20%5B0x1B%5D%3CBR%20%2F%3Efslmc%3A%20fslmc_map_dma()%3A%20--%26gt%3B%20Map%20address%3A%200x140000000%2C%20size%3A%201073741824%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20Installed%20memory%20callback%20handler%3CBR%20%2F%3Efslmc%3A%20rte_fslmc_vfio_dmamap()%3A%20Total%201%20segments%20found.%3CBR%20%2F%3Efslmc%3A%20Unable%20to%20map%20region%20(errno%20%3D%2022)%3CBR%20%2F%3Efslmc%3A%20dpmcp.38%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpmcp.39%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20Device%20(dprc.2)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpni.1)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.1)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.2)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.3)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.4)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.5)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.6)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.7)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.8)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.9)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.10)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.11)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.12)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.13)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.14)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.15)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpseci.16)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.32)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.33)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.34)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.35)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.36)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.37)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.38)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpcon.39)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.2)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.3)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.4)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.5)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.6)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.7)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.8)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.9)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.10)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.11)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.12)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.13)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.14)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.15)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.16)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpbp.17)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20dpio.16%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.17%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.18%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.19%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.20%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.21%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.22%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpio.23%20Blacklisted%2C%20skipping%3CBR%20%2F%3Efslmc%3A%20dpaa2_create_dpio_device()%3A%20LX2160%20Platform%20Detected%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.24)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.25)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.26)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.27)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.28)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.29)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.30)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpio.31)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpci.0)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpci.1)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.0)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.1)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.2)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.3)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.4)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.5)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.6)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmai.7)%20abstracted%20from%20VFIO%3CBR%20%2F%3Efslmc%3A%20Device%20(dpdmux.0)%20abstracted%20from%20VFIO%3CBR%20%2F%3EPMD%3A%20dpni.1%3A%20netdev%20created%2C%20connected%20to%20dpdmux.0%3CBR%20%2F%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20New%20Portal%200x17fff3280%20(1)%20affined%20thread%20-%208602%3CBR%20%2F%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20Portal%3D%201%20CPU%3D%201%20SDEST%3D%200%3CBR%20%2F%3Efslmc%3A%20DPAA%20Portal%3D0x17fff3280%20(1)%20is%20affined%20to%20thread%208602%3CBR%20%2F%3E%3CSTRONG%3EPort%200%20started%20with%202%20RX%20queues%20and%207%20TX%20queues%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EUDP%20port%205000%20-%26gt%3B%20RXQ%200%20created%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Edpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Edpaa2_net%3A%20Failure%20to%20create%20flow%2C%20return%20code%20(-1)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EFlow%20create%20failed%3A%20unknown%3C%2FSTRONG%3E%3CBR%20%2F%3Efslmc%3A%20dpaa2_get_qbman_swp()%3A%20New%20Portal%200x17ffebbc0%20(2)%20affined%20thread%20-%208602%3CBR%20%2F%3Efslmc%3A%20dpaa2_configure_stashing()%3A%20Portal%3D%202%20CPU%3D%201%20SDEST%3D%200%3CBR%20%2F%3Efslmc%3A%20DPAA%20Portal%3D0x17ffebbc0%20(2)%20is%20affined%20for%20eth%20rx%20to%20thread%208602%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20resolved%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpaa2_net%3A%20FS%20table%20with%201%20entries%20full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EResolved%20by%20adding%20below%202%20lines%20in%20application%26nbsp%3B%20memset(%26amp%3Battr%2C%200%2C%20sizeof(attr))%3B%3CBR%20%2F%3Eattr.ingress%20%3D%201%3B%3CBR%20%2F%3Eattr.group%20%3D%200%3B%3CBR%20%2F%3Eattr.priority%20%3D%20pat%3B%3CBR%20%2F%3Epat%2B%2B%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
