LX2160 : I am getting below error while running my application.
After reboot works fine . Next time same error again. This problem seen if i configure as below
#export DPIO_COUNT=20
set -x
#export DPIO_COUNT=10
ls-listni #to check if 40G is enabled or not
#Remove 40G port if it is enabled (40G=dpmac.2)
echo dpni.1 > /sys/bus/fsl-mc/drivers/fsl_dpaa2_eth/unbind
restool dpni destroy dpni.1
echo 0 > /proc/sys/kernel/randomize_va_space
export DPMCP_COUNT=3
export FS_ENTRIES=12
#/usr/local/dpdk/dpaa2/dynamic_dpl.sh dpmac.3
/usr/local/dpdk/dpaa2/dynamic_dpl.sh dpni dpni -b 00:00:00:00:05:00
# dpni.1 00:00:00:00:05:01
# dpni.2 00:00:00:00:05:02
ls-addni --no-link
#eth0 dpni.3
ls-addni --no-link
#eth2 dpni.4
#/////OUTPUT/////////
# Unbinding dprc.2 from VFIO
echo dprc.2 > /sys/bus/fsl-mc/drivers/vfio-fsl-mc/unbind
#dpn.2 is the output of dynamicdpl.sh
#dpni.1 dpmac.4 -Dynamic-
#restool dprc disconnect dprc.2 --endpoint=dpni.1
restool dpdmux create --num-ifs=3 --method DPDMUX_METHOD_MAC --max-dmat-entries=3 --manip=DPDMUX_MANIP_NONE
restool dprc connect dprc.1 --endpoint1=dpmac.3 --endpoint2=dpdmux.0.0
restool dprc connect dprc.1 --endpoint1=dpni.1 --endpoint2=dpdmux.0.1
restool dprc connect dprc.1 --endpoint1=dpni.3 --endpoint2=dpdmux.0.2
restool dprc connect dprc.1 --endpoint1=dpmac.4 --endpoint2=dpdmux.1.0
restool dprc connect dprc.1 --endpoint1=dpni.2 --endpoint2=dpdmux.1.1
restool dprc connect dprc.1 --endpoint1=dpni.4 --endpoint2=dpdmux.1.2
#echo dprc.2 > /sys/bus/fsl-mc/drivers/vfio-fsl-mc/bind
# Bind the DPRC back to VFIO
# Export the DPRC
export DPRC=dprc.2
[ 3103.545665] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.545690] ------------[ cut here ]------------
[ 3103.545701] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.545703] Modules linked in: libdes mali_dp
[ 3103.545715] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Not tainted 5.10.35 #5
[ 3103.545717] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.545721] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.545724] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.545727] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.545729] sp : ffff800012ef3c90
[ 3103.545731] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.545735] x27: 0000000000000000 x26: 0000000000000000
[ 3103.545740] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.545745] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.545749] x21: ffff0e7d1edc7800 x20: ffff0e7d3d39f040
[ 3103.545754] x19: ffff0e7d1d71db80 x18: 0000000000000001
[ 3103.545758] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.545763] x15: ffff0e7d3d39f040 x14: 00000000000007dd
[ 3103.545767] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.545771] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.545776] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.545781] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.545785] x5 : 0000000000000000 x4 : ffff0e83fc27d860
[ 3103.545789] x3 : ffff0e83fc284770 x2 : 0000000000000000
[ 3103.545793] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.545798] Call trace:
[ 3103.545802] vfio_fsl_mc_release+0xdc/0x190
[ 3103.545806] vfio_device_fops_release+0x24/0x48
[ 3103.545811] __fput+0x78/0x230
[ 3103.545814] ____fput+0x10/0x20
[ 3103.545818] task_work_run+0x80/0x140
[ 3103.545821] do_exit+0x324/0xa08
[ 3103.545824] do_group_exit+0x44/0xa0
[ 3103.545826] __wake_up_parent+0x0/0x30
[ 3103.545831] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.545834] do_el0_svc+0x24/0x90
[ 3103.545839] el0_svc+0x14/0x20
[ 3103.545841] el0_sync_handler+0xb0/0xb8
[ 3103.545845] el0_sync+0x178/0x180
[ 3103.545847] ---[ end trace d15991a0fbaef713 ]---
[ 3103.546381] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.546399] ------------[ cut here ]------------
[ 3103.546406] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.546411] Modules linked in: libdes mali_dp
[ 3103.546430] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.546435] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.546441] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.546447] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.546453] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.546458] sp : ffff800012ef3c90
[ 3103.546462] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.546466] x27: 0000000000000000 x26: 0000000000000000
[ 3103.546471] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.546475] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.546479] x21: ffff0e7d02d77000 x20: ffff0e7d3d39f040
[ 3103.546484] x19: ffff0e7d1dc13480 x18: ffffb28536ab3470
[ 3103.546488] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.546492] x15: ffff0e7d3d39f040 x14: 0000000000000805
[ 3103.546497] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.546501] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.546506] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.546510] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.546514] x5 : 0000000000000000 x4 : ffff0e83fc27d860
[ 3103.546518] x3 : ffff0e83fc284770 x2 : 0000000000000000
[ 3103.546522] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.546527] Call trace:
[ 3103.546529] vfio_fsl_mc_release+0xdc/0x190
[ 3103.546532] vfio_device_fops_release+0x24/0x48
[ 3103.546536] __fput+0x78/0x230
[ 3103.546539] ____fput+0x10/0x20
[ 3103.546541] task_work_run+0x80/0x140
[ 3103.546544] do_exit+0x324/0xa08
[ 3103.546546] do_group_exit+0x44/0xa0
[ 3103.546548] __wake_up_parent+0x0/0x30
[ 3103.546552] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.546555] do_el0_svc+0x24/0x90
[ 3103.546557] el0_svc+0x14/0x20
[ 3103.546559] el0_sync_handler+0xb0/0xb8
[ 3103.546562] el0_sync+0x178/0x180
[ 3103.546564] ---[ end trace d15991a0fbaef714 ]---
[ 3103.547072] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.547086] ------------[ cut here ]------------
[ 3103.547090] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.547091] Modules linked in: libdes mali_dp
[ 3103.547098] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.547100] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.547103] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.547105] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.547107] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.547109] sp : ffff800012ef3c90
[ 3103.547111] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.547116] x27: 0000000000000000 x26: 0000000000000000
[ 3103.547120] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.547125] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.547129] x21: ffff0e7d02d32000 x20: ffff0e7d3d39f040
[ 3103.547133] x19: ffff0e7d1dc13d80 x18: ffffb28536ab3470
[ 3103.547138] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.547142] x15: ffff0e7d3d39f040 x14: 000000000000082d
[ 3103.547146] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.547151] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.547155] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.547159] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.547164] x5 : ffff0e83fc27d860 x4 : 0000000000000000
[ 3103.547168] x3 : 0000000000000027 x2 : 0000000000000000
[ 3103.547172] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.547176] Call trace:
[ 3103.547179] vfio_fsl_mc_release+0xdc/0x190
[ 3103.547182] vfio_device_fops_release+0x24/0x48
[ 3103.547185] __fput+0x78/0x230
[ 3103.547188] ____fput+0x10/0x20
[ 3103.547190] task_work_run+0x80/0x140
[ 3103.547193] do_exit+0x324/0xa08
[ 3103.547195] do_group_exit+0x44/0xa0
[ 3103.547198] __wake_up_parent+0x0/0x30
[ 3103.547201] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.547204] do_el0_svc+0x24/0x90
[ 3103.547207] el0_svc+0x14/0x20
[ 3103.547209] el0_sync_handler+0xb0/0xb8
[ 3103.547211] el0_sync+0x178/0x180
[ 3103.547213] ---[ end trace d15991a0fbaef715 ]---
[ 3103.547721] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.547735] ------------[ cut here ]------------
[ 3103.547739] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.547740] Modules linked in: libdes mali_dp
[ 3103.547748] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.547750] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.547752] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.547755] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.547757] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.547759] sp : ffff800012ef3c90
[ 3103.547761] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.547765] x27: 0000000000000000 x26: 0000000000000000
[ 3103.547770] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.547777] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.547781] x21: ffff0e7d1e989000 x20: ffff0e7d3d39f040
[ 3103.547785] x19: ffff0e7d1dcc6680 x18: ffffb28536ab3470
[ 3103.547790] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.547794] x15: ffff0e7d3d39f040 x14: 0000000000000855
[ 3103.547798] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.547802] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.547807] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.547812] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.547819] x5 : ffff0e83fc27d860 x4 : 0000000000000000
[ 3103.547823] x3 : 0000000000000027 x2 : 0000000000000000
[ 3103.547827] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.547831] Call trace:
[ 3103.547834] vfio_fsl_mc_release+0xdc/0x190
[ 3103.547837] vfio_device_fops_release+0x24/0x48
[ 3103.547840] __fput+0x78/0x230
[ 3103.547843] ____fput+0x10/0x20
[ 3103.547845] task_work_run+0x80/0x140
[ 3103.547848] do_exit+0x324/0xa08
[ 3103.547850] do_group_exit+0x44/0xa0
[ 3103.547853] __wake_up_parent+0x0/0x30
[ 3103.547858] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.547861] do_el0_svc+0x24/0x90
[ 3103.547864] el0_svc+0x14/0x20
[ 3103.547866] el0_sync_handler+0xb0/0xb8
[ 3103.547868] el0_sync+0x178/0x180
[ 3103.547870] ---[ end trace d15991a0fbaef716 ]---
[ 3103.548378] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.548392] ------------[ cut here ]------------
[ 3103.548395] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.548397] Modules linked in: libdes mali_dp
[ 3103.548404] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.548406] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.548408] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.548411] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.548413] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.548415] sp : ffff800012ef3c90
[ 3103.548417] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.548421] x27: 0000000000000000 x26: 0000000000000000
[ 3103.548426] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.548430] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.548437] x21: ffff0e7d1ea4e000 x20: ffff0e7d3d39f040
[ 3103.548442] x19: ffff0e7d1dcc6f80 x18: ffffb28536ab3470
[ 3103.548446] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.548450] x15: ffff0e7d3d39f040 x14: 000000000000087d
[ 3103.548455] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.548459] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.548464] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.548468] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.548472] x5 : ffff0e83fc27d860 x4 : 0000000000000000
[ 3103.548479] x3 : 0000000000000027 x2 : 0000000000000000
[ 3103.548483] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.548488] Call trace:
[ 3103.548490] vfio_fsl_mc_release+0xdc/0x190
[ 3103.548493] vfio_device_fops_release+0x24/0x48
[ 3103.548497] __fput+0x78/0x230
[ 3103.548500] ____fput+0x10/0x20
[ 3103.548502] task_work_run+0x80/0x140
[ 3103.548505] do_exit+0x324/0xa08
[ 3103.548507] do_group_exit+0x44/0xa0
[ 3103.548509] __wake_up_parent+0x0/0x30
[ 3103.548513] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.548516] do_el0_svc+0x24/0x90
[ 3103.548519] el0_svc+0x14/0x20
[ 3103.548523] el0_sync_handler+0xb0/0xb8
[ 3103.548526] el0_sync+0x178/0x180
[ 3103.548528] ---[ end trace d15991a0fbaef717 ]---
[ 3103.549035] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.549049] ------------[ cut here ]------------
[ 3103.549052] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.549054] Modules linked in: libdes mali_dp
[ 3103.549060] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.549062] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.549065] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.549067] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.549069] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.549071] sp : ffff800012ef3c90
[ 3103.549073] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.549077] x27: 0000000000000000 x26: 0000000000000000
[ 3103.549082] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.549086] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.549090] x21: ffff0e7d1dd80000 x20: ffff0e7d3d39f040
[ 3103.549094] x19: ffff0e7d1dc09880 x18: ffffb28536ab3470
[ 3103.549098] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.549103] x15: ffff0e7d3d39f040 x14: 00000000000008a5
[ 3103.549107] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.549111] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.549116] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.549120] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.549124] x5 : ffff0e83fc27d860 x4 : 0000000000000000
[ 3103.549129] x3 : 0000000000000027 x2 : 0000000000000000
[ 3103.549133] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.549137] Call trace:
[ 3103.549139] vfio_fsl_mc_release+0xdc/0x190
[ 3103.549142] vfio_device_fops_release+0x24/0x48
[ 3103.549145] __fput+0x78/0x230
[ 3103.549148] ____fput+0x10/0x20
[ 3103.549151] task_work_run+0x80/0x140
[ 3103.549153] do_exit+0x324/0xa08
[ 3103.549155] do_group_exit+0x44/0xa0
[ 3103.549158] __wake_up_parent+0x0/0x30
[ 3103.549161] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.549164] do_el0_svc+0x24/0x90
[ 3103.549166] el0_svc+0x14/0x20
[ 3103.549168] el0_sync_handler+0xb0/0xb8
[ 3103.549171] el0_sync+0x178/0x180
[ 3103.549172] ---[ end trace d15991a0fbaef718 ]---
[ 3103.549679] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.549693] ------------[ cut here ]------------
[ 3103.549699] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.549701] Modules linked in: libdes mali_dp
[ 3103.549708] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.549710] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.549712] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.549715] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.549717] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.549718] sp : ffff800012ef3c90
[ 3103.549720] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.549725] x27: 0000000000000000 x26: 0000000000000000
[ 3103.549729] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.549733] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.549738] x21: ffff0e7d1dd9dc00 x20: ffff0e7d3d39f040
[ 3103.549744] x19: ffff0e7d1d6adc80 x18: ffffb28536ab3470
[ 3103.549749] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.549753] x15: ffff0e7d3d39f040 x14: 00000000000008cd
[ 3103.549757] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.549762] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.549766] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.549771] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.549775] x5 : ffff0e83fc27d860 x4 : 0000000000000000
[ 3103.549782] x3 : 0000000000000027 x2 : 0000000000000000
[ 3103.549786] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.549790] Call trace:
[ 3103.549792] vfio_fsl_mc_release+0xdc/0x190
[ 3103.549795] vfio_device_fops_release+0x24/0x48
[ 3103.549798] __fput+0x78/0x230
[ 3103.549801] ____fput+0x10/0x20
[ 3103.549804] task_work_run+0x80/0x140
[ 3103.549806] do_exit+0x324/0xa08
[ 3103.549809] do_group_exit+0x44/0xa0
[ 3103.549811] __wake_up_parent+0x0/0x30
[ 3103.549814] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.549818] do_el0_svc+0x24/0x90
[ 3103.549822] el0_svc+0x14/0x20
[ 3103.549824] el0_sync_handler+0xb0/0xb8
[ 3103.549827] el0_sync+0x178/0x180
[ 3103.549829] ---[ end trace d15991a0fbaef719 ]---
[ 3103.550346] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
[ 3103.550360] ------------[ cut here ]------------
[ 3103.550368] WARNING: CPU: 2 PID: 3644 at drivers/vfio/fsl-mc/vfio_fsl_mc.c:212 vfio_fsl_mc_release+0xdc/0x190
[ 3103.550373] Modules linked in: libdes mali_dp
[ 3103.550393] CPU: 2 PID: 3644 Comm: gnb_du_layer2 Tainted: G W 5.10.35 #5
[ 3103.550398] Hardware name: NXP Layerscape LX2160ARDB (DT)
[ 3103.550404] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[ 3103.550410] pc : vfio_fsl_mc_release+0xdc/0x190
[ 3103.550416] lr : vfio_fsl_mc_release+0xdc/0x190
[ 3103.550420] sp : ffff800012ef3c90
[ 3103.550426] x29: ffff800012ef3c90 x28: ffff0e7d3d39f040
[ 3103.550432] x27: 0000000000000000 x26: 0000000000000000
[ 3103.550437] x25: 0000000000000000 x24: ffff0e7d3d39f440
[ 3103.550441] x23: ffff0e7d030cc800 x22: 00000000fffffff3
[ 3103.550456] x21: ffff0e7d1ee17800 x20: ffff0e7d3d39f040
[ 3103.550469] x19: ffff0e7d1dc81580 x18: ffffb28536ab3470
[ 3103.550483] x17: ffff0e7d00001088 x16: ffff0e7d000010a8
[ 3103.550496] x15: ffff0e7d3d39f040 x14: 00000000000008f5
[ 3103.550510] x13: ffff0e7d3d39f4a0 x12: 00000000ffffffea
[ 3103.550523] x11: ffffb28536b23468 x10: ffffb28536b0b428
[ 3103.550536] x9 : ffffb28536b0b480 x8 : 0000000000017fe8
[ 3103.550549] x7 : c0000000ffffefff x6 : 0000000000000001
[ 3103.550564] x5 : 0000000000000000 x4 : ffff0e83fc27d860
[ 3103.550577] x3 : ffff0e83fc284770 x2 : 0000000000000000
[ 3103.550587] x1 : 0000000000000000 x0 : 0000000000000000
[ 3103.550591] Call trace:
[ 3103.550594] vfio_fsl_mc_release+0xdc/0x190
[ 3103.550597] vfio_device_fops_release+0x24/0x48
[ 3103.550600] __fput+0x78/0x230
[ 3103.550603] ____fput+0x10/0x20
[ 3103.550605] task_work_run+0x80/0x140
[ 3103.550608] do_exit+0x324/0xa08
[ 3103.550610] do_group_exit+0x44/0xa0
[ 3103.550612] __wake_up_parent+0x0/0x30
[ 3103.550616] el0_svc_common.constprop.0+0x78/0x1a0
[ 3103.550618] do_el0_svc+0x24/0x90
[ 3103.550621] el0_svc+0x14/0x20
[ 3103.550623] el0_sync_handler+0xb0/0xb8
[ 3103.550626] el0_sync+0x178/0x180
[ 3103.550628] ---[ end trace d15991a0fbaef71a ]---
[ 3103.551136] vfio-fsl-mc dprc.2: VFIO_FLS_MC: reset device has failed (-13)
