dmesg report dpaa2 error:dpaa2_ethsw dpsw.0 eth2: dpsw_if_enable err -110
nxppenpals
We have a custom board with LS2160 CPU on it.
Operating System: NXP LSDK 2004 main
Kernel: 4.19.90
restool -v
restool v2.4 (10.30.0 compatible)
restool -m
MC firmware version: 10.36.0
ls-listmac
dprc.1/dpmac.17 (end point: dpni.1)
dprc.1/dpmac.16 (end point: dpni.0)
dprc.1/dpmac.15
dprc.1/dpmac.14
dprc.1/dpmac.13 (end point: dpsw.0.0)
dprc.1/dpmac.10 (end point: dpsw.0.1)
dprc.1/dpmac.9
dprc.1/dpmac.8
dprc.1/dpmac.7 (end point: dpni.5)
dprc.1/dpmac.5
dprc.1/dpmac.4 (end point: dpni.4)
dprc.1/dpmac.3 (end point: dpni.3)
when i reboot , dmesg report the bellow errors:
kern :err : [ 58.697829] dpaa2_ethsw dpsw.0 eth2: dpsw_if_enable err -110
kern :err : [ 59.317064] dpaa2_ethsw dpsw.0 eth3: dpsw_if_disable err -13
kern :err : [ 60.645011] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 61.940214] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 63.257294] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 64.581578] dpaa2_ethsw dpsw.0 eth2: dpsw_if_get_counter err -13
kern :err : [ 65.892006] dpaa2_ethsw dpsw.0 eth3: ERROR -13 getting link state
kern :err : [ 67.204366] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 68.512720] dpaa2_ethsw dpsw.0 eth3: dpsw_if_set_flooding err -13
kern :err : [ 69.817939] dpaa2_ethsw dpsw.0 eth2: dpsw_if_get_counter err -13
kern :err : [ 71.134669] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 72.454158] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 73.763729] dpaa2_ethsw dpsw.0 eth3: dpsw_if_set_stp err -13
kern :err : [ 73.782777] dpaa2_ethsw dpsw.0 eth3: failed (err=-13) to set attribute (id=2)
kern :err : [ 75.261048] dpaa2_ethsw dpsw.0 eth3: dpsw_if_set_stp err -13
kern :err : [ 75.280977] dpaa2_ethsw dpsw.0 eth3: failed (err=-13) to set attribute (id=2)
kern :err : [ 76.378948] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 77.691796] dpaa2_ethsw dpsw.0 eth3: dpsw_if_enable err -13
kern :err : [ 79.004096] dpaa2_ethsw dpsw.0 eth4: dpsw_if_disable err -13
kern :err : [ 80.330763] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 81.691072] dpaa2_ethsw dpsw.0 eth2: dpsw_if_get_counter err -13
kern :err : [ 82.942474] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 84.264398] dpaa2_ethsw dpsw.0 eth2: dpsw_if_get_counter err -13
kern :err : [ 85.573405] dpaa2_ethsw dpsw.0 eth3: dpsw_if_get_counter err -13
kern :err : [ 86.885892] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 88.192516] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 89.519345] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 90.832203] dpaa2_ethsw dpsw.0 eth4: ERROR -13 getting link state
kern :err : [ 92.144110] dpaa2_ethsw dpsw.0 eth4: dpsw_if_get_counter err -13
kern :err : [ 93.452586] dpaa2_ethsw dpsw.0 eth4: dpsw_if_set_flooding err -13
kern :err : [ 94.767646] dpaa2_ethsw dpsw.0 eth4: dpsw_if_set_stp err -13
kern :err : [ 94.788954] dpaa2_ethsw dpsw.0 eth4: failed (err=-13) to set attribute (id=2)
kern :err : [ 96.083822] dpaa2_ethsw dpsw.0 eth4: dpsw_if_set_stp err -13
kern :err : [ 96.103686] dpaa2_ethsw dpsw.0 eth4: failed (err=-13) to set attribute (id=2)
kern :err : [ 97.396519] dpaa2_ethsw dpsw.0 eth4: dpsw_if_enable err -13
kern :err : [ 112.575458] vfio-fsl-mc dprc.2: fsl_mc_driver_probe failed: -110
 cat /dev/fsl_mc_console
[30150.460085] fsl-ls2-console: MC base address at 0x00000027e0000000
, qbman_swp_mc_complete:107, QBMAN] SWP 0 management command failed to complete
[E, qbman_fq_query_state:1256, QBMAN] SWP 0 is not responding
[E, dpmng_dump_rerr_fqid:1328, QBMAN] Fail to get REL_FQ (FQ[0]) state
[E, qbman_rec_isr:391, QBMAN] QBMAN recoverable event 0x2000000
[E, qbman_swp_mc_complete:107, QBMAN] SWP 0 management command failed to complete
[E, mc_portal_isr:994, RESMAN] portal 34 is serving previous command!
Is there any way to solve the problem?
Thanks for advice from experienced experts.
yipingwang
Please download LSDK 21.08 pre-built image
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/lsdk2108_yocto_tiny_LS_arm64.itb
Then boot Linux Kernel with the following command.
=>tftp 0xa0000000 lsdk2108_yocto_tiny_LS_arm64.itb
=>bootm 0xa0000000#lx2160ardb
Then check whether this problem still exist.
Please apply your DPL file before booting Linux Kernel.
